Go Back   NASIOC > NASIOC Subaru Models > Outback Forum
Old 10-30-2003, 10:38 PM   #1
Slowhand
Member#: 46361
1997 Outback Wagon
Spruce Pearl Green
Default Just bought 97 OB wagon w/problems outback
Just bought a 97 w/100k. Car looks and drives like new, until I removed the FWD fuse up front------now it's binding and clunking, especially on slow turns and under power. Feels like a posi-traction rearend w/problems. Called the dealer and he said $875.00---$1400.00 without seeing it[pretty good huh?] I used to have a 90 Legacy awd wagon w/ 175k and never had this trouble. So---------is it the rearend [clutch pack ?] half shafts ,etc. I used to sell em in the 80's when things were simple. p.s. I realize the previous owner pulled a fast one by disengaging the awd and making it a fwd. I wondered about the light on the dash, but didn't research it until I had it home. Any help would be appreciated. Thanks
Slowhand is offline   Reply With Quote
Old 10-31-2003, 02:07 AM   #2
sybir
Member#: 4615
05 FXT/01 OB/97 OB
Yes.
Sounds like the rear end or the center diff, you're getting torque bind.
Something to try: do about 6-8 tight figure 8's (full lock). This can sometimes clear the problem up, if something has just gotten misaligned.
I'm pretty sure it's a problem with the transfer case/center diff, as the rear ends are pretty much bulletproof, even at double stock output. Hope that helps.
Sorry to hear you got ripped off, was it a private seller, or a dealer you can go back to?
sybir is offline   Reply With Quote
Old 10-31-2003, 02:09 AM   #3
sybir
Member#: 4615
05 FXT/01 OB/97 OB
Yes.
Also could be something as simple as CV joints/axles. The junkyard is your friend, since most subarus from 90-2004 (lol) use the same axles/rear end components.
Old 10-31-2003, 10:16 AM   #4
Slowhand
Member#: 46361
1997 Outback Wagon
Spruce Pearl Green
I bought it from a private individual so I'm on my own. [QUESTION] Is it OK to put the fuse back in and run it in FWD only until I fix it ? Don't need AWD now anyway, it's 78 degrees and sunny ! Thanks for the quick replies.
Old 10-31-2003, 04:05 PM   #5
gavin
Member#: 3198
2005 GT LTD Wagon
Garnet Red
sounds like it might be a good opportunity to put in a LSD rear...
gavin is offline   Reply With Quote
Old 10-31-2003, 10:23 PM   #6
GLwagon
Member#: 16696
2002 WRX Sedan Stg2
2013 OBW roll'n at 30+mpg
Here are some odd thoughts...
? auto or manual (assuming that manuals of that year could be disengaged)
? is the rear diff the right ratio ?
? does it bind & clunk in a strait line at all ?
? are the tires the same size & worn evenly front to rear ?
? is the sound a "hurclunk hurclunk hurclunk" or "clickity clickity clickity" ?
Posible thoughts & options...
Rear drive shaft U-joints, or center diff
Put in a togle switch & an inline fuse, & disengage the system from inside when not needed... The AWD solenoid should take the abuse from being on.
GLwagon is offline   Reply With Quote
Old 10-31-2003, 11:49 PM   #7
Slowhand
Member#: 46361
1997 Outback Wagon
Spruce Pearl Green
I'm going to change all the fluids tomorrow[trans,both differentials] and measure the tires and see if I have an oddball. Some [lucky owners] have solved this problem with just the fluid changes and or replacing the tires. My Michelin XSE radial pluses are about half gone and are noisy anyway. What tires seem to do the best as far as 1. good ride 2. quiet. I'm not going to go "Mudboggin" so I don't need a real aggressive tread.
Old 11-01-2003, 06:01 PM   #8
Slowhand
Member#: 46361
1997 Outback Wagon
Spruce Pearl Green
Changed all the fluids [engine,transmission,and rear differential [will do the front tomorrow] and guess what ? No more binding and clunking ! Drives like new. Drove a couple blocks,stopped and pulled the FWD fuse , held my breath and took off----I could tell within a block it was OK-------Thank you Jesus,Thank you Lord !. Might not have been a miracle, but it sure is nice knowing I don't have to spend a $1000.00 bucks !
Old 11-02-2003, 12:00 AM   #9
Rally Medic
Member#: 28249
1998 Outback Sport
Dirty with some mud flaps
875.00 for a dealer fluid change.. you are the man , you should go rub that in there face.. BTW ill be going to you for my clunking and or binding issue's
www.gravelcrew.com
MeDiC
RALLY-On
Rally Medic is offline   Reply With Quote
WTB receiver hitch for 97 OB Wagon outback_97 Private 'Wanted' Classifieds 2 03-24-2005 10:23 AM
For Sale - Dog Guard for 97 OB Wagon jeffsti_buffalo Private 'For Sale' Classifieds 2 08-31-2004 11:11 AM
Just Bought a WRX, and common problems or issues with the car? FTY Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 05-20-2004 11:16 PM
GF just bought Legacy L Wagon. Eric Gagnon Legacy Forum 2 05-21-2001 10:48 PM
