Old 11-03-2003, 05:47 PM   #1
blizzmn
Member#: 46564
1997 Legacy GT 2.5
Question Cold Interior, Takes Long time to warm up
I have a issue with my subaru that i havent had before with any other subaru i have owned, i live in MN and well its getting chilly out and this car i have takes forever to warm up and doesnt idle that high, so i dunno if the idle needs to be adjusted or if i need a new thermostat....just need some help, also i am getting about 23 mpg, and thats mainly highway miles any suggestions on how i can get my mpg higher?? when i first got the car it was higher then that, and now its going down hill. i have a 2.5 5 speed....thanks for any help provided
blizzmn is offline   Reply With Quote
Old 11-03-2003, 07:26 PM   #2
Dolphin Overton
Member#: 1925
01 A4 89 944s2
13 Speed 3R 99 Sprint
as far as mileage... have you checked your fuel filter, air filter, plugs, wires, etc.? I would check the fuel filter especially. I know nothing about heating though.
Dolphin Overton is offline   Reply With Quote
Old 11-03-2003, 07:33 PM   #3
blizzmn
Member#: 46564
1997 Legacy GT 2.5
yeah i have put in new plugs, and fuel filter and also a new air filter about 3000 miles ago, i have only 71,320 miles on this car it should be getting better just wondering if anyone had ideas
thanks
Old 11-03-2003, 10:49 PM   #4
m750
Member#: 2278
8Sti | 07 allez
White | Comp
it sounds like a potential symptom of Head gasket failure. I know the early dohc 2.5's were _very_ prone to this failure.
AO
m750 is offline   Reply With Quote
Old 11-03-2003, 11:19 PM   #5
blizzmn
Member#: 46564
1997 Legacy GT 2.5
bummer, i suppose i can look and see if there is a leak or if its sucking air.
thanks
how bout a remote start for a manual tranny anyone know of one?
Old 11-04-2003, 02:57 AM   #6
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
ull probably have to rig up a switch for that which i heard is illegal and my friend did it and forgot he left his car in gear smashed his car into his barn, bet he wont do that again
also, check to see if theres air in ur heater core , put ur car on a steep hill <front aimed up> open the radiator w/ it running and turn on the heater and put in fluid till its full if it isnt
Old 11-04-2003, 07:59 PM   #7
blizzmn
Member#: 46564
1997 Legacy GT 2.5
ok sounds good yeah i found a company that makes starters for manual transmissions so thats cool, well thanks for the help
ill check out my head gasket its prolly that i will also check the heater core
how long after you reset ECU,does it take for the sensors to warm up? chu my pu Engine Management & Tuning 8 03-08-2008 03:11 PM
Car cranks, takes long time to start? jay25RS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 05-02-2004 11:41 PM
How long to warm up? John C Texas Impreza Club Forum -- TXIC 1 12-03-2002 01:37 PM
is it my car, or does the wrx seem to take a long time to warm up? wrxxtc Newbies & FAQs 16 11-13-2001 03:35 PM
Those w/ oil temp gauges: how long to warm up? Fubaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-11-2001 03:04 PM
