Closed Thread
Old 12-09-2010, 12:26 AM   #1751
tingle86
Member#: 198876
2006 STI
anybody tried the raceline bremtech 17x8 with +35 offset? it shows 5.877 backspace. also what is the center bore that i need? this one shows 74 mm. sorry i am a noob. thanks in advance.
tingle86 is offline
Old 12-09-2010, 09:08 AM   #1752
Foxy
Member#: 33069
2008 STI
Originally Posted by BrianU View Post
Looking for winter rim and found set of MB Weapons, size 17x8 with offset of +42. Can anyone say if these will fit 2011 STI?
Thanks
These will fit. I ran them on my 08 STI, but I bent two of them in one winter.
Foxy is offline
Old 12-09-2010, 01:29 PM   #1753
DRayKS2011STi
Member#: 265651
2013 Focus ST
Tuxedo Black
got a friend who has a set of blizzaks for free if they fit, 205-50-17, would just have to pick up rims, but am unsure if there is a combo that will work for the 11 STi, help?
DRayKS2011STi is offline
Old 12-13-2010, 03:41 AM   #1754
jh.
Member#: 263340
2011 4DR STI
Does anyone know if buddyclub p1 sf 17x7 +42 will clear 2011 brembos?
jh. is offline
Old 12-16-2010, 03:44 PM   #1755
knkfiend
Member#: 219466
17x8 +48 drag dr31 on sti. yay or nay
knkfiend is offline
Old 12-17-2010, 04:28 AM   #1756
04wrexsti
Member#: 225937
15 Mustang GT
All subies gone
im also wondering this^
04wrexsti is offline
Old 12-18-2010, 12:14 AM   #1757
Ellery
Member#: 267484
2011 Impreza WRX STI
Plasma Blue Pearl
Default 16" for 2011 STI Sedan
Originally Posted by RockyMtnKevin View Post
I measured the radius needed to clear the Brembos when I had access to this chassis, and then contacted a bunch of companies that make custom steel wheels, and found out the 16" rim blank they start with was at least 1/2" too small in the diameter to clear the Brembos. I doubt there is a 16" that would work, but I think it would be cool if there was one.
This was exactly my question too - I HAVE A SET OF 16"X7" +45MM Offset OZ rims with 5 x 114.3 mm Bolt pattern with Snows from my 98 Eclipse GS-T That I was hoping to use on my STI just in case I had to drive it over the winter.
I guess the only way for me to know is to try it out then. Unless someone from Tirerack can confirm...Please.
The OEM on the 2011 STI Limited I have is a BBS 18" x8.5" +55 (according to stamp on rim?) 5 x 114.3 bolt pattern. using 245/40 R18
Any help would be appreciated! Thanks
E
Ellery is offline
Old 12-18-2010, 11:46 AM   #1758
SilverSubi
Member#: 9856
2011 STI
PBP
I can't find any confirmation that the Stock/OEM 17" 2005 STi wheels will work on a 2011 STI. Does anyone know this for certain?
Thanks.
SilverSubi is offline
Old 12-18-2010, 04:37 PM   #1759
mosc
Member#: 177401
2015 STi White
Thanks.
They fit fine
mosc is offline
Old 12-20-2010, 11:42 AM   #1760
Nokternal
Member#: 264258
So do we have an answer to what the smallest diameter, narrowest alloy wheel with a decently close-to-stock offset for the 2011 STI Sedan is? Preferably the most inexpensive as well
Nokternal is offline
Old 12-20-2010, 01:24 PM   #1761
Axan
Member#: 17569
I'm running Rota SDX 17x7.5 ET45 wheels ~$650
might not be narrowest but they let you run 205 tires which I think are perfect for winter.
