Closed Thread
Old 04-04-2011, 08:14 PM   #1901
mosc
Member#: 177401
2015 STi White
your calculator was fed bad info. That setup is 5mm more inner clearance, 15mm less outer clearance. The tire is taller than stock, but not by much. Should be fine, but you'll be close to your rear fenders.
My comments would be 19" wheels offer only a poor selection of overly expensive tires. Also, 255 is not a lot of width for the 2011 STi. 265 or even 275 can be done with stock fenders if you keep the offset up.
mosc is offline
Old 04-04-2011, 11:10 PM   #1902
totem
Member#: 220270
2011 STI Sedan
Spark Silver Metallic
I used: http://www.1010tires.com/wheeloffsetcalculator.asp
New rims are 9.5 offset 45.
Stock rims are 8.5 offset 55
So if the offset calculator was given wrong info, the offset for a stock rim is not 55? http://www.iwsti.com/forums/gr-tires...ei-offset.html
okay so without modifying the fenders on a 2011 sti sedan,
CE28N 18x9.5 with what offset will be the best to use with 265 35 18?
Thanks again.
totem is offline
Old 04-05-2011, 12:38 AM   #1903
littlewhitewagon
Member#: 103068
11 STI sedan
Why are you afraid of rolling the rear fenders? There is so much fender that it's not even funny.
littlewhitewagon is offline
Old 04-05-2011, 07:01 PM   #1904
mosc
Member#: 177401
2015 STi White
Thanks again.
You used the WHEEL width, which is nowhere near the limiting factor. I used the TIRE width (245/40R18 vs 255/35R19) and the offset.
mosc is offline
Old 04-05-2011, 07:49 PM   #1905
seanwork101
Member#: 273243
2008 WRX STI
grey
Default 2008 STI rims
i am looking fo the 2008 STI 18' 7.5 silver alloy wheels. does any one have a set or know where i can find some dope wheels for my ride i bent one and do not want it to look off... any advice where to find rims would b dope. thanks guys!!!
seanwork101 is offline
Old 04-06-2011, 12:19 AM   #1906
totem
Member#: 220270
2011 STI Sedan
Well, its not fear.
In 07, I bought an 07.
In 08, I traded in the 07 for an 09.
And this year, I traded in the 09 for this car.
I just want to keep the body of the car stock.
Its a personal preference just in case I decide to sell this car in 3 years.
totem is offline
Old 04-06-2011, 12:57 AM   #1907
totem
Member#: 220270
2011 STI Sedan
This gave me the section width in inches: http://www.1010tires.com/TireSizeCal...?action=submit
I then got the offsets in mm from vendors.
And used them in:
Which says that:
inner clearance has 5mm more
outer position extends by 15mm
If the math is already correct, using the ce28n, what is the maximum safe outer position extension(mm) without rubbing anywhere on stock suspension with no fender mods?
totem is offline
Old 04-06-2011, 01:45 AM   #1908
littlewhitewagon
Member#: 103068
11 STI sedan
Well, its not fear.
I have never once had anyone care if the fenders were rolled. Those who did care were so excited that it was done right and beautifully. A proper roll will look like the rear fenders of a BMW (they are rolled from the factory on the sport package models). In 02, got an 02. In 06, I got an 06. In 07, I got an 08. In 10, I got an 11... I buy cars often too.
Old 04-06-2011, 02:43 AM   #1909
totem
Member#: 220270
2011 STI Sedan
Hmmm.
Let me think about it.
Thanks.
totem is offline
Old 04-06-2011, 04:28 AM   #1910
wrathchild_78
Member#: 200388
2000 Impreza GT
Originally Posted by wrathchild_78 View Post
hi guys,
I own a subaru impreza GT MY00 with the gold brembo brakes from a new age STI.
I really like the BBS RG-R wheels. Can someone confirm if they will fit my car?
If not, what BBS wheel clears the brakes and has the same more or less design as the RG-R?
thanks in advance
Odysseas
Does anyone know FOR SURE if any of the below wheels fits in a classic Impreza with gold brembos fitted?
