Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC
Old 11-03-2003, 06:03 PM   #1
NegativeC
Member#: 40297
2004 WRX Sport Wagon
Platinum Silver Metallic
Question Lowered car bad in winter?
Thought, I'd ask you f00ls since you all know about the mid-west winters. How do your dropped cars fair in the snow and slush? Better/Worse that stock? Granted it's only like an inch or 2 but does the stiff suspension hurt snow traction? Thanks for any input.
NegativeC is offline   Reply With Quote
Old 11-03-2003, 06:30 PM   #2
A_Train
Member#: 34171
2007 G35S 6MT
2008 ML550
With the right winter or all season tires it shouldn't be a problem. Some cars just react a little faster with a tighter suspension
A_Train is offline   Reply With Quote
Old 11-03-2003, 06:38 PM   #3
Got Groceries?
Member#: 25323
2003 WRX Wagon
My wagon did just fine last winter with Prodrive springs on RE92's. Granted, not aggressively dropped, but enough to matter. Coincidentally we had one of the snowiest (4-6" deep 3-5 times) winters in recent memory last year. Never had a problem but I stayed out of anything piled up by the plows. I'd think if the plows take care of the bulk of the snow around you, everything should be fine. Traction will be fine assuming good tires.
Got Groceries? is offline   Reply With Quote
Old 11-03-2003, 07:05 PM   #4
Section 8
Member#: 821
Tires are the biggst problem. I f you have legitimate tires for foul weather you will be fine. The only time that the stiffer suspention comes into play is on "wavy" or "uneven" pavement, I hesitate to say bumpy because the bumps are not a problem, its the lifting of tires that can get you in trouble. Most suspentions still have enough travel to keep them on the ground in any case. Of course AWD (3wd) can make up for deficiencies from uneven traction better than 2wd (or 1 wd)
Stiff rear swaybars are more of a concern then stiff springs are. Unless you run ~400lb in springs or more.
cheeRS,
Greg
Section 8 is offline   Reply With Quote
Old 11-03-2003, 07:06 PM   #5
WRX02WRB
Member#: 36240
2015 STi
mine was a little more willing to slide but other than that i didnt have many problems (allmost a 2in drop) now this year might be a diff. story my poor Re-92's are shot
WRX02WRB is offline   Reply With Quote
Old 11-03-2003, 07:07 PM   #6
kenchan
Member#: 15106
my wrx wont clear the autowash places so i dont drive it
in the snow. if you got a v1 or v2 lip, dont lower it
too much. i could raise it cause it's on tein's but too lazy.
performance wise, i think the factory soft springs work
better in the snow unless you got some snow tires.
i use s03s all year round (dry roads only in the winter).
kenchan is offline   Reply With Quote
Old 11-03-2003, 07:22 PM   #7
Section 8
Member#: 821
My car was sketchy on the tared and graveled road surfaces (the kind that are never flat after they resurface it once, by slpooing tar all over and dumping truck after truck of gravel on them) when it was wet ouside on Tein HA's and a 22mm rear sway bar. Fresh blacktop was worse, with cement being actually not to bad. I ddin't even try them in the snow.
Greg
Old 11-03-2003, 07:50 PM   #8
kenchan
Member#: 15106
yah, u need to get the right tires.
Old 11-04-2003, 07:07 AM   #9
itWoRX
Member#: 21305
2002 WRX Sport Wagon
WR blue
Da-ude!, you still running them?
My god, you got mega miles out of them, aye??
itWoRX is offline   Reply With Quote
Old 11-04-2003, 11:53 AM   #10
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
It's a good opportunity to make some extra cash snowplowing. If you have a fiberglas bumper or lip you may be in for some trouble.
Tim Sanderson is offline   Reply With Quote
Car.. almost in winter mode. slowguy Vancouver Impreza Club Forum -- VIC 50 11-05-2009 12:05 AM
any secrets to keeping car clean in winter 07blksti Alaskan Impreza Club Forum -- AKIC 27 01-08-2008 03:26 PM
Lowered cars in the winter linux>windows Mid West Subaru Owners Club Forum -- MWSOC 15 10-06-2005 10:03 PM
Lowered cars in winter? NegativeC Brakes, Steering & Suspension 4 09-17-2003 02:54 PM
Spotted at Exotic Car Show in Winter Park 10/20 Subi Chicky South East Region Forum 0 10-21-2002 08:02 AM
