Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Closed Thread
Old 04-03-2009, 11:57 AM   #1401
wantsti
Member#: 134764
04 sti
java black pearl
What would fit better on my 04 sti
18x8.5 +48
or
18x9 +42
with a dunlop star spec 255/35/18 tire?
I have rce yellow springs about 1.5 degress of camber all around.
24 mm front bar
22 in the rear
I know i'll have to roll the rear but what would be a better set up i dont wanna pull at all. Is the 8.5 to skinny for that tire?
the car is mostly a dd with the occasional track day.
thanks
wantsti is offline
Old 04-03-2009, 05:09 PM   #1402
nhat
Member#: 140163
03 STi
hellaflunctional
pretty much the exact same setup i have, down to the car, springs, camber, wheel specs, and tire size.
i have 18x8.5 +48 with 255s and i had to roll my fenders flat in the rear, no need for a pull, and no rear camber adjustment. i had about 1-2mm of clearance between tire and strut and never rubbed against the spring perch. i used 3mm spacers because i was rubbing under full compression up front on the fender liner. i think you'd have room with a +45 even without a pull.
right now, i'm running a 17x9 +42 with 255 re01rs. no rubbing anywhere, pretty much the same clearance as the 18x8.5 +48 between tire and strut, and tire to fender.
so all in all, you really can't go wrong but personally, i would go with the 18x9. all you'll need to do is roll the rear fender lips flat and you'll be good to go with either setup. i had my rear fenders slightly pulled so i could run spacers and try to fit a lil bit more tire
nhat is offline
Old 04-03-2009, 05:47 PM   #1403
wantsti
Member#: 134764
04 sti
java black pearl
Thanks nhat
wantsti is offline
Old 04-05-2009, 08:33 PM   #1404
blown subbie
Member#: 188204
2004 wrx
wrb
i have 18x8 oz superleggera's et51 5x100 and i wonder if they will fit an 04 sti. thanks.
blown subbie is offline
Old 04-05-2009, 08:53 PM   #1405
nhat
Member#: 140163
03 STi
hellaflunctional
probably not.
nhat is offline
Old 04-05-2009, 08:55 PM   #1406
blown subbie
Member#: 188204
2004 wrx
wrb
alright, ill have to track down an 04 sti and see if they fit, thanks.
Old 04-05-2009, 09:56 PM   #1407
gr8r rex
Member#: 155652
2002 PSM WRX
www.forced4s.com
nhat, shouldn`t that clear with 3mm spacers in the front? The faq says +48 fits?
gr8r rex is offline
Old 04-06-2009, 12:33 AM   #1408
Nor-Cal'N
Member#: 192190
What are the bolt patterns for the 02-07 WRX Sedan and Wagon and the 06/07 STi?
I want to get some Eneki NT03's but I might be selling the wagon so I need to know the bolt patterns to see what wheels I can get.
Nor-Cal'N is offline
Old 04-06-2009, 01:03 AM   #1409
nhat
Member#: 140163
03 STi
hellaflunctional
02-09 wrx & 04 sti 5x100
05-09 sti 5x114.3
nhat is offline
Old 04-06-2009, 05:02 AM   #1410
Nor-Cal'N
Member#: 192190
What would my options be as far as converting a 5x100 to a 5x114.3?
Old 04-06-2009, 09:31 AM   #1411
nhat
Member#: 140163
03 STi
hellaflunctional
find a wrecked 05-09 sti and taking off the parts or 6gunracing.net for all the parts.
there's also spacers that'll convert you to 5x114.3 but i don't advise that.
nhat is offline
Old 04-06-2009, 11:50 AM   #1412
prochucker
Member#: 21038
05 STi CGM
08 WRX 5D SSM
Subaru Stars
The OZ Superleggera III = 18x8_ET48 fit according to the list. ET53 is the stock offset, May or may not need spacers.
prochucker is offline
Old 04-06-2009, 12:18 PM   #1413
bendub
Member#: 195821
09 White GTR
Hi guys hoping to get some answer here.
