Old 11-01-2003, 01:06 PM   #1
gerbs
Member#: 41597
Question little RPM jump while letting off gas and engaging clutch at same time??
hey guys, i've gotten my wrx's tricky manual tranny/overpowered clutch pretty much programmed into my brain now, but i have one kink to work out, which is figuring out why that when i let off the throttle and engage the clutch at the exact same time (both soft and hard clutching) there is some noticiable lag AND/OR alot of the time like 500~ rpms hop up before they begin to drop.
would possibly a grounding kit fix this issue (because it might make the throttle more responsive?)??
or should i just start letting off the throttle a little early? i'd much rather buy a grounding kit if it would actually help
also, about a grounding kit.. is it true that the 04's have better grounding wire or is that just a rumor i picked up somewhere?
has anyone else noticed this on their 04 rex??
THANKS!
(sorry for the never ending run-on sentence... F+ for me )
gerbs is offline   Reply With Quote
Old 11-01-2003, 01:15 PM   #2
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
At first I thought it was just that my timing was off or whatever.
After getting the Utec and looking at logs it's clear that on all transitions the ECU enriches fuel for a short time to stave off detonation. In the case of shifting it's sort of an unwanted side effect, but it still helps to keep the engine from getting det.
Nothing will 'fix' it short of an aftermarket standalone ECU. You may be able to ask a n ECUtek tuner to adjust the enrichment amount/time on a reflash, but depending on how the parameters are setup in the ECU it may or may not be plausible to do so.
Concillian is offline   Reply With Quote
Old 11-01-2003, 01:35 PM   #3
gerbs
Member#: 41597
is there any way to help the situation without modding my ECU?
Old 11-01-2003, 04:02 PM   #4
larryg
Member#: 13911
2002 Maxima
It happens on my 02 also, but only on part-throttle acceleration. Drove me nuts at first but I hardly notice it anymore.
Larry
larryg is offline   Reply With Quote
Old 11-01-2003, 04:30 PM   #5
gerbs
Member#: 41597
the only reason it drives me crazy is cause of the friggen rev when i change gears sometimes.. it's almost embarassing
Old 11-01-2003, 09:31 PM   #6
hotrod
Member#: 14141
2002 Impreza WRX
Default covered many times
This is normal for the WRX
Don't worry guys, this is completely normal, for this car. If you dig back through the list you will see it gets discussed about every 2-3 weeks on one of the forums or another.
It is a result of residual boost build up as you let off the throttle. If you make your shift just as you begin to build boost and the turbo is spooling up, when you lift the throttle, there is a sudden rise in pressure in the intercooler as the throttle begins to close. Since it takes a moment for the throttle to close, the higher pressure flows more air through the remaing opening in the throttle body.
This gives the effect of a quick blip of the throttle.
It is most obvious if you short shift around 3500-4000 rpm or so. You don't see it in more agressive shifting because the boost increase is enough to pop the BOV, and in low speed shifting the turbo has not started to spool significantly and your shifts are usually slower (gives more time for the throttle to close so less pressure rise)
It is easy to deal with, just lift on the throttle a fraction of a second before you start your shift. That way when you press the clutch in and unload the engine, the boost increase has already disappeared.
Larry
http://forums.nasioc.com/forums/show...residual+boost
hotrod is offline   Reply With Quote
Old 11-01-2003, 11:15 PM   #7
wbwrx
Member#: 22475
02 wrx
black
you tps could be going bad. that is what mine is doing so you looked at the scaner and it showed that the tps was bad
wbwrx is offline   Reply With Quote
Old 11-01-2003, 11:19 PM   #8
AndyWRXWG
Member#: 23784
2005 M3
Tiag
that's weird I was just having that happen to me tonight and was wondering what the hell was going on. I've noticed it before, but for some reason tonight it just kind of hit me and I was questioning it. wierd.....
AndyWRXWG is offline   Reply With Quote
Old 11-01-2003, 11:36 PM   #9
gerbs
Member#: 41597
Wink
maybe its the chicagoy rains that are getting to our scoobies
what = tps?
Old 11-02-2003, 01:06 AM   #10
wbwrx
Member#: 22475
02 wrx
black
what = tps?
throttle position sensor
Old 11-02-2003, 01:09 AM   #11
gerbs
Member#: 41597
ic.
so a grounding kit is deemed useless in this situation?
and does anyone know if the grounds are better on 2004 wrxs??
thanks for all the replys guys! it's very appreciated
Old 11-02-2003, 01:27 AM   #12
wbwrx
Member#: 22475
02 wrx
black
my 02 is grounded and it dose not help
Old 11-02-2003, 03:21 AM   #13
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
Larry
Ive seen it talked about 3 or 4........ dozen times.
Car shakes violently when letting off gas at 5k rpms? Help... ImportVenom Transmission (AT/MT) & Driveline 9 10-21-2011 06:16 AM
Keep high beams and fogs on at same time? kpalena Electrical & Lighting 4 04-19-2007 01:28 PM
24 Finale and Mavs/Spurs at Same Time? CONSPIRACY! Spider Pig Texas Impreza Club Forum -- TXIC 34 05-22-2006 11:40 PM
06 STI Clear Fender Gap and improve ride at same time eSToI Loco Brakes, Steering & Suspension 5 01-02-2006 09:56 PM
High beams and Low beams at same time trojan9x Interior & Exterior Modification 9 10-19-2001 10:49 AM
