Old 10-31-2003, 11:23 AM   #1
Subasaurus Rex
Member#: 5269
1998 Forester L
Black Diamond Pearl
Default What manifolds will wrx injectors fit in, AND fit an '01 2.5 motor???
I searched and found that the '99 RS intake will work for this, correct?
I'm curious if any of the newer (Forester XT / Sti) ones work? I'm assuming that you could also use Forester XT injectors, because they are larger, correct? Would they plug into the RS wiring, or are they a different style injector?
Thanks for the help.....
PS - for the record, this would be on an RS-T setup
Subasaurus Rex is offline   Reply With Quote
Old 10-31-2003, 12:19 PM   #2
FJP
Member#: 43852
GC8 2.5RST
I got them to fit my '01 manifold. You just need to mildly port where the injectors spray out of. The 99 and 01 injectors are actually the same length, it's just that the 01 has an extra plastic piece on the end of it for air assist. You also need to play with O-rings to ensure a good seal.
FJP is offline   Reply With Quote
Old 10-31-2003, 12:26 PM   #3
Section 8
Member#: 821
Use a WRX upper manifold and STi RA lower manifold. The WRX manifold is much more efficent than the RS manifold. I vote for plastic as well.
You could use a complete stock WRX manifold, and just remove the TGV's as well.
Plus the manifold is shorter lengthwise, giving you more room behind the manifold so you don't have to screw around with the stuff already back there.
cheeRS,
Greg
Section 8 is offline   Reply With Quote
Old 10-31-2003, 12:33 PM   #4
FJP
Member#: 43852
GC8 2.5RST
Greg
say what?
Old 10-31-2003, 12:42 PM   #5
Section 8
Member#: 821
If you are getting the WRX manifold, get the plastic one.
Old 10-31-2003, 12:47 PM   #6
FJP
Member#: 43852
GC8 2.5RST
No way!!! They make a plastic one? Don't forget to get the throttle body since the RS cable mounts are on the wrong side and won't bolt up anyways. Any idea how much the plastic one costs?
Old 10-31-2003, 01:14 PM   #7
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
Most of the newer manifolds are plastic, even the new RS's.
lotusTT is offline   Reply With Quote
02 2.0 WRX flywheel in an 03 2.5 Legacy, will it work? meandean Transmission (AT/MT) & Driveline 3 11-15-2006 11:45 PM
'01 2.5 SOHC heads and manifold JoshP Private 'For Sale' Classifieds 45 11-20-2005 01:54 PM
WRX engine mated to an '01 RS 5-speed in a '99 OBS? Geoff Subaru Conversions 23 01-05-2004 12:00 PM
WTB: '00/'01 2.5 motor Subasaurus Rex Private 'Wanted' Classifieds 1 10-16-2003 09:32 AM
Will WRX be shown in SoCal at an auto show? socal2.2 General Forum Archive 4 11-02-2000 10:30 AM