Axan is offline
Old 12-20-2010, 02:30 PM   #1762
nhat
Member#: 140163
03 STi
hellaflunctional
http://forums.nasioc.com/forums/show...highlight=cr+v
honda cr-v wheels would be ideal for that tire size.
from a quick search, you'll probably need a 15mm spacer to clear the calipers.
yay if they're identical to the rota torques in the same specs.
you'll need a spacer, there's no way a 16" wheel will clear the calipers.
http://www.iwsti.com/forums/gd-tires...tion-pics.html
the next best option would be the oem bbs wheels from an 05-07 sti.
nhat is offline
Old 12-21-2010, 03:22 PM   #1763
jdm05
Member#: 180155
05 Jdm Sti 2.0
anybody know if 2011 wrx wheels fit 04 sti. I'm searching...
jdm05 is offline
Old 12-22-2010, 01:06 PM   #1764
prochucker
Member#: 21038
05 STi CGM
08 WRX 5D SSM
Subaru Stars
The bolt pattern is the same, and the offset should be close enough, the question is will they fit over the Brembo's. If you do a test fit, let us know here so others will be able to find out.
prochucker is offline
Old 12-22-2010, 01:32 PM   #1765
jdm05
Member#: 180155
05 Jdm Sti 2.0
I will do that as soon as i can get a hold of them put a want in my region.
jdm05 is offline
Old 12-24-2010, 01:18 PM   #1766
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Going on the information here, I assume 2009/2010 stockers wouldn't fit over Brembos, would they? 17x7 ET55...
OrbitalEllipses is offline
Old 12-24-2010, 10:26 PM   #1767
prochucker
Member#: 21038
05 STi CGM
08 WRX 5D SSM
Subaru Stars
If you're talking about the WRX wheels, see the above few posts...
Old 12-25-2010, 11:48 PM   #1768
mosc
Member#: 177401
2015 STi White
2002 - 2010 stock wrx wheels do not clear brembos.
mosc is offline
Old 12-30-2010, 07:41 AM   #1769
scoreseasy
Member#: 268626
1996 Impreza WRX sti
Default Final Speed Forged
Final Speed Forged are amazing. I just wish I could find another 17X7.5 +49C for my '96 sti to complete my set.
scoreseasy is offline
Old 01-01-2011, 09:40 AM   #1770
Smezmerz
Member#: 223561
02 Tacoma/01 RS
white/ sedona red pearl
does anyone know if 17x8 TE37c +38 will clear a brembo? I bought a set for my GC8. I see that the +44 will clear it, so does that mean that the +38 will as well? Thank you
Smezmerz is offline
Old 01-04-2011, 07:26 PM   #1771
Olduwan
Member#: 266164
2011 STI Sedan Ltd
Satin White Pearl
I can confirm that 2005+ Acura RSX wheels will fit and clear the 2011 STi sedan brembos with a 5mm spacer.
Olduwan is offline
Old 01-04-2011, 07:29 PM   #1772
nhat
Member#: 140163
03 STi
hellaflunctional
should, yes.
what're the specs on these?
nhat is offline
Old 01-11-2011, 12:41 PM   #1773
TheHawk
Member#: 242617
04' STI
JBP
I'm wondering if the XXR 521 18x8.5 et40 will fit over my 04 STI's Brembo's. Maybe I'll just need 5mm or 10mm spacers?? I'm in a bind and need new wheels pronto, so if anyone could help me out that would be awesome.
TheHawk is offline
Old 01-13-2011, 10:49 PM   #1774
xkenhillx
Member#: 270195
2006 sti
white
Hey i just got a 06 sti and im looking for some stock wheels so i can run winter tires. I live in washington. Anyone know where i can get a set?
xkenhillx is offline
Old 01-15-2011, 01:01 AM   #1775
hi-flo
Member#: 220008
2004 WRX STi
Originally Posted by nhat View Post
should, yes.
2005-2006 rsx type-s rims like those pictured are 17x7 +45 iirc
hi-flo is offline
Closed Thread
Wheels that fit the 2.5i and the best offset. VIsubi Tire & Wheel 2 06-23-2010 09:19 PM
When the hell is prodrive going to make wheels that fit the 05 STI PARAMEDIC Tire & Wheel 2 01-09-2005 01:20 PM
Wheels that fit the 05 STI nhluhr Tire & Wheel 21 06-25-2004 01:46 PM
Need 17x7.5 wheels that fit the STi boxerT Private 'Wanted' Classifieds 5 02-17-2004 03:11 PM
Unknown wheels that fit the STi Neil Wallerstein Tire & Wheel 6 11-04-2003 12:51 PM
