Welcome to the North American Subaru Impreza Owners Club Saturday April 25, 2015
Old 11-03-2003, 03:39 PM   #1
xfactor834
Member#: 12506
Default guys...I need to learn C++...what's the best way to approach it???
I have some experience with highly old-school languages such as Pascal, but my job requirements will slowly force me to learn C++ within a year or so.
I know it's difficult to master it in a year, especially considering I'm gonna teach myself (which can be a disaster, I know).
What's the best way to approach it. There are tons of "learn C++ in 21 days" books on Amazon that all got great reviews, but most of them move too quickly.
Any thoughts or opinions?
xfactor834 is offline   Reply With Quote
Old 11-03-2003, 03:45 PM   #2
AC Lerok
Member#: 7918
2007 FSXT
Obsidian Black Pearl
do you have any object-oriented languages under your belt?
and when you say "learn" it, are you going to be a developer? tester? what exactly is your job?
AC Lerok is offline   Reply With Quote
Old 11-03-2003, 03:46 PM   #3
WHTWRX
Member#: 18571
2002 Impreza WRX
I've gotta quickly ramp up my C++ skills as well, I've not touched it since before the STL was added.
Will this be the first Object Oriented language you're going to learn? It's a steep learning curve, but just take a piece at a time. No one can expect you to know everything about it.
Get the fundamentals down: Encapsulation, Inheritance, Polymorphism, templates and exceptions.
Find a SMALL book to ease into it, something you can easily read in less than a week (spending say 2 hours a day on it).
Those "Learn C in 21 day" type books are also a good idea, they'll take a little longer to get through.
If you want to really jump in, get Stanley Lipman's C++ Primer 3rd edition. This is the bible most C++ developers have on their shelf.
WHTWRX is offline   Reply With Quote
Old 11-03-2003, 03:58 PM   #4
xfactor834
Member#: 12506
I have some limited knowledge of VB as far as object oriented languages.
I'm dabbling in .NET.
Old 11-03-2003, 04:05 PM   #5
Nyarlathotep
Member#: 41250
Seriously, force yourself to use it to complete a project. Something simple, build up from there. In my case it was a machine control application. But it can be as simple as a DLL. Get sample code from the net and do it!
Nyarlathotep is offline   Reply With Quote
Old 11-03-2003, 04:08 PM   #6
WHTWRX
Member#: 18571
2002 Impreza WRX
Try getting "Hello World" to compile and link first...
Old 11-03-2003, 04:09 PM   #7
Unit 91
Member#: 15810
2007 Mazda Fastar
2009 Legacy
Start at the beginning.
Unit 91 is offline   Reply With Quote
Old 11-03-2003, 04:10 PM   #8
WHTWRX
Member#: 18571
2002 Impreza WRX
And if something gets in your way...TURN!
Old 11-03-2003, 04:11 PM   #9
Unit 91
Member#: 15810
2007 Mazda Fastar
2009 Legacy
Do you have any idea what the street value of this mountain is?
Old 11-03-2003, 04:11 PM   #10
xfactor834
Member#: 12506
Sp ken like a true genius Ryan.
Old 11-03-2003, 04:18 PM   #11
Unit 91
Member#: 15810
2007 Mazda Fastar
2009 Legacy
It isn't easy being this smart.
Old 11-03-2003, 04:43 PM   #12
IM2dd
Member#: 33587
-Data Structure is important...then the syntaxes aren't that hard to pick up.
http://www.deitel.com/
good sites to check out...
http://www.codeguru.com/
http://www.codeproject.com/
good luck!
IM2dd is offline   Reply With Quote
Old 11-03-2003, 05:09 PM   #13
Zahnster
Member#: 2918
2002 Impreza WRX
Silver Sedan
C++ For Dummies isn't that bad of a book to get you started. (Perhaps I can manage to show up thursday if you wanna borrow/have it)
Herbert Schildt is pretty decent. Where I learned C++ originally (Teach Yourself C++ and C++ Programmers Reference, though his more recent stuff like C++ From the Ground Up might be better.)
