Closed Thread
Old 12-18-2003, 11:15 AM   #101
garlo
Member#: 39296
2004 WRX STi
Heres a relatively fast way to check to see if the spokes of a wheel will clear the Brembos. I did measurements off of my car and found out the Brembo caliper sticks out 34mm past the hub (the point where the wheel mounts) on the front wheel of the Sti. Then I pulled off the BBS and measured on the inside of the wheel the distance from surface where the wheel mounts to the hub and the backside of the spokes (40mm 41mm). This gives the stock BBS wheel a clearance of around 6mm between the front of the calipers and the back of the spokes on the front wheel. Now given the curve of the spoke may vary wheel-to-wheel this measurement may not work in all cases, but should be a good general fitment indicator. I unfortunately did not measure from the center of the hub to the point where the spoke on the BBS wheel starts to curve. On the stock BBS wheel after the initial bend coming from the hub the spoke is relatively straight to the inside edge of the wheel.
Anyway, before doing the dry fit on the Racing Sparco Tarmac I measured the distance on the inside of the wheel from the surface where the wheel mounts to the hub to the back of the spokes (39mm 40mm). After mounting the wheel on the car I measured from the front of the caliper to the back of the spoke (3mm 4mm). Brembos site mentions a minimum of 3mm clearance. All the measurements were taken in a confined space, no not a prison, in my one car garage, so they may be off slightly +/- 1mm.
So, to get a fair idea if a wheel will fit. Pull the wheel, get a flat object to lay across the mounting surface on the inside of the wheel (I used a 12 drafting triangle) then with a mm ruler measure various points from the back of a spoke to the edge of the object or triangle. I took measurements from the inside edge of the wheel to the point where the spoke starts to curve. If your measurements are >= 40mm Id say you have a good chance that the wheel will fit on a STi.
If you are interested here are the measurements I took from my Sti that I had posted on another site. I thought about making a template like the one on the StopTech site and then posting it, but now that I have my wheels I have gotten lazy. These measurements where taken outside in good lighting, so they should be accurate.
Here are the measurements I got:
- The length of caliper (tip to tip): 280mm
- The width of caliper (front to back): 138mm
- The distance from the rotor to the front of the caliper: 57mm
- The distance from the hub face to the front of the caliper: 34mm
(The point where the wheel touches the hub)
- The distance on the inside of the wheel from where it mounts to the inside edge of the spokes.
(Just after the point where the spoke curves): 41mm
(The inside edge of the wheel to the spoke): 40mm
- Clearance from the spoke to the caliper: 6mm
(Measured from the center of the second b in brembo to the spoke).
I used a micrometer to do the measurements except when measuring the size of the caliper.
Gary
garlo is offline
Old 12-19-2003, 11:01 PM   #102
philw007
Member#: 34326
2004 WRX STI
Good job Gary! Maybe we'll be finding more wheels that fit the sti this way!
philw007 is offline
Old 12-26-2003, 12:51 PM   #103
NORCAL STI
Member#: 48911
will 18x8 volk gt-n (see them on a sti already) but in a 48 mm offset and 245 40 18 work?
NORCAL STI is offline
Old 01-02-2004, 09:42 AM   #104
garlo
Member#: 39296
2004 WRX STi
Here are some photos of my STI with the 17x7 +48 Racing Sparco Tarmacs and Bridgestone 225/45-17 LM22 tires. No spacers needed for brake clearance. They do need hub rings, which came with the wheels.
garlo is offline
Old 01-02-2004, 09:47 AM   #105
garlo
Member#: 39296
2004 WRX STi
Photo #2
garlo is offline
Old 01-02-2004, 09:49 AM   #106
garlo
Member#: 39296
2004 WRX STi
Closeup of front wheel showing brake clearance (3-4mm).
garlo is offline
Old 01-02-2004, 10:16 AM   #107
horshack
Member#: 19236
Axis GT35/40R STi
Not back yet
Hey ami2fst4u
Thanks for posting this!
