Closed Thread
Old 07-27-2008, 06:09 PM   #1276
MrDanno
Member#: 182509
Gram Lights 57Optimise
18x8.5 +43
Does anyone know if this will clear the brembos?
MrDanno is offline
Old 07-27-2008, 08:37 PM   #1277
WRX8XB
Member#: 45323
MY05 Impreza WRX STi
Pastelito Racing & SFSOC
the 18x8.5 +43mm 5x114.3 gramLight 57Optimise clear brembos as do the 18x8.5 +45mm 5x100 gramLight 57Optimise
WRX8XB is offline
Old 07-27-2008, 08:40 PM   #1278
WRX8XB
Member#: 45323
Originally Posted by lcjarrett View Post
Does Gram lights 57C 5x100 18x7.5+48 fit an STI. I bought it from a Nasioc Member and he said that they should Clear Brembos. I hope he was right because I am going to do a Brembo swap on My WRX and I am going to be pissed if they don't Fit.
Someone please help me!!!
the 57c's are not brembo clearance friendly.
I know in the 17x8.5 you needed to go to a +40mm to clear the calipers.
find a local STi and test fit.
WRX8XB is offline
Old 07-28-2008, 08:58 AM   #1279
nhat
Member#: 140163
03 STi
hellaflunctional
Originally Posted by Diablo_XX View Post
Has anyone checked to see if the stock 06/07 wrx 17" will fit over these?
no...and why? they're narrower than the 04 sti wheels...
nhat is offline
Old 07-28-2008, 04:18 PM   #1280
WRX8XB
Member#: 45323
also b/c their spoke design is not caliper clearance friendly and their offset is high.
WRX8XB is offline
Old 07-28-2008, 06:16 PM   #1281
Diablo_XX
Member#: 94514
01 RS
I have a GC and am looking for some cheap rims for the snow where narrow is better, figured i coulda gotten some 06 stockers for cheap. any other recommendations?
PS as far as seeing if aftermarket wheels fit over brembos is to see if they are suggested wheels on tirerack for the 04 sti a good way to do it?
Diablo_XX is offline
Old 07-29-2008, 08:46 AM   #1282
nhat
Member#: 140163
03 STi
hellaflunctional
what's 'cheap'? if you want a set of wheels for under $1000, your best bet is to find a used set or new rotas.
and yes, set your car to be an 04 sti on tirerack and it'll list the wheels that fit over brembos.
nhat is offline
Old 08-02-2008, 12:50 AM   #1283
sycklylow
Member#: 138059
2004 Impreza WRX STi
what is the stock offset of the factory sti wheels for 2004?? I see the size is 17x7.5 but there wasnt a offset listed.
sycklylow is offline
Old 08-02-2008, 02:38 PM   #1284
boxered
Member#: 61884
+53..
boxered is offline
Old 08-11-2008, 12:23 PM   #1285
imcabby
Member#: 71661
2005 Legacy GT ULTD
will Rota Tarmac 1's fit over STi Brakes ( 17x7.5 48 ofset )? 04 and 05 pls
imcabby is offline
Old 08-19-2008, 10:57 AM   #1286
gregr01
Member#: 49333
04 STi
java pearl black
Actual weight on a certified postal scale for the 5/100 manufactured ~2004 is 14.0 lbs without centercap (which does not weigh .9 lbs).
SSR Competition = 17x8.5_ET48__(14.9 lbs)... ([email protected])
gregr01 is offline
Old 08-19-2008, 11:50 AM   #1287
nhat
Member#: 140163
03 STi
hellaflunctional
possibly. any reason why you're asking? only reason i ask is because those are nearly identical to the oem wheel specs.
nhat is offline
Old 08-19-2008, 04:42 PM   #1288
06njsti
Member#: 150986
06 #001 LSB STi
i just put 17x9.5 advan rs's on my 2006 sti. they have the 35mm offset also
06njsti is offline
Old 08-20-2008, 12:57 AM   #1289
alex.gusto
Member#: 187390
What wheel I should choose for the STI version 10?
I am going to buy SSR Type-F 18", the do have 2 specs as follow.
1. 18x8.5 ET30
2. Front18x8.5 Rear18x9 ET40
I am going to use the stock 245 tires, but I do afraid that ET30 wheel is to close to the wings, for ET40, I am not sure if it can fit the Alcon brake kit.
alex.gusto is offline
Old 08-20-2008, 08:48 PM   #1290
Gonzalo_C
Member#: 186902
I have 255/35-18 ...is there any way I can fit 285/30-18s?