17"
BBS RG-R Wheel 17x7.5 5x100
http://www.vividracing.com/catalog/w...0-p-48084.html
BBS RS-GT Wheel 17x7.5 5x100
http://www.vividracing.com/catalog/r...0-p-47728.html
18"
BBS RG-R Wheel 18x7.5 5x100
http://www.vividracing.com/catalog/w...0-p-48101.html
BBS RS-GT Wheel 18x8 5x100
http://www.vividracing.com/catalog/r...0-p-47744.html
BBS RE Wheel 18x8 5x100
http://www.vividracing.com/catalog/w...0-p-48061.html
wrathchild_78 is offline
Old 04-06-2011, 07:39 PM   #1911
///M-power
Member#: 278764
Default Impreza 2.5i Wheels
I wont to get the gold BBS whels for my subaru Impreza 2.5I 2007. and the bolt pattern is 5*100. I have BBS whelss in good condition for STI 2007, but it doesn't fit on my car because the bolt pattern is 5*114.
Originally Posted by ami2fst4u View Post
I have compiled a list of wheels that to the best of my knowledge fit the STi with sizes and offsets. With out further delay here goes (all in random order):
General Info for the 04' USDM STi:
04' STi bolt pattern = 5x100
04' STi BBS wheels = 17x7.5_ET53__(16.5 lbs)
Wheels that fit the 04' STi (sizes and offsets):
17 wheels:
Rage Breaker = 17x7_ET42... (fastline)
Enkei CDR9 = 17x7_ET40
Enkei ES-Tarmac = 17x8.5_ET48__(16 lbs)... (Red Rocket)
Enkei ES-Tarmac = 17x9_ET50_(16 lbs)... (Red Rocket)
Enkei RS5 = 17x7_ET40__(19.8 lbs)... (ralyrcr)
Enkei RS6 = 17x7.5_ET38... (clong on imprezawrxsti.com)
Enkei RPF-1 = 17x8_ET45__(15.5 lbs)... (rharder)
Volk SE37K = 17x8_ET38 & ET44... (Rayswheels website)
Volk SE37K = 17x8.5_ET50... (Rayswheels website)
Volk TE37 = 17x8_ET44... (wgknestrick)
Volk LE37T = 17x8.5_ET50__(15 lbs)... (horshack)
Volk CE28N = 17x7.5_ET33__(13.8 lbs)... (Rayswheels website)
Volk CE28N = 17x8__ET38 & ET44... (Rayswheels website)
Volk CE28N = 17x8.5_ET40 & ET44... (Rayswheels website)
Volk CE28N = 17x9_ET43__(14.8 lbs)... (Rayswheels website)
STi RS-ZERO = 17x8_ET40... (Rayswheels website)
5Zigen FN01RC = 17x8_ET35__(16.5 lbs)... (Z1 Performance)
5Zigen Pro-Racer GN+ = 17x8.5_ET48... (Silver-Bolt)
ASA KA3 = 17x7.5_ET48__(23.4 lbs)... ([email protected])
ASA JH3 = 17x7.5_ET48__(22.0 lbs)... ([email protected])
Advan Racing V2 = 17x8.5_ET45... (Z1 Performance)
Advan RG-II = 17x8.5_ET43... (Gruppe-S)
Advan RG = 17x8.5_ET43__(16.5 lbs)... (WorldOne)
Advan RS = 17x8.5_ET43... (Gruppe-S)
Advan TCII = 17x8.5_ET45... (WorldOne)
OEM UK/JDM STi (ver. 7)= 17x7. 5_ET53... (wrx what)
Rota Tarmac II = 17x7.5_ET48... (SubyDude)
Rota SDR = 17x7.5_ET48__(18 lbs)... (SubyDude)
Rota Torque = 17x8_ET48__(18.1 lbs)... (SubyDude)
Rota Rev = 17x8_ET48__(18.1 lbs)... (SubyDude)
Rota Boost = 17x8_ET48... (SubyDude)
Rota Grid = 17x8_ET48... (SubyDude)
Rota Slipstream = 17x8_ET48... (SubyDude)
