Welcome to the North American Subaru Impreza Owners Club Friday March 6, 2015
Old 11-03-2003, 05:33 PM   #1
Eggas
Member#: 43214
2003 Stage should
have bought a house
Default Best turbo for my needs?
I won't be going out to the track all the often 3/4 times a year so high top end really isn't important to me.. I am looking for a turbo that spools quickly and had some great mid-range punch.. I love 3rd gear.... Which one would be the best for me? Low price I was thinking about a port n polish from deadbolt on the stocker.. Mid was thinking bout the vf34 (seems to be everybody's fave) or the deadbolt Monster Td05 any ideasd on which would be best? Thanks
Eggas is offline   Reply With Quote
Old 11-03-2003, 05:39 PM   #2
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Seems like you have already answered your question. A VF-34 or a TD05-16G sounds like what you want. Get some engine management with it then get it tuned and you will have a great 3rd gear punch
cdvma is offline   Reply With Quote
Old 11-04-2003, 12:55 AM   #3
Eggas
Member#: 43214
2003 Stage should
have bought a house
Can you run an upgraded turbo/injectors/pump with upipipe/turbo back on a cobb ecu reflash? Or are theres only for turboback
Old 11-04-2003, 09:36 AM   #4
samwY
Member#: 31816
SR40 is for YOU!
samwY is offline   Reply With Quote
Old 11-04-2003, 12:12 PM   #5
Slvrblt
Member#: 4811
2014 Focus ST
NESIC track Ho #35
the TD05 would probably give you the most- not too much spool and some good power with some tuning. I'm not too sure about the VF- don't have much experience with them. I have the deadbolt TD04- I love it. gives spool, plenty of go, and a huge difference in 5th- I know, you said 3rd, but you get the idea
speed safely
Brian
Slvrblt is offline   Reply With Quote
Old 11-04-2003, 06:37 PM   #6
Eggas
Member#: 43214
2003 Stage should
have bought a house
specs on sr40?
Old 11-04-2003, 06:44 PM   #7
MustGoFast
Member#: 33370
2002 Impreza WRX
Blue now w/ 6 fun flavors
a bit bigger than the VF34 .. slightly slower spooling and 3 times as expensive.
MustGoFast is offline   Reply With Quote
Old 11-04-2003, 07:02 PM   #8
Vinnie
Member#: 7869
2011 STi
TheUrbanRallyProject.com
if you upgrade your turbo to one a little bigger than stock, is the injectors and pump the next thing to do? Are there any upgraded turbos that don't require upgrading the injectors, etc...?
Vinnie is offline   Reply With Quote
Old 11-04-2003, 07:44 PM   #9
mlambert
Member#: 13831
You can get by without upgrading the fuel system with just about any bolt on turbo as long as you pay attention to a/f and idc.
Just so youre aware, in stock form at stock boost levels, the stock turbo pushes idc's really high as is. Theres not much room for improvement after youve done all the usual bolt ons.
mlambert is offline   Reply With Quote
Old 11-05-2003, 12:50 AM   #10
Eggas
Member#: 43214
2003 Stage should
have bought a house
Not trying to be dumb here, but why would anybody buy one of those?
Old 11-05-2003, 01:38 AM   #11
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
more top end, more boost
try this
PE1414
*Boost 2500-2700 rpm stock
*Peak efficiency 17psi
*Max boost 26.5 psi
subiekid is offline   Reply With Quote
Old 11-05-2003, 12:15 PM   #12
modvp
Member#: 25215
I think a vf30/34 is a good choice.
modvp is offline   Reply With Quote
Old 11-05-2003, 12:39 PM   #13
camz911
Member#: 16041
'02 SCRAP METAL
ZERO whp.... :(
its really kind of hard to compare a vf34 with an SR40 ..... they're not even in the same class.
camz911 is offline   Reply With Quote
Old 11-05-2003, 03:20 PM   #14
glenihan
Member#: 23134
2002 impreza WRX
check out the VF 35 will give you tons of low end and mid
glenihan is offline   Reply With Quote
Old 11-05-2003, 03:55 PM   #15
big_adventure
Member#: 40501
2005 Decathalon 21sp
One WheelSeanPower
I would definitely recommend throwing on some new injectors and a fuel pump with any upgraded turbo. Mlambert is right, the stock setup already pushes the stock injectors over 90% at high MAF and revs. When my car was at stage 2, I would see 98-99% idc routinely at high revs in 4th.
If you stick with a vf30/34, you get a turbo that just about everyone knows very, very well. They're cheap, spool fast and make plenty of power for you at easily attainable revs, yet don't drop off at redline. I have a vf34, and on 91 octane, I'm at 16.5psi by ~3250, holding it all the way to redline, and on 98/100 octane, I'm at 21psi from ~3400 to redline.
A vf35 will spool sooner than a vf30/34, at the expense of high-end power. A vf35 is also more expensive.
-Sean
big_adventure is offline   Reply With Quote
What is the best turbo for my 02 WRX? 2$SPIFF Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 09-20-2006 07:16 PM
whats the best turbo for my aplication superdupersubaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 09-04-2005 02:03 AM
Best turbo for my aplication superdupersubaru Normally Aspirated with bolt-on Forced Induction Powertrain 1 09-01-2005 04:21 PM
What's best turbo for the my setup? wavshrdr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-11-2003 08:50 PM
The Best Turbo for my Needs???? MAX_Scooby Newbies & FAQs 9 11-18-2000 09:42 PM
