Closed Thread
Old 03-17-2004, 09:16 PM   #251
ami2fst4u
Member#: 40638
'04 PSM STi
Has some work done... ;)
Default Re: TE-37 MERCURY SILVER
Originally posted by DangerousWRX
245/40 17
I would stick with the 245's as they are perfect for an 8.5" wheel, however you might be able to fit 255's bit you may run into clearance problems. Lasty, congrats on the purchase they will look sweet .
Rick
ami2fst4u is offline
Old 03-17-2004, 09:39 PM   #252
bgbyztoy
Member#: 49437
04 wrb STI
PE1820 turbo [email protected]
adam or rick
i also ordered volks ce28n 18x8.5 +44 offset. i'm also drop with tein s tech springs. whats the widest tire i can use without rubbing.
225/40/18
235/40/18 or
245/40/18
any help would be great
bgbyztoy is offline
Old 03-17-2004, 09:53 PM   #253
ami2fst4u
Member#: 40638
'04 PSM STi
bgbyztoy, I again would try to go for a 245. Yet to keep the overall same tire size as stock (sidewall width, and overall tire radius) I would run a 245/35/18, so that you will only be really altering the width. Congrats on the CE28N's .
Rick
Old 03-17-2004, 10:30 PM   #254
bgbyztoy
Member#: 49437
04 wrb STI
thanks for the quick response rick
one last question sorry to ask
will it be ok if used 235/40/18 without rubbing i am currently drop with tein s tech springs its about 2 fingers gap in the front and alittle less than 2 fingers in the rear.. im really confused right now cause people give me different opinions.. some say stick with 225/40/18 so this way i wont rub but it seems small for an 18x8.5 rim and others say i'll be fine with 235/40/18 without rubbing or should i stick with 245/35/18 i'm scared on running with wider tires due to rubbing issues so right now im really confused which set up will be good for me.. but anyways any help would be great.. thanks again
bgbyztoy is offline
Old 03-17-2004, 11:52 PM   #255
DangerousWRX
Member#: 8459
2004 STi
Thumbs up thank you!
They say it will be around 3 months for them to get here, but what the hell. I got a raise this year and guess what, it just went under my car.
DangerousWRX is offline
Old 03-18-2004, 06:58 AM   #256
SLKWrx
Member#: 8247
2004 STi JBP
1973 914
Bgbyztoy,
I am currently running an 18x8.5 w/ 235/40-18's and lowered on pink's. There is no rubbing at all, but the 235's don't exactly hang over the rim at all. If you are looking for all season tires, you won't find a 245/35-18, but there are a few in summer tires. I'll have to go out and check again, I know that from the tire to the strut body assembly there is at least 1/2" if not more, I couldn't see back there, that is just from feel. I'm not 100% on how much room I have left to the fenders, but I think a 245 would fit. Definitely do not go with a 225, it will be very narrow on a 8.5" wheel.
Hope it helps
-- Steve
SLKWrx is offline
Old 03-18-2004, 07:09 AM   #257
Z1 Performance
Member#: 9327
I too woulod go 245 -235 is bound to give more lip ezposure for potential damage.
Some tires ahve really good designs to further prevent this - T1S's and P Zero's come to mind
Adam
Z1 Performance is offline
Old 03-18-2004, 01:35 PM   #258
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
ami2fst4u,
This is a great thread! Thanks for all the hard work. I got tired of looking for the pics everytime I forgot what each rim looked like so I put together this page to go along with the thread. I am mostly through the 17's and 18's and I will finish and try to keep it updated with this thread. I hope this helps some people out.
PICS OF WHEELS THAT FIT THE STI
http://www.geocities.com/crystalhelix/STiRims.html
Thanks,
Justin
crystalhelix is offline
Old 03-18-2004, 01:43 PM   #259
ami2fst4u
Member#: 40638
'04 PSM STi
Justin,
You beat me to it, I am almost done with my complete site. Been working on it for a while now, it will have all the info as you have listed and then some .
Rick
Old 03-18-2004, 01:49 PM   #260
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
Sweet. I didn't want to spend too much time so I am looking forward to checking out your site.
Justin
Old 03-18-2004, 02:29 PM   #261
Mr Impreza swe
Member#: 43391
2002 Impreza WRX STI
Nice work.
Mr Impreza swe is offline
Old 03-18-2004, 03:24 PM   #262
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
Does anyone know anything about the fitment of :
Gram Lights or Work wheels?
I just found these rims on www.gruppe-s.com, states that they clear Brembo calipers
Gram Lights 57F 17x8.5 ET-45
Work Emotion CR 17x8.0 47
Work Emotion CR 18x7.5 42
Work Meister S1 3 Piece 18x7.5 49
Work Rezax II 17x7.5 53
Work Rezax II 18x7.5 53
Work VS-XX 17x7.5 53
Work VS-XX 18x7.5 53
Work XSA 02C 18x8.0 37
This would be a good addition to the thread.
Justin
Old 03-21-2004, 12:47 AM   #263
Kharne
Member#: 24726
2006 Tacoma
Originally posted by Z1 Performance
Kharne - For GTN proper size is 18x8 +42
Thanks.
Just curious, but gruppe-s told me +44. And several other pages say 18x7.5 +37.
link for STi wheels
Is +42 the best fitment?