Gonzalo_C is offline
Old 08-20-2008, 11:38 PM   #1291
nhat
Member#: 140163
03 STi
hellaflunctional
1. 18x8.5 ET30
to answer you:
Originally Posted by SSR Wheels View Post
Here are some SSR Type F fitments on the 2008 STi! Let us know if you have any questions.
18x9.5 +40 w/ fender modification
18x9 +40 w/fender modification
18x8.5 +48 no modification
1, you haven't told us what kind of car you have. 2, we have no idea what kind of suspension mods you have. 3, to answer you...yes, with money you can make anything fit.
nhat is offline
Old 08-22-2008, 11:47 PM   #1292
kaneda3
Member#: 8057
99 rs-t & 02 sti
95 s14.5
anyone know if if 98-99 rs wheels will clear rear brembos
i know they clear 4pots and 2pots but i need them to clear rear gold brembos
if not, will they clear with like 10mm spacers?
kaneda3 is offline
Old 08-23-2008, 02:09 PM   #1293
jsr426
Member#: 170369
STI- EVO X- GT-R
WRB,WW,RED
how much do the ssr gt-7 18x8 114.3 weigh ?
jsr426 is offline
Old 08-23-2008, 04:12 PM   #1294
nhat
Member#: 140163
03 STi
hellaflunctional
most likely not. i doubt their inner diameter will clear the front calipers. there are very few 16" wheels which clear the brembos.
google says ~18lbs.
nhat is offline
Old 08-23-2008, 04:53 PM   #1295
kaneda3
Member#: 8057
99 rs-t & 02 sti
95 s14.5
no not the fronts
i just need to clear the rears.
kaneda3 is offline
Old 08-28-2008, 11:25 PM   #1296
gregr01
Member#: 49333
04 STi
java pearl black
Rota G-Force
18x9
5x100
et35
hub 56.1mm
Gun Metallic
24.4 lbs per wheel on my certified postal scale.
gregr01 is offline
Old 08-30-2008, 08:11 PM   #1297
affinity1
Member#: 97266
'15 Forester 2.5i
Touring DGM
There has got to a way to tell whether or not a rim will clear STi Brembos. What number do I look for when shopping for a rim? Offset? Backspacing?
There has to be something other than trial and error!?
I don't see ASA wheels on TireRack anymore. Did they change their name to Sport Competition by any chance?
affinity1 is offline
Old 08-30-2008, 09:00 PM   #1298
prochucker
Member#: 21038
05 STi CGM
08 WRX 5D SSM
Subaru Stars
As far as sizes yes, you can generally tell if a rim will not fit, 16 X 7, 53mm offset, 5 X 100, a stock WRX rim, will definately not fit. A 17 X 8, 48mm offset, 5 X 114.3 Rota Torgue fits, but another rim in the same size etc. with a different spoke design may rub the FACE of the Brembos. That's why sometimes you just have to put them on to see.
prochucker is offline
Old 09-07-2008, 03:17 PM   #1299
Robbie_B
Member#: 137728
93 MR2T 87 924S
Teal and Black
Can anyone confirm that SSR Competitions 17x7.5 with a 50mm offset will clear Brembos? Tire Rack says that 17x8 with a 49mm offset of the same rims will fit on an 04 STi. I'd just like to make sure, thanks.
Robbie_B is offline
Old 09-10-2008, 02:31 PM   #1300
grenadeking
Member#: 183231
will this fit my 2004 WRX. Mine stock wheels has 5 lugs
Azul Razr
http://www.azulwheels.com/wheels.html
Thank you
grenadeking is offline
Closed Thread
Wheels that fit the 2.5i and the best offset. VIsubi Tire & Wheel 2 06-23-2010 09:19 PM
When the hell is prodrive going to make wheels that fit the 05 STI PARAMEDIC Tire & Wheel 2 01-09-2005 01:20 PM
Wheels that fit the 05 STI nhluhr Tire & Wheel 21 06-25-2004 01:46 PM
Need 17x7.5 wheels that fit the STi boxerT Private 'Wanted' Classifieds 5 02-17-2004 03:11 PM
Unknown wheels that fit the STi Neil Wallerstein Tire & Wheel 6 11-04-2003 12:51 PM