I recently purchased a set of ROTA here. 18X8.5 ET35, and I am running tanabe gf210 spring thus it's lowered 1'' front and .5 rear.
What size of tires should I run to minimize pulling and rolling fenders.
bendub is offline
Old 04-06-2009, 01:02 PM   #1414
nhat
Member#: 140163
03 STi
hellaflunctional
nhat is offline
Old 04-06-2009, 01:07 PM   #1415
bendub
Member#: 195821
09 White GTR
Originally Posted by nhat View Post
235/40/18.
Thanks nhat you the man
bendub is offline
Old 04-06-2009, 04:44 PM   #1416
Nor-Cal'N
Member#: 192190
Thanks for all the help. I think I am just going to try and find some wheels that look similar to the NT03's.
Old 04-09-2009, 10:42 PM   #1417
JDMFLCL
Member#: 180513
Baby Baby C'mon!
Looka Bomba! 99 JDM GM8
17x8 +46 MB gears?
i assume they will fit since im seeing even more aggressive offsets fitting.
JDMFLCL is offline
Old 04-10-2009, 03:04 AM   #1418
Chacha
Member#: 183065
2001 2.5 RSTi
BRP
GP Racing Volk RE30 knockoffs 18x8 +45, will those clear front brembos?
Chacha is offline
Old 04-10-2009, 09:32 AM   #1419
nhat
Member#: 140163
03 STi
hellaflunctional
Originally Posted by JDMFLCL View Post
17x8 +46 MB gears?
both depend on spoke design.
nhat is offline
Old 04-10-2009, 09:33 AM   #1420
JDMFLCL
Member#: 180513
Baby Baby C'mon!
JDMFLCL is offline
Old 04-10-2009, 10:10 PM   #1421
prochucker
Member#: 21038
05 STi CGM
08 WRX 5D SSM
Subaru Stars
As explained many times, the face of the Brembo caliper protrudes further than most. There has to be clearance there as well.
Old 04-14-2009, 05:57 PM   #1422
vatorn10
Member#: 124724
Whats the biggest tire you mount on a sti bbs 5x100? will a 255 fit?
vatorn10 is offline
Old 04-15-2009, 02:30 PM   #1423
prochucker
Member#: 21038
05 STi CGM
08 WRX 5D SSM
Subaru Stars
The '04 17 X 7.5 BBS? Some 255's may wedge on there, many different 255's fit the 17 X 8 - 5 X 114.3 of the '05 up BBS. The 1/2 inch difference may make it not possible, 245 probably.
Old 04-21-2009, 11:17 AM   #1424
darkinc
Member#: 188559
06 STI
Will these fit on an 06 sti Advans RS 18x9.5 (114.3x5) w/Yokohama Advan Neova tires (255/40 R18 95W)..
stock suspension?
darkinc is offline
Old 04-21-2009, 11:20 AM   #1425
WRX8XB
Member#: 45323
MY05 Impreza WRX STi
Pastelito Racing & SFSOC
where did you find 18x9.5 Advan RS's?
and no the 255/40/18 is far too tall.
and we don't know the offset you've found, so we can't say if it is even feasible without a stock suspension.
if you're talking about a 17x9.5 +35mm with a 255/40/17 then it's possible to make it fit with the appropriate suspension and fender mods but it wont work (nor look good) on a stock suspension.
WRX8XB is offline
Closed Thread
Wheels that fit the 2.5i and the best offset. VIsubi Tire & Wheel 2 06-23-2010 09:19 PM
When the hell is prodrive going to make wheels that fit the 05 STI PARAMEDIC Tire & Wheel 2 01-09-2005 01:20 PM
Wheels that fit the 05 STI nhluhr Tire & Wheel 21 06-25-2004 01:46 PM
Need 17x7.5 wheels that fit the STi boxerT Private 'Wanted' Classifieds 5 02-17-2004 03:11 PM
Unknown wheels that fit the STi Neil Wallerstein Tire & Wheel 6 11-04-2003 12:51 PM
