Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 10-31-2003, 12:49 PM   #1
mannix
Member#: 46504
2004 WRX wagon
Default Stock Boost gauge - what should it read?
Hi all - I have a 2004 WRX, came with the factory boost gauge.
For those that have the same (or similar MPa) gauge, what does it get to at max boost, on a stock car? AFAIK, these things are supposed to make 13-14psi, give or take, not sure what that correlates to on the goofy gauge.
I live in Denver; the car makes more boost at sea level(expected, at least from my experience with turbo Audis), shrug, just curious - the car is not slow, just wondering what it "should" say.
Iain Mannix
mannix is offline   Reply With Quote
Old 10-31-2003, 02:39 PM   #2
mixup52
Member#: 39691
2002 WRX Wagon
Ok if you have the stock gauge, which reads in MPa (mega Pascals) which in turn converts like this, .1 MPa =14.52 Psi. Hope that helps.
mixup52 is offline   Reply With Quote
Old 10-31-2003, 02:43 PM   #3
mannix
Member#: 46504
2004 WRX wagon
Thanks - that means my car is making ~11.xx psi (it gets to .07-8 on the gauge @ altitude).
Anyone have a gauge in a stock WRX to compare? Seems low on one hand, otoh, it may well be altitude.
Thanks!
Iain
Old 10-31-2003, 03:01 PM   #4
quynce
Member#: 15409
Mine read .08 most of the time. It would sometimes spike up to .095 but only for a split second. I have an Omori gauge in the OEM pod now that reads in PSI. When the car was stock it was about 11-12psi. I've since put in a Cobb flashed ECU and I now make a consistent 13-13.5 psi. hth
quynce is offline   Reply With Quote
Old 10-31-2003, 03:17 PM   #5
mannix
Member#: 46504
2004 WRX wagon
Helps a lot - thanks! Seems like my car is normal (or both of ours had issues.
Iain(mine spikes past .08 briefly too)
Old 10-31-2003, 07:08 PM   #6
WheelsCSM
Member#: 20765
2008 Forester XT
6mt/18g-xt
Yea, that's about what I get too, usually around .075 MPa, it does spike a little higher, I think one time I saw it spike to .009
WheelsCSM is offline   Reply With Quote
Old 11-01-2003, 12:26 AM   #7
KeithRS
Member#: 3436
1987 Rockhopper
Yellow
Mine is always negative (well, if I had a vacuum gauge, it would be). Of course, I have a block off plate under my hood scoop, too...
-Keith Wenzel
KeithRS is offline   Reply With Quote
Old 11-04-2003, 03:42 PM   #8
mannix
Member#: 46504
2004 WRX wagon
Ahhh, I have conclusive proof that a boost gauge attached to a car with a boost producing device is a Good Idea.
Iain
Old 11-04-2003, 03:46 PM   #9
Fuquad
Member#: 16164
For future boost measurement conversions:
http://www.onlineconversion.com/
Fuquad is offline   Reply With Quote
Testing Front OEM O2/AFR Sensor... What Should It Read? TDQuiksilver Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-17-2008 08:02 PM
WHat should be my readings on stock boost gauge? jaskillz Newbies & FAQs 16 02-18-2006 04:15 AM
stock boost gauge, what the? dakwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 05-05-2005 11:22 PM
What should the factory installed boost gauge on an STi read? SithSolo1 Newbies & FAQs 3 01-03-2005 02:54 PM
What should vacuum read on Boost gauge? MARTY5446 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-28-2001 03:42 PM