Rota Slipstream = 17x8.5_ET48__(21.0 lbs)... (SubyDude)
Compomotive TH2 = 17x7.5_ET53
Compomotive TH3 = 17x7.5_ET53__(22 lbs)... (mazdman)
Work Meister S1-1P = 17x8.0_ET46... (Z1 Performance)
Work Emotion CR KAI = 17x8_ET47... (Z1 Performance)
SSR Competition = 17x8.5_ET48__(14.9 lbs)... ([email protected])
SSR GT7 = 17x7.5_ET48__(16.8 lbs)... ([email protected])
SSR GT2 = 17x8.5_ET48__(15.9 lbs)... ([email protected])
Racing Sparco Tarmacs = 17x7_ET48__(20.5 lbs)... (garlo)
O.Z. Superturismo GT = 17x7.5... ([email protected])
O.Z. Ultraleggera = 17x8_ET48__(17.4 lbs)... ([email protected])
WedsSport SA-70 = 17x7.5_ET45__(16.8 lbs)... ([email protected])
18 wheels:
Buddy Club P1 II Plus = 18x8_ET48__(21.0 lbs)... (UrbanImport)
Crimson K6 = 18x8_ET46... (Z1 Performance)
STi RS-ZERO = 18x7.5_ET53... (G-force)
Speedline Turini = 18x8_ET48... (UKjon)
Enkei RPF-1 = 18x8_ET45__(17.8 lbs)... (ami2fst4u)
5Zigen Pro Racer GN+ = 18x8.5_ET48... (South Coast Subaru)
5Zigen FN01RC = 18x8.5_ET48... (Aerosim Research Ltd)
Gram Lights 57Pro = 18x8_ET40... (imminence)
Gram Lights 57F-Pro = 18x8_ET37 & ET43... (Rayswheels website)
Gram Lights T57-RC = 18x8.5... ([email protected])
G-Games 77W/vaio = 18x8.5_ET42... (byroll01)
Kosei K3 = 18x8.5... ([email protected])
BBS RE = 18x8_ET50__(19.0 lbs)... ([email protected])
Crimson K6 = 18x8_ET46__(20.8 lbs)
Compomotive MO = 18x8_ET53
Black Racing Pro N1 = 18x8_ET45
Advan RG-II = 18x8.5_ET45__(18.0 lbs)... (Fizz Autosports)
Advan RCII = 18x8.5_ET45... (WorldOne)
Rota Tarmac II = 18x7.5_ET48__(18.1 lbs)... (SubyDude)
Rota Formula Mesh = 18x8_ET48__(21.1 lbs)... (SubyDude)
Prodrive Special Edition P1 (STi Specific) = 18x7.5_ET46__(21 lbs)... ([email protected])
Prodrive GC-010 = 18x8_ET43__(17.75 lbs)... ([email protected])
Prodrive GC-06 = 18x8_ET43__(17.25 lbs)... ([email protected])
Prodrive GC-07 = 18x8_ET43__(17.25 lbs)... ([email protected])
Prodrive PFF7 = 18x8_ET51__(20.25 lbs)... ([email protected])
Volk GT-N = 18x7.5_ET37... (PhastM3)
Volk GT-C (Face 1) = 18x8_ET42... (STi - IMPREZA)
Volk CE28N = 18x7.5_ET33... (Rayswheels website)
Volk CE28N = 18x8_ET38 & ET44... (Rayswheels website)
Volk CE28N = 18x8.5_ET40 & ET44__(15.2 lbs)... (Rayswheels website)
Work Emotion CR KAI = 18x7.5_ET42... (Z1 Performance)
Work Emotion Forged = 18x7.5_ET42__(17.4 lbs)... (Z1 Performance)
WedsSport SA-70 = 18x8... ([email protected])
OZ Superleggera III = 18x8_ET48... ([email protected])
O.Z. Ultraleggera = 18x8_ET48__(18.4 lbs)... ([email protected])
SSR GT10 = 18x8_ET49__(23.4 lbs)... ([email protected])
SSR Competition = 18x8.5_ET48__(15.0 lbs)... ([email protected])
SSR GT7 = 18x8_ET48... ([email protected])
SSR Professor SP1 = 18x8.5_ET47__(22.5 lbs)... (sev)
