Canada Region Club
Go Back   NASIOC > NASIOC Regional Areas > Canada Region Forum
Old 11-01-2003, 05:00 PM   #1
bigbear522
Member#: 21304
2002 Impreza WRX
Funky Silver Party Wagon
Default Steel wheels for WRX ?
So where is a good place to get it? How much should they cost? ~ $70? any suggestions? or should I look back on a previous thread if you guys have discuss about this already. Thanks. I am just looking for steel wheels.
Damian you have anything good on your yard?
bigbear522 is offline   Reply With Quote
Old 11-01-2003, 09:24 PM   #2
fishbio
Member#: 43614
2004 WRX Wagon
COSTCO - about $48 each.
Larry
fishbio is offline   Reply With Quote
Old 11-02-2003, 01:51 AM   #3
bigbear522
Member#: 21304
2002 Impreza WRX
I though costco only sell tires? I was there today but I did't see any steel rims.
Old 11-02-2003, 10:59 AM   #4
damianq
Member#: 5380
1999 Impreza
Primer
Yeah I have some stuff. We'll have to check if they'll fit. Costco does bring in 5x100 (VW & Chrysler) steel winter wheels but you will have to special order the Subaru 53mm offset. Only takes about a week though. We got some from there before. Not very strong but perfectly round enough for regular winter duty.
damianq is offline   Reply With Quote
Old 11-02-2003, 11:24 AM   #5
bigbear522
Member#: 21304
2002 Impreza WRX
Thanks for taking a look.
Old 11-02-2003, 01:08 PM   #6
markus
Member#: 438
2004 STi
White on Gold
spt_impreza has a set of steelies with winter tires on already. Don't know if they'll fit a WRX though, cause I think his are 15's.
Also, Jeremy still has some at Rally.
Finally, IIRC, last time I checked this out at Costco, they did say the Subaru wheel was a special order, and the $48 charge was not applicable to these special orders. I'd go with Rally's pieces.
My 2 cents.
markus is offline   Reply With Quote
Old 11-02-2003, 05:13 PM   #7
bigbear522
Member#: 21304
2002 Impreza WRX
I remember Spt_impreza was 15" and I wanted 16".
Correct me if I am wrong and myself being cheap but $90+ for steel rims are too much.
Old 11-02-2003, 07:03 PM   #8
fishbio
Member#: 43614
2004 WRX Wagon
Re: the $48 WRX rims at COSTCO I mentioned above. I bought a set last week here in Winnipeg. They had 2 sets in stock. If you don't see any, ask to see the wheel catalogue
Larry
Old 11-03-2003, 02:54 PM   #9
bigbear522
Member#: 21304
2002 Impreza WRX
Thank you I will do that. $48 is a much better price.
Old 11-03-2003, 11:39 PM   #10
WPGDarren
Member#: 32578
Hey Larry, which Costco sells rims -Regent or St. James? I thought they got out of rims due to errors on shipments and markings etc.
thanks,
Larry
WPGDarren is offline   Reply With Quote
Old 11-04-2003, 02:53 PM   #11
fishbio
Member#: 43614
2004 WRX Wagon
I got mine on St. James.
Larry
Old 11-17-2003, 12:21 PM   #12
thejean
Member#: 17763
Stick with the OEM steelies as they are hubcentric. You don't want to shear off your lugs...
thejean is offline   Reply With Quote
Old 11-17-2003, 12:33 PM   #13
MixeD_MenacE
Member#: 1274
MY00 BRP 2.5RSTi
www.zucru.ca
i have some universal steelies (16") that i got from subaru. they worked fine for me, although im getting rid of them soon. searching for a set of wrx stockers instead. i need a more narrow wheel base. my steel rims are 16x7 but i need a 6.5.
MixeD_MenacE is offline   Reply With Quote
Old 11-20-2003, 01:45 PM   #14
blarex
Member#: 44933
My local Costco has the Macpek steel 16 inch wheels at that nice price. What is the consensus on that? Is the offset reasonably close to stock WRX? Is it hubcentric, or will it shear off my lugs? Maybe if they're not perfect, no steel wheel is going to be perfect, and I really don't want to use my stock alloys, so I'll go with them anyways...
blarex is offline   Reply With Quote
Old 11-20-2003, 03:21 PM   #15
thejean
Member#: 17763
I think that the costco jobbies are 48mm offset. thats bad.
Old 11-21-2003, 10:10 AM   #16
damianq
Member#: 5380
1999 Impreza
Primer
IF you "order" the steel wheels in 16x6.5" for a WRX from costco, they WILL come w/ a 53mm offset. If you buy the ones off the rack, that's your decision. BTW 16x6 ET48 wheel (designed for German makes) will be completely w/in range as long as you don't get wide winter tires, which is not smart anyways. Going w/ a 195 width winter tire will still fit in the wheel well while pushing the track outwards which is better for lateral stability. They WILL be no rubbing issues, even on wagons.
For those buying 15" Steel wheels from costco, either a 6" wide w/ ET48 or 5.5" wide w/ ET56 is available. Best to use 195 & 185 width tires, respectively.
Steel wheels for 2006 wrx 2006subaru Tire & Wheel 1 05-05-2009 10:06 PM
16" steel wheels for 03 WRX? Mike Wevrick Tire & Wheel 4 06-27-2006 02:33 PM
WTB: 16" Steel Wheels for 02 WRX - Toronto Area markreda Canada Region Forum 3 11-02-2005 04:37 PM
15" Forester Steel wheels for sale - 3 wheels - no tires rao Mid West Subaru Owners Club Forum -- MWSOC 8 12-10-2001 03:44 PM
