#1 |
Member#: 6943
Vehicle:'04 05 STi (Sold) 02 WRX (Sold) |
The WRX comes with speaker rain shields in the rear and (apparently) none in the front. Are these necessary? If they are, why aren't they installed in the front too? My Infinity Reference's have just arrived and the instructions say to avoid water or rain. I'd like to hear some thoughtful opinions on the subject. Thanks.
#2 |
Member#: 36838
Vehicle:2000 RS Sedan 2004 STi w/RS body swap |
I keep meaning to get baffles for my front speakers, but I haven't really had much rain get in there. Depending on the materials used to make the speaker, it may or may not be damaged by water. Surely any paper cone speaker will be mostly destroyed by water, but most new cones tend to use either plastic/fiberglass/kevlar or some other composite. I've found the coating on these to be pretty water resistant. You also don't want water getting on your speaker terminals or lead wires as it can corrorode them after time. It's a good idea to try and do what you can to keep them dry.
You can buy XTC foam baffles from crutchfield for like $20 for 4 and customize them for your own needs. I'll probably go find my old ones and do this when I put my Focal's back in this weekend. |
#3 |
Member#: 17256
Vehicle:04 STi Blue w/ custom bug splat |
I had the foam baffles installed when I had the shop install my diamond fronts. They sounded bass-less (is htat a word?). The tech told me that they needed more room to work in and recommended taking out the baffles. I did this and it DID pick up a little bit of mid-bass. But not much.
Almost all modern speaker cones are very water resistant or waterproof. And the place where they are installed is pretty dry to start with. If it were not, the water would run down and into the interior of the car, soaking the carpet. |
#4 |
Member#: 32434
Vehicle:05 Outback XT 5EAT Gold/Black |
The XTC baffles can make your speakers sound flat, since they restrict cone movement (by putting a cushion of air behind the speaker). However, you can cut a hole in them and alleviate the problem.
When I use them, I normally cut out the lower 20-30%. They will still be fine as rain shields, but not hurt sound. Craig |
#5 |
Member#: 36838
Yeah, I cut the bottom 1/2 off of my baffles...I just need to find them...
| Thread Tools | |
| Display Modes | |
| Wanted in Socal: OEM heat shield, rear speakers, downpipe | Zoombaru | Private 'Wanted' Classifieds | 2 | 06-11-2007 10:37 PM |
| WRX Speaker Rain Shields | We're Here | Private 'Wanted' Classifieds | 2 | 11-22-2003 07:05 AM |
| WRX OEM Speaker Rain Shields | We're Here | Private 'Wanted' Classifieds | 4 | 11-11-2003 11:53 PM |
| Front Door Dynamat: Remove Plastic Rain Shield? | skybluedoc | Car Audio, Video & Security | 15 | 09-12-2003 04:12 PM |
| rain shield | RotarFreak | Normally Aspirated Powertrain | 4 | 12-03-2001 11:35 PM |