Kharne is offline
Old 03-21-2004, 11:48 AM   #264
ami2fst4u
Member#: 40638
'04 PSM STi
Originally posted by Kharne
Thanks.
link for STi wheels
The only wheel that I know fits is the 18x7.5_ET37, however in a 8" width the offset will be different. The site you just mentioned is really just a mirror of the list I started so we both have the same info (thanks Justin ). Not sure where you got your info off of Gruppe-S but they don't even list a fitment for the GT-N on Gruppe-S.
Back on topic after viewing Rays website it seems as though the GT-N will fit in either a 18x8_ET37 and 18x8_ET42 (just depends on how deep you want the lip to be 50mm or 44mm respectively). Here is the link, look under Offset A (being it is for Brembo's) Rayswheels GT-N
Hope this helps,
Rick
p.s. Please look at the first page I am in need of pictures of aftermarket wheels on STi's, as it is the last aspect of the website I am working on for you guys. It will make it alot easier to view all the specs and pictures.
Old 03-21-2004, 08:47 PM   #265
ami2fst4u
Member#: 40638
'04 PSM STi
TTT....
Rick
Old 03-22-2004, 06:45 PM   #266
ami2fst4u
Member#: 40638
'04 PSM STi
Please look at the first page, I would like to get this site complete for all you to view.
Rick
Old 04-04-2004, 08:58 PM   #267
wm07
Member#: 26529
04 STi
5Zigen FN01RC = 17x8_ET35__(16.5 lbs)... (Z1 Performance)
-35 offset? isn't it will put a lot of stress on wheel bearings? any pics?
wm07 is offline
Old 04-04-2004, 09:13 PM   #268
Z1 Performance
Member#: 9327
no it would not.
There is no "right or wrong" offset for a car - there is right and wrong relative to a certain wheel. Width and offset go hand in hand, as those 2 factors affect where the weight is centered on the wheel. Now this is a relative point of course - some wheels might "fit", but would look downright awful on the car or could necessitate rolling, etc.
As for the wheel bearing issue, it's honestly not related to the wheels people are using. there are countless people with wheels in high ofsets (+50 and up), who also had wheel bearing issues - it's just another example of a not-great-out-of-the-box-part from Subaru, not a case of wheel choice.
FWIW, I have had 3 Subaru's, which wore a some total of 8 sets of wheels. Some I bought new, others were high mileage when i got them (Legacy Turbo had 165k, Legacy 2.5 GT had around the same). My Impreza was purchased new and sold after around 45k HARD miles (those who know me know the car). I have never had to replace a set of wheel bearings on any of these cars......
Adam
Old 04-04-2004, 11:47 PM   #269
wm07
Member#: 26529
04 STi
So, with +35, which means it shifted 18mm outside compare to our stockers(+53), then add another quarter of an inch (half of 1/2", ~6mm) from the wider wheel, so we have a total of 24mm out compare to stock. It's almost an inch!
The reason I asked is because I am looking for wheels so that I could mount some 245s. This 17x8, +35 offset sounds perfect. It will move the wheel out and I do not have to worry about the tires rubbing the suspensions, especially the rear, but will it rub against the fender?
If there is a picture showing this offset on a subie, that would be nice. It would look bad a$$ too!
Thanks Adam!
wm07 is offline
Old 04-04-2004, 11:56 PM   #270
Z1 Performance
Member#: 9327
I'll see what I can do about getting you a pic ASAP!
Old 04-05-2004, 12:14 AM   #271
RaceComp Engineering
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
RaceComp Engineering is offline
Old 04-09-2004, 02:36 PM   #272
horshack
Member#: 19236
Axis GT35/40R STi
Not back yet
Hey Rick,
I am looking into a set of Buddy Club Racing wheels.
Will keep you updated as to specs and such.
horshack is offline
Old 04-13-2004, 01:55 AM   #273
JDiesel
Member#: 34557
2004 Impreza WRX STi
Default Add STi Stock BBS Wheel Weight To Front Page
ami2fst4u, I think it would be helpful to everyone if you added how much the stock BBS wheels weigh to the front page. I found this link...
http://forums.nasioc.com/forums/show...ght=BBS+weight
Keep up the great work!
JDiesel
JDiesel is offline
Old 04-13-2004, 11:42 AM   #274
RoyBoy016
Member#: 44621
2002 RSX Type-S
Is there anyway that a SE37K would fit an STI in 18's?
RoyBoy016 is offline
Old 04-15-2004, 01:36 PM   #275
byroll01
Member#: 611
'05 E55 AMG
GetADomTune.com
Well, add another to the list. I finally got my 18x8.5 +42 G-Games Wolf 77 w/VAIO (2 piece). The only problem is that Vivid threw 225/40 Kuhmo supras on instead of 235/40 Kuhmo MX's. it will be fixed shortly.
Here are the pics in the meantime.
in that last pic you can tell how the 225 gets skinnier towards the top and fatter near the rim. I know the 235 will do that a little too and be the wrong rolling diameter but I too would like to not rub and not roll fenders.
byroll01 is offline
Closed Thread
Wheels that fit the 2.5i and the best offset. VIsubi Tire & Wheel 2 06-23-2010 09:19 PM
When the hell is prodrive going to make wheels that fit the 05 STI PARAMEDIC Tire & Wheel 2 01-09-2005 01:20 PM
Wheels that fit the 05 STI nhluhr Tire & Wheel 21 06-25-2004 01:46 PM
Need 17x7.5 wheels that fit the STi boxerT Private 'Wanted' Classifieds 5 02-17-2004 03:11 PM
Unknown wheels that fit the STi Neil Wallerstein Tire & Wheel 6 11-04-2003 12:51 PM
