Old 05-19-2001, 08:35 AM   #1
Star*Child
Member#: 5659
Question Stupid Oil Change Question
Okay, I'm an idiot
I decided to change the oil in my car (my very first oil change). Everything is going great (aside from half the oil missing the drain pan), until I'm putting on my new filter.
I dented the bottom edge of the filter in to create a dimple about 1/4" deep. It was enough to put a tiny crease where the edge of the dimple meets the undented area. I didn't notice this until I'd already filled it up with the new oil. *sigh*
It seems to be okay (nothing appears to be leaking...took it out for a drive and still no visible leakage), but I'm considering starting over again because I'm paranoid that I'll lose all my oil and have a bad thing happen.
I don't want to have to go buy 5 new quarts or Redline and a new Purolator filter, but it sure would be a lot cheaper than buying a new engine.
Anyone have any advice or experience in this matter?
Star*Child is offline   Reply With Quote
Old 05-19-2001, 08:44 AM   #2
BilboWRX
Member#: 6341
Post
You could try draining the oil into a nice clean catch pan and then reuse it. That way you'll only be down the price of the filter + about one quart of oil (whatever is in the old filter). This should give you piece of mind and shouldn't break the bank.
BilboWRX is offline   Reply With Quote
Old 05-19-2001, 08:52 AM   #3
Seeing StaRS
Member#: 5294
Post
^^^^^ Sounds like a good plan to me
Seeing StaRS is offline   Reply With Quote
Old 05-19-2001, 09:32 AM   #4
Star*Child
Member#: 5659
Post
*smacks my forehead*
BilboWRX, you are a genius! Thanks!
Old 05-19-2001, 09:34 AM   #5
inpreza kid
Member#: 3334
Post
can't you just change your filter with out draining all the oil? this way you only loose maybe half a quart of oil.
[This message has been edited by inpreza kid (edited May 19, 2001).]
inpreza kid is offline   Reply With Quote
Old 05-19-2001, 11:07 AM   #6
gavin
Member#: 3198
2005 GT LTD Wagon
Garnet Red
Post
Yes, the filter is above the level of the oil pan.
Just unscrew the filter, when the car is cold. You'll only lose the oil that's in the filter, and the bit that's in the engine.
gavin is offline   Reply With Quote
Old 05-19-2001, 01:03 PM   #7
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Post
A lot of people who use Redline oils, just remove/change the oil filter at 3,000 miles and top off the little oil that is missing. Then they send a sample of the oil in for testing. Once the test results reach a certain level, they will change the oil...
Revision is offline   Reply With Quote
Old 05-19-2001, 09:23 PM   #8
Star*Child
Member#: 5659
Talking
Great! That's even better (the filter being above the pan).
It still doesn't seem to be leaking, but it does seem to be "bleeding" a bit. I just picked up a new filter, so I'll swap it out tomorrow morning. Thank you all for the great advice. I'm going to try it without draining the entire thing first since I bought an extra quart anyways.
I love that I can come here, bask in my gross ignorance and not be ridiculed. Thanks again, everyone, for the help and suggestions!
Fujimoto oil drain valve and oil change questions ps99115 Newbies & FAQs 38 10-14-2005 08:14 AM
Another stupid oil temp question MKranz Factory 2.0L Turbo Powertrain 2 04-19-2002 11:26 PM
wrx oil change question inchoate Factory 2.0L Turbo Powertrain 3 07-03-2001 02:39 PM
Few oil change questions? Turk Normally Aspirated Powertrain 10 03-01-2001 12:50 AM
Oil change question... ImprezaRS2000 General Forum Archive 6 05-09-2000 08:06 PM
Message Board Statistics All times are GMT -4. The time now is 09:40 PM.