I'm a big fan of things by O'Reilly and Wrox press so those are too good places to look. http://cprog.oreilly.com/
Zahnster is offline   Reply With Quote
Old 11-03-2003, 05:32 PM   #14
USA1
Member#: 33390
I started reading the "21 days" book, got a good start on it, and then took a class. One semester and I learned a bunch. The book really helped me get a head start and understand what the teacher was talking about (no previous programming skills, but I do have a bs in math). Ended up with an A in the class.
USA1 is offline   Reply With Quote
Old 11-03-2003, 05:51 PM   #15
Foovanadil
Member#: 23515
2011 Legacy GT
Steel Silver Metallic
VB isn't excatly a OOP languge. It's kind of half there in a bastard sort of way.
do you have any knowledge of Java?
C++ isn't hard to get the basics down, now mastering the lanuguge is quite diffcult if not impossible (I've been working with C++ for almost 6 years and I still wouldn't consider myself a master)
I would say first off read up on OOP (Object Oriented Programming) get a solid understading of that before jumping into anything else.
To master C++ (or any programming lanuguge) you really need to understand the concepts behind it. Not simply how do you do something but why is done that way.
a good programmer should be able to at least read and comprehend just about any languge.
By understanding the concepts of programming you will be able to implement an appllication in any lanuguge. Programming languges become simply a matter of syntax.
Foovanadil is offline   Reply With Quote
Old 11-03-2003, 07:23 PM   #16
andywrx
Member#: 10355
2008 Honda Element
Those "Learn C++ in 21 days/24 hours" are a good place to start.
After my freshman year, I only really learned C (kind of missed too
many C++ classes ) and had to pick up C++ pretty much on my
own.
The best thing I did though was take a hard class that required
C++ for its' programs. You may or may not need a class, but I
would highly suggest creating some sort of project (be it a stock
tracker, lottery number generator, address book, etc) to keep you
on track and to introduce you to problems you might encounter
when you program "for real". The books will teach you things like
arrays, syntax, STL, etc, but putting them to good use can be
another matter (there are some books that are geared toward
this line of things...one Java book I had, by the end of it, you had
your own stock tracker that would hit yahoo and look at stock
prices for you).
andywrx is offline   Reply With Quote
Old 11-03-2003, 07:29 PM   #17
George71
Member#: 5157
2005 WRX wagon
Just remember, classes are structs that own functions as well as data. That's all you need to know. Now paypal me $50 for the lesson.
George71 is offline   Reply With Quote
Old 11-03-2003, 07:35 PM   #18
FuzzyNips
Member#: 16686
2010 Mazda 3s GT 5dr
Black Mica
cout << "Newbie" << endl;
FuzzyNips is offline   Reply With Quote
Old 11-03-2003, 07:57 PM   #19
xfactor834
Member#: 12506
thanks for the help guys
Old 11-03-2003, 08:58 PM   #20
mordy_2v
Member#: 3381
2011 Sah nah tah
dark
so (classT *)var must be inheritence?
mordy_2v is offline   Reply With Quote
Old 11-03-2003, 10:41 PM   #21
WHTWRX
Member#: 18571
2002 Impreza WRX
function pointers own j00!!!
What's the best way to learn the Cyrillic alphabet? snvin Off-Topic 21 03-12-2009 04:51 PM
What's the best way to clean the engine compartment under the hood? rabbit92x Car Care & Detailing 4 11-27-2008 09:06 PM
what's the best way to train a dog to live in the backyard? skimmilk68 Off-Topic 99 11-07-2007 05:42 PM
What's the best way to get to Logan Airport? Red Rocket New England Impreza Club Forum -- NESIC 17 02-06-2003 12:57 PM
I got egged, what's the best way to clean it? Robmat Car Care & Detailing 4 04-28-2002 05:58 PM