I have been doing research over the past 72 hours trying to complie a list, size, fittment and weight being the most pressing issues!
horshack is offline
Old 01-02-2004, 08:00 PM   #108
ami2fst4u
Member#: 40638
'04 PSM STi
Has some work done... ;)
NORCAL STI, I am awaiting a reply to my PM that I have sent to PHAST M3 (he has a set of GT-N's on his STi). Immediately after I get a reply I will update you everyone on the info I have received.
garlo, the Racing Sparco Torino's have been added to the list, thanks for posting pics and geting me the specs. Would you happen to know the weight off hand?
Originally posted by horshack
Hey ami2fst4u
horrshack, no problem, the first initial list took more than a week to compile and have been adding ever since. I too have been pressing to find weights for each wheel. If you have found any other wheels that you know fit please post them and I will then add them to the list I currently have going.
Again, thanks to everyone that has contributed to helping me compile this list .
Rick
ami2fst4u is offline
Old 01-02-2004, 09:38 PM   #109
garlo
Member#: 39296
2004 WRX STi
Rick,
The weight on the Racing Sparco Tarmacs in 17x7 is 20.5 lbs.
Gary
garlo is offline
Old 01-02-2004, 09:40 PM   #110
ami2fst4u
Member#: 40638
'04 PSM STi
Rick,
Gary
Gary, thanks again..... list updated
Rick
Old 01-04-2004, 07:41 AM   #111
Mr Impreza swe
Member#: 43391
2002 Impreza WRX STI
Do anyone know if OZ Superleggera 17"x7" OFFSET 48 works on the STI?
Mr Impreza swe is offline
Old 01-04-2004, 10:32 AM   #112
ami2fst4u
Member#: 40638
'04 PSM STi
Sorry to say but they will not fit, from what I have heard the 19" SuperLeggera is the smallest size that will fit over the Brembo's as of now .
Rick
Old 01-06-2004, 10:38 AM   #113
BlueSwedeSTi
Member#: 50487
Can someone confirm these??
Volk TE37 18x7.5 +43
BlueSwedeSTi is offline
Old 01-06-2004, 03:15 PM   #114
garlo
Member#: 39296
2004 WRX STi
I can't verify if the TE37 exists in a 18x7.5 +43. I couldn't find them on the Rays site. I can verify the 18x7.5 +48 do exist and DO NOT fit. Sorry, I've tried twice to post the link to the www.i-Club.com site but it didn't work. It's in the Tires & Wheels forum. A guy there (midnightwrx) tried them in the 18x7.5 +48 and they wouldn't work without a 7mm spacer.
Rick, unfortunately another wheel to remove from the list.
Gary
garlo is offline
Old 01-06-2004, 04:49 PM   #115
ami2fst4u
Member#: 40638
'04 PSM STi
Gary,
I actually got the info for the fitment of the Volk TE37's in 18x7.5_ET43 (17 lbs) from Tim @ ImportHookup. Here is the link (I also contacted via PM to confirm): TE37 fitment.... but like you said I too can't find the specs on Rays website . I will take it off the list just to be safe, if they do exist and fit I can always add them later.
Rick
p.s. If anyone finds any other issues let me know, I then will update accordingly.
Old 01-07-2004, 12:14 AM   #116
ami2fst4u
Member#: 40638
'04 PSM STi
As I was browsing on Gruppe-S today, I happened to notice it looks as though they took the list I have compiled and incorporated it into there website in the exact same format I made.... Wheel fitment.... obviously only listed the wheel makers they carry. Nevertheless it's nice to see a commercial company is using the info I posted here on NASIOC for there site without even being mentioned or credited (just would have been nice for the time I put in making the list).
Sorry for the rant,
Rick
Old 01-07-2004, 11:58 AM   #117
garlo
Member#: 39296
2004 WRX STi
Rick,
We know who gets the credit. Good job!
