Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 10-27-2000, 08:10 PM   #1
chyisan
Member#: 1083
99 Altima
Post Shifting an Automatic: what RPM?
If I wanted to shift my automatic manually, (is this called powershifting?) at what RPM would I shift from 1-2-3-D?
chyisan is offline
Old 10-27-2000, 08:22 PM   #2
T-WRX
Member#: 2468
08 RS4
05 STi - Gone
Post
Power shifting is with a manual, when you don't lift the gas pedal while pushing the clutch in/out.
T-WRX is offline
Old 10-28-2000, 02:11 AM   #3
ivbdn
Member#: 2736
2001 Impreza 2.5RS
Post
I don't think it's a good idea to be shifting your auto manually. Unless you're racing, I don't see the need to manually shift the car (although I do it on occasion). Just out of curiosity, what's your reason for wanting to manually shift your auto?
ivbdn is offline
Old 10-28-2000, 04:18 AM   #4
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Post
I would assume hes talking going up/down hills, or using the gears to slow down possibly... am I right?
Kostamojen is offline
Old 10-28-2000, 10:57 PM   #5
chyisan
Member#: 1083
99 Altima
Post
No, I meant shifting manually. Like for racing. I've done it one time from a standing start and didn't notice any gains. I've read about people doing this when racing with automatics, so I thought I might be doing something wrong.
But while at it, is it bad for the auto tranny to use the gears to slow down? I've done that also...
Basically, I'm just really bored with an auto and like to play around with it.
chyisan is offline
Old 10-29-2000, 12:10 AM   #6
Faraz
What?...
Do they speak English in What?
Member#: 1459
2008 WRX 5door MT
WR Blue
Post
if you keep the pedal down on the auto it will shift at the redline on its own....just while its in D
Faraz is offline
Old 10-29-2000, 12:27 AM   #7
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Exclamation
Your Manual will say what speeds you can use in each gear, and you can do it at any time you want usually within those speed limits, but as for racing... dont do it.
What you need is a Sport-shift car (you know, the auto/manual shifters )
Old 10-29-2000, 04:26 AM   #8
ivbdn
Member#: 2736
2001 Impreza 2.5RS
Talking
If there was some way to convert my AT to a sport shift...I'd be willing to shell out the $$$ (as long as it's reasonable). Anybody know anything about making it possible?
ivbdn is offline
Old 10-29-2000, 04:46 AM   #9
SnapperHead
Member#: 2740
Post
Before I bought my manual Scooby, I had a supercharged Camaro RS, auto. I had a shift kit installed to make for more positive shifting. When running at the track, I had no difference between manual i.e. 1 2 d od and just leaving it in D Just made me feel like I was doing something when I was doing the shifting. Although redline really creeps up on you fast blowing 9lbs of boost. Especially on a 5500 redline. As far as converting, not worth the money. IMHO But I know what you mean.
SnapperHead is offline
Old 10-29-2000, 04:49 AM   #10
SnapperHead
Member#: 2740
Post
As far as what RPM, you'll have to run it at the track varying, depends on your set up, if you have all low end, shift early. IF you have high end, redline the puppy.
Old 10-29-2000, 05:12 PM   #11
ivbdn
Member#: 2736
2001 Impreza 2.5RS
Post
Well, if I could drive stick, it wouldn't be worth conveting in my opinion either. But since I can't drive stick (due to a condition I was born with) I'll have to just settle smokin' Honduhs in an auto. *sigh*
ivbdn is offline
Old 10-29-2000, 05:44 PM   #12
Faraz
What?...
Member#: 1459
2008 WRX 5door MT
WR Blue
Post
level 10 ...makes a speed shifter for the RS
Faraz is offline
HTML code is On
Ok, I just didn't shift gear until 8000 RPM, what should I do now? IMPEXRALLY Transmission (AT/MT) & Driveline 17 01-05-2003 04:36 PM
What rpm do you shift your WRX? moojamboo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 28 04-14-2002 05:32 PM
At what RPM do you guys shift up or normal driving? myfirstnewcar General Community 46 03-27-2002 01:17 AM
Shifting at what RPMs is faster? kotaro Newbies & FAQs 9 12-03-2001 05:10 PM
AutoX'n in an automatic: which to use? D-3-2-1? chyisan General Forum Archive 3 10-01-2000 10:07 PM
