Old 10-31-2003, 01:06 PM   #1
lupohki
Member#: 3457
2008 STi
Exclamation Help ... CEL 1086 re: Tumble Generator Valve - SOLVED
I was installing a grounding kit and to reach one of the bolts I removed the Tumble generator valve ASSY (didn't know what it was at the time) without disconnecting the battery as outlined in the service manual:
service manual
After reconnecting it and starting up, I had a CEL and the blinking cruise light. I went to Autozone and they pulled a 1086 code which is:
Tumble Generated Valve Position Sensor 2 Circuit Low
There isn't anything complicated in detaching and reattaching the piece. It's just 2 bolts on the housing and then there's a tab that goes into what looks like a spinning wheel on the other end. Did I fry it?
Driving-wise, throttle sound is different and response is noticeably weaker.
Any ideas before I take it to the dealership?
Here's a pic of it:
edit: updated proper naming of diff pieces based on service manual
SOLUTION: I needed to wind up the spring before reattaching the assembly by inserting the plug end in the 12 o'clock position and then twisting it to the 3 o'clock postion where it lines up with the bolt holes.
lupohki is offline   Reply With Quote
Old 10-31-2003, 01:18 PM   #2
dsmperformance
Member#: 15059
2004 WRX STi
1991 TSi
Clear the code and see if you get it again.
dsmperformance is offline   Reply With Quote
Old 10-31-2003, 01:19 PM   #3
lupohki
Member#: 3457
2008 STi
I tried clearing the code via disconnecting the battery and also the autozone guy tried clearing it via the machine, and it doesn't go away.
Old 10-31-2003, 05:44 PM   #4
Amazake
Member#: 9889
just did the same thing on my O2 unfortunately i cracked mine
Amazake is offline   Reply With Quote
Old 11-01-2003, 11:48 PM   #5
cann
Member#: 8618
hey i can help
u take out the thing
u see inside it's like > <
if u use a screwdriver, it turns
and u see on the car there is a ---
so u need to put that thing on the --- turn it a bit, and bolt the two screws
idea is
> < at 0 degree = low
> < at 45 degree = car works fine
> < at 90 degrees = high
cann is offline   Reply With Quote
Old 11-02-2003, 06:04 PM   #6
Invisiguard
Member#: 43201
04 STi
07 Corvette
did you pump the brake pedal a few times after you disconected the battery to reset? thats supposed to be one ofthe steps to reset.
Invisiguard is offline   Reply With Quote
Old 11-02-2003, 06:10 PM   #7
cann
Member#: 8618
u don't need to reset it
pump brake = drain the leftover batt
Old 11-02-2003, 07:32 PM   #8
xtmx
Member#: 40390
2008 EVO X
Gray
Listen to Cann.
I just replaced the right side TGV sensor. You have to push the sensor in with the plug (were you harness connects to the sensor) at the 12 o'clock position and rotate down to the 9 or 3 o'clock position (or the screw holes line up) or start in the with the plug in the 6 o'clock position and rotate up to the 9 or 3 o'clock position.
In other words the sensor is spring loaded, take a look at it you will figure it out.
Originally posted by cann
hey i can help
idea is
> < at 0 degree = low
xtmx is offline   Reply With Quote
Old 04-18-2005, 06:32 PM   #9
WRXFan007
Member#: 85268
Default Right TGV Sensor giving Low error P1088
OK, I had a shop work on my uppipe and when I got it back the CEL was on and giving P1088, which as I know now is related to the Tumble Generator Valve (right, or passenger side).
It looks like the mechanic probably slipped and hit the sensor housing with a tool, as there is a dent in the plastic, and what appears to even be a start of a crack near the edge.
Since this is on a '04 WRX, and it's not going away after a reset, I'm wondering this:
Do you think that I have to remove the Turbo in order to adjust it (assuming it's just nocked a little out of adjustment), or do you think I can simply remove both screws and try turning it a little one way or another instead of pulling it entirely out?
I am thinking It'll have to remove the turbo and pull out the TGV Sensor 2-3 inches just to adjust it...
Thanks for your help!
WRXFan007 is offline   Reply With Quote
Old 04-18-2005, 08:52 PM   #10
drale954
Member#: 50739
2004 wrx sti
You have to position the sensor 90degress. Trust me i have the APS tumbler deletes for my STI. I doubt there is anything wrong with the sensor. YOu have to put tension on the sensor.
drale954 is offline   Reply With Quote
Old 04-18-2005, 11:24 PM   #11
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp [email protected]
cann is correct. I did the same thing.....its spring loaded and you have to put tension on the spring.
SloRice is offline   Reply With Quote
Old 05-20-2005, 07:14 AM   #12
Peaty
Techno Sapien
Member#: 449
2010 Legacy 3.6R Lim
Azurite Blue Pearl
This thread helped me do my TGV sensor so I thought I'd post my scoobymods page incase like me someone did a search on the problem:
http://www.scoobymods.com/forums/showthread.php?t=5159
Peaty is offline   Reply With Quote
Tumble generator valve CEL TyranosaurusWRX Newbies & FAQs 11 08-09-2010 08:46 PM
CEL Code: P1090 Tumble generator valve #1 (RH) malfunction (stuck open) 4sworks Newbies & FAQs 6 08-14-2009 01:23 PM
P2009 CEL Tumble Generator Valve 97OBWagon Service & Maintenance 4 12-29-2008 06:31 PM
HELP! P1088 - Locating Tumble generator valve #1 scoolbuzz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 02-08-2004 05:31 PM
Check engine. Tumble generator valve EPD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-12-2001 11:47 AM