Speaking of getting the credit. Mach5WRX over on the i-Club site redirected me back to the Rays site and a much cleaner fitment table then the one I saw. I did a little looking around and noticed they list the Volk SE37K 17x8.5 +50 as fitting the "Brembo caliper of Impreza (GDB)".
http://rayswheels.co.jp/cgi-bin/cgi/...odelName=SE37K
So, you take one off the list, but get to add a new one!
Gary
garlo is offline
Old 01-07-2004, 12:14 PM   #118
ami2fst4u
Member#: 40638
'04 PSM STi
Gary,
Thanks for the props, as well as all your help on making this list longer . I have now added the Volk SE37K = 17x8.5_ET50. Hopefully we will see more wheels come available in the future.
Rick
Old 01-07-2004, 03:29 PM   #119
ami2fst4u
Member#: 40638
'04 PSM STi
Not to add to the fire, but a memebr just informed me that Mauromotorsports is using the list I compiled also..... (again not mentioned or creditied).
Sorry for the rant yet again,
Rick
Old 01-07-2004, 03:36 PM   #120
SLKWrx
Member#: 8247
2004 STi JBP
1973 914
Wow.. not even a credit.. and its almost verbatim.. that sucks man.. I'm sorry
SLKWrx is offline
Old 01-07-2004, 04:31 PM   #121
Red Rocket
Member#: 10507
'04 Ex STi Owner
'97 4Runner
Sorry for the rant,
Rick
The gruppe-s folks seem to be pretty good guys, I think they would put up a credit if you emailed them.
Kevin
Red Rocket is offline
Old 01-07-2004, 04:44 PM   #122
horshack
Member#: 19236
Axis GT35/40R STi
Not back yet
Rick
Face it ami2fst4u......Ur a GOD, and they will bow down to your almighty power or face your wrath!
Honestly, without your post, they couldnt sell any wheels to USDM STi owners!
You should get commision, or at least a finders fee!
Without your assistance and a million fone calls, I would have never known that GramLights would have fit!
Time for the afternoon Nana!
horshack is offline
Old 01-07-2004, 05:04 PM   #123
garlo
Member#: 39296
2004 WRX STi
horshack,
Could you let us know which Gram Lights worked for you and post a picture?
Thanks,
Gary
P.S. Love them dancin' nanas!
garlo is offline
Old 01-07-2004, 05:10 PM   #124
horshack
Member#: 19236
Axis GT35/40R STi
Not back yet
Ordered a set of 4 Silver GramLights 57F 17x7.5 ET 48. (wish they came in Gunmetal)
Not here yet, last I heard 4 weeks on a container ship from Japan!
Unless I wanted express 10 day shipping for an xtra $500!
Per Rays fitment guide, they fit the GC8 Impreza Brembo's. The distributor assured me that they would fit the USDM STi.
Makes sense, since the BBS 17x7.5 are ET 53
Once they arrive via carrier pigeon I will snap some pics and post'm!
Now - what tires?????????
horshack is offline
Old 01-07-2004, 05:20 PM   #125
essogas
Member#: 35703
2004 WRX STi
Blue/British Black 18's
I'm going to try on a set of 57F in the 17"X7.5 this week. I know a place that has them in stock so I will let you know if they fit.
essogas is offline
Closed Thread
Wheels that fit the 2.5i and the best offset. VIsubi Tire & Wheel 2 06-23-2010 09:19 PM
When the hell is prodrive going to make wheels that fit the 05 STI PARAMEDIC Tire & Wheel 2 01-09-2005 01:20 PM
Wheels that fit the 05 STI nhluhr Tire & Wheel 21 06-25-2004 01:46 PM
Need 17x7.5 wheels that fit the STi boxerT Private 'Wanted' Classifieds 5 02-17-2004 03:11 PM
Unknown wheels that fit the STi Neil Wallerstein Tire & Wheel 6 11-04-2003 12:51 PM
