Old 11-03-2003, 11:59 PM   #1
ImportVenom
Member#: 34204
2004 WRX
WR Blue
Default How to remove the oil drain plug at the very end (before it drops)
Hey all,
I have a simple question. I use a 17 mm socket to loosen the oil drain plug on my wrx, but how should I get the plug off at the very end (right before it falls out). Last time I used my hands to loosen it real fast, but got some oil on me as it came off. What do you all do?
ImportVenom is offline   Reply With Quote
Old 11-04-2003, 01:12 AM   #2
cnk
Member#: 10757
2013 BRZ Limited 6MT
You can press in on the bolt and keep unscrewing it. When you feel that it's all the way out, I usually just pull the bolt away and up really quickly. That is usually good enough to not get oil all over my hands.
Calvin
cnk is offline   Reply With Quote
Old 11-04-2003, 02:54 AM   #3
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
quick hands
Old 11-04-2003, 04:42 AM   #4
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Learn to enjoy the soothing feeling of hot oil on your skin!
Seriously, though, cnk is right. I do use one of those dishwashing rubber gloves on my hand to protect it -- it's also handy for keeping oil off my hand when unscrewing the filter.
Old 11-04-2003, 08:41 AM   #5
leecea
Member#: 37359
2003 WRX
I use a socket and long extension, which I just turn by hand. My drain pan has a grid over the opening in case the bolt falls.
leecea is offline   Reply With Quote
Old 11-04-2003, 10:06 AM   #6
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Put a plastic shopping bag over your hand . I do the same thing for the oil filer .
Brian
Old 11-04-2003, 01:44 PM   #7
Stanley
Member#: 7374
2007 Grandpamobile
BlingBlingBlue
I wear plastic gloves and push the drain plug towards the pan as I am loosening it.
Stanley is offline   Reply With Quote
Old 11-04-2003, 09:45 PM   #8
ShotgunTC88
Member#: 30970
Ok, Thats it guys!!!
I am coming to get your cars..............................
j/k
Shotgun
(Greasemonkey)
ShotgunTC88 is offline   Reply With Quote
Old 11-04-2003, 10:00 PM   #9
ImportVenom
Member#: 34204
2004 WRX
WR Blue
Brian
Good idea! Now I don't have to buy rubber gloves. I guess I'll follow everyone's advise and push in towards the bolt, while having my hand protected by a plastic bag, and try to remove the bolt with lightning quick speed so I won't burn myself...thanks
Old 11-05-2003, 01:50 AM   #10
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
rubber gloves are still better IMHO
Old 11-05-2003, 10:38 AM   #11
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Get a Fumoto valve and heave your drain plug into the trash. I can change my oil in a tuxedo now.
Old 11-05-2003, 11:05 AM   #12
Hawk296
Member#: 14555
1995 Impreza L
Baja
as stated, loosen, unscrew by hand, as you do apply pressure inward toward the oil pan to prevent the oil from starting to drip, then once its all the way unthreaded, superquick pull it out, I can do it without getting a drop of oil anywehre but the drain pan. Filter i lossen and let drain and graba shop rag and pull off the oil covered filter, toss the rag in the bin and my hands are still clean.
Hawk296 is online now   Reply With Quote
Old 11-06-2003, 12:21 AM   #13
Mapplex
Member#: 20315
1997 Impreza L
hunter green
Loosen the bolt as much as you can. Then take a short piece of string and tie it around the threads of the bolt. Wrap the string a few times around the bolt in a counter-clockwise fashion and then pull. The bolt will come free and will be dangling on the string (not at the bottom of your oil container) and your hands will be perfectly clean. I take full credit for this one.
Now if only there was clean way to do the oil filter....
Mapplex is offline   Reply With Quote
Old 11-06-2003, 12:38 AM   #14
singletrack
Member#: 42440
04 Impreza WRX STi
Platinum Silver
I use Nitrile gloves.
-st
singletrack is offline   Reply With Quote
Old 11-06-2003, 08:39 AM   #15
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Get one of those telescoping magnets to take it out the final couple threads and viola! you don't get oily.
I hav'nt tried this but since you asked for ideas I thought I'd put my thinking cap on.
Tim Sanderson is offline   Reply With Quote
Old 11-06-2003, 10:24 AM   #16
Nok's WRX
Member#: 25797
2002 PSM - Stock
Smile
Use one those strainers they have for cooking or wire mesh on top of your pan or just fish it out after you pour the oil in a container....
noksie
Nok's WRX is offline   Reply With Quote
Old 11-06-2003, 10:24 AM   #17
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Get a nail and hammer. Tap a hole or three into the bottom of the filter and let drain. If you drain pan is big enough, you can do this at the same time as the oil is draining. Wait 5-10 minutes. Unscrew your filter for mess free results!
Old 11-06-2003, 06:36 PM   #18
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
Another vote for this - but I don't know if I'd do it in my tuxedo though
Hank3 is offline   Reply With Quote
Old 11-07-2003, 02:51 PM   #19
Rojorex
Member#: 19687
'02 WRB WRX
Non-sedan
Another plug for the Fumoto valve!!!
Rojorex is offline   Reply With Quote
Old 11-07-2003, 04:04 PM   #20
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
Cut a piece of garden hose about 3-5 inches long and then slit it down one side for about one inch. When the plug is almost completely unscrewed, put the end with the slit over the plug and just unscrew it using the hose. Your hand should be out of the oils way and the drain plug should still be stuck in the hose. Of course, this does depend on the size of the hose.
Old 11-09-2003, 11:49 PM   #21
wrx-boy
Member#: 43662
2005 STi
CGM
anyone know where to get a Fumoto Valve and for how much $$$? Just curious....looks amazing!
wrx-boy is offline   Reply With Quote
Old 11-11-2003, 01:28 AM   #22
file_id
Member#: 28197
2003 WRX w/ VF34
Fumoto valves are $20
file_id is offline   Reply With Quote
Old 11-12-2003, 09:24 PM   #23
Neek
Member#: 3400
2016 Red Pirate Cat
1981 CJ-7
Originally posted by HndaTch627
quick hands
Neek is offline   Reply With Quote
How to Remove Turbo Oil Drain Tube on Head? SEEC Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 01-01-2016 08:12 AM
how do you guys remove the oil drain tube on the head? ownnij Built Motor Discussion 14 12-10-2009 10:07 PM
Rear differential oil fill and drain bolts, same size as the oil drain plug? scooterforever Transmission (AT/MT) & Driveline 4 01-24-2005 06:06 PM
Good god! What did you guys do to get the oil drain plug off the first time? DVN428 Newbies & FAQs 27 05-02-2003 03:24 PM
ANybody know how to get a oil drain pan bolt out when it is stuck? Jasno999 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 09-28-2002 01:08 AM
