Old 11-01-2003, 11:27 AM   #1
c_hunter
Member#: 32434
05 Outback XT 5EAT
Gold/Black
Default CD changer input on Stock WRX head unit
I noticed that the stock WRX head unit has an additional connector on the back, which is likely for the add-on Subaru CD changer. Has anyone added the changer to this unit, thereby enabling a total of 12 CDs? Does it work?
More importantly, I was wondering if anyone knew whether or not this connector could be hijacked and used for other types of inputs, say an iPod.
Look at the connector here:
(the connector in question is on the lower left)
There appears to be eight pins. Four of these would likely be the line in. The other four would likely control a trigger and logic for communication between the changer and head unit.
Anybody have a wiring schematic for either the stock head unit or the add-on CD changer? If we had more info, it should be possible to hijack this connector and use it for various line-in applications.
thanks!
Craig
c_hunter is offline   Reply With Quote
Old 11-01-2003, 12:24 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
This has been discussed in the past. If you do a way-back search in this forum some threads should come up. IIRC nobody ever figured out a ways to use that connector.
Old 11-01-2003, 03:56 PM   #3
mikkyo
Member#: 25399
2003 Impreza WRX
With the WRX head unit, I think that is only for the subwoofer.
I haven't seen an add in remote CD changer for the stock unit.
If there were, there would be a way to use that connector for other stuff.
As it is, it would appear to be output only.
mikkyo is offline   Reply With Quote
Old 11-01-2003, 04:04 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The factory sub is connected externally with a harness adapter and uses the rear speaker outputs, it does not connect directly to the HU. FYI this is why you can replace the HU with an aftermarket one and still use the sub.
There is no optional external changer offered. However the speculation is that since the HU is manufactured by Matsushlta, the same unit may be used in other applications where an external device would be connected to the extra plug. Any data link used would be proprietary so it's highly unlikely you could do anything else with it.
Adding a sub to a stock WRX head unit? Jon Martin Car Audio, Video & Security 1 10-28-2002 12:25 PM
want to borrow: Stock WRX Head Unit SeattleWRX North West Impreza Club Forum -- NWIC 4 09-14-2002 01:07 AM
Stock WRX Head Unit SeanLiew Canada Region Forum 7 03-13-2002 02:14 PM
Stock WRX head unit SaintViper Car Audio, Video & Security 9 12-04-2001 01:52 AM
Replacing Stock WRX Head Unit--Adapter? shakattk Car Audio, Video & Security 6 08-08-2001 03:37 PM
