Old 11-04-2003, 08:17 AM   #1
tomoking
Member#: 36130
Default piston slap after i changed pistons to arias forfed pistons
My engine has piston slap after i changed pistons to arias forged pistons. I can hear slap when engine is cold and when is hot . What i have to do for repair slap ??? should i bore/hone the cylinders to bigger diameter or opisit i should get oversized pistons ??? sorry for my english
tomoking is offline   Reply With Quote
Old 11-04-2003, 10:07 AM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
You don't want to bore the cylinders to cure piston slap- you need a piston with a longer skirt on it .
Brian
Old 11-04-2003, 10:14 AM   #3
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
Aren't some (all?) Sube pistons marked for orientation due to wrist pin being slightly off center? Maybe that's the older engines but what would happen if he installed them 'upside down'?
Carl
1 Lucky Texan
1 Lucky Texan is offline   Reply With Quote
Old 11-04-2003, 10:54 AM   #4
tomoking
Member#: 36130
Carl
1 Lucky Texan
i have wrx 2002
EJ 20 engine
stock piston have mark for right orientation
arias forged piston do not have mark for right orientation because pin bore is precisely in middle of skirt
arias skirt is longer then stock
Old 11-05-2003, 08:28 AM   #5
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
At the very least I think you should get a refund on the new pistons. The reason the stocks have a slightly offset wrist pin is to reduce piston slap! I do agree a longer/different skirt design might do the same. However this all points to the same conclusion. Your new pistons are poorly designed for your application.
Carl
1 Lucky Texan
Old 11-05-2003, 09:36 AM   #6
tomoking
Member#: 36130
Carl
1 Lucky Texan
Why ariaspistons.com produced bad pistons for EJ 20 ?
they wrote
ARIAS PISTONS, the leader in sport compact pistons, now offers Subaru WRX piston kits for the EJ20 engine. Forged from high-tensile billet aluminum, ARIAS PISTONS feature fully machined external features for maximum strength and minimum weight. Designed for extreme street or race, turbo or nitrous applications. These shelf-stock kits come complete with 8.5:1 compression ratio .50 mm oversize pistons, case-hardened wrist pins, severe-duty rings and pin locks
Old 11-05-2003, 11:57 AM   #7
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
Well, perhaps they are not poorly designed. Still, they could be undersized or have some other defect.
How long was your engine open during the work? Maybe there is some other source of the noise? TB tensioners can be noisy, lifters,etc. If you engine was inoperable for a while the oil could have gotten gummy or something.
hope you get it sorted out.
Carl
1 Lucky Texan
Old 11-05-2003, 02:28 PM   #8
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
tomoking, do a site search here
http://www.northursalia.com/m...ns/index1.html
for engine noise.
good luck
Carl
1 Lucky Texan
Old 11-05-2003, 09:46 PM   #9
aj's25rs
Member#: 30160
9900 2.5rs
rbp,srp
when my friend put those pistons in his honda it sounded loud also. sounded like piston slap but it was due to them being lighter and forged. anyway he had no problem with them.maybe that will help
aj's25rs is offline   Reply With Quote
Old 11-06-2003, 08:48 AM   #10
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
How many miles did you have on your engine when you changed pistons? Did you mic. the bores? Sounds to me like you have too much piston to wall clearance. There should be no more than .004 clearance.
I doubt you would be able to get a refund.
Tim Sanderson is offline   Reply With Quote
EJ257 STi ARIAS forged pistons 100mm XS_WRX Engine/Power/Exhaust 3 12-17-2014 08:55 PM
Arias forged pistons leondal Private 'For Sale' Classifieds 0 01-21-2004 02:59 PM
Arias forged pistons leondal Private 'For Sale' Classifieds 2 01-10-2004 04:57 PM
Forged Pistons and Rods JE Arias Eagle dynoflo Vendor 'For Sale' Classifieds 31 11-22-2003 03:19 AM
Arias Forged Pistons Ej20 Ej25 $475 dynoflo Vendor 'For Sale' Classifieds 7 08-08-2003 10:30 AM