SSR GT2 = 18x8.5_ET48__(17.2 lbs)... ([email protected])
SSR GT7-H = 18x8_ET51... ([email protected])
Speed Star Wheels D5R = 18x8.5_ET50__(24.7 lbs)... ([email protected])
Sport Edition E1 = 18x8_ET45__(23.0 lbs)... ([email protected])
Velox ZETA 5 = 18x7.5_ET47...(subarudaikin & Velox website)
Velox ZETA 8 = 18x7.5_ET47...(subarudaikin & Velox website)
Velox ZETA K = 18x7.5_ET47...(subarudaikin & Velox website)
19" wheels:
G-Games 77W/vaio = 19x8_ET42... (Rizzo314)
Speed Star Wheels D5R = 19x8_ET50__(25.1 lbs)... ([email protected])
SSR Professor SP1 = 19x8.5__(23.4 lbs)... ([email protected])
SSR GT10 = 19x8_ET49__(25.1 lbs)... ([email protected])
SSR Comp-H = 19x8_ET51__(19.0 lbs)... ([email protected])
OZ Superleggera = 19x8_ET48... ([email protected])
O.Z. Ultraleggera = 19x8_ET45__(20.0 lbs)... ([email protected])
Volk CE28N = 19x8_ET35 & ET43... (Rayswheels website)
Volk CE28N = 19x8.5_ET35 & ET43... (Rayswheels website)
Additional Wheel Info:
(The fitment for the Volk LE28N's is the same as the Volk CE28N's, as it is the same wheel except with a polished lip.)
General Info for the 05' USDM STi:
05' STi bolt pattern = 5x114.3
05' STi BBS wheels = 17x8_ET53
Wheels that fit the 05' STi (sizes and offsets):
17 wheels:
Enkei RS5 = 17x7_ET40__(19.8 lbs)... (rdqlus)
Advan RG-II = 17x8.5_ET50... (black on imprezawrxsti.com)
ASA ST4 = 17x8... ([email protected])
ASA JH3 = 17x7.5_ET45__(23.8 lbs)... ([email protected])
ASA ST4 = 17x8_ET45__(26.5 lbs)... ([email protected])
BBS RK = 17x8__(19.7 lbs)... ([email protected])
Mille Miglia Action = 17x8... ([email protected])
Mille Miglia HT3 = 17x8... ([email protected])
O.Z. Superleggera = 17x8__(17.6 lbs)... ([email protected])
Rota Boost = 17x8.5_ET48... (Subydude)
Rota Slipstream = 17x8.5_ET48... (SubyDude)
SSR GT7 = 17x8__(17.2 lbs)... ([email protected])
WedsSport SA-90 = 17x8... ([email protected])
Volk CE28N 17x8.5_ET50... (cusco4life)
Volk TE37 17x8.5_ET50... (STiMonSTAR on imprezawrxsti.com)
Gram Lights T57-RC = 17x8... ([email protected])
WedsSport SA-70 = 17x7.5_ET43__(16.5 lbs)... ([email protected])
WedsSport SA-90 = 17x8_ET48__(20.8 lbs)... ([email protected])
18 wheels:
Crimson K6 = 18x8.0_ET49... (Z1 Performance)
Volk TE37 = 18x8.5_ET50... (ScoobyPilot on imprezawrxsti.com)
Volk CE28N = 18x8.5_ET40 & ET50... (Milan on imprezawrxsti.com / Fizz Autosports)
BBS RE = 18x8_ET40__(20.3 lbs)... ([email protected])
O.Z. Superleggera = 18x8... ([email protected])
Advan RG-II = 18x8.5_ET50__(19.0 lbs)... (Fizz Autosports)
ASA JH3 = 18x8__(25.1 lbs)... ([email protected])
ASA CL20 = 18x8_ET45__(29.5 lbs)... ([email protected])
Moda R10 = 18x8_ET45__(34.4 lbs)... ([email protected])
SSR GT7 = 18x8... ([email protected])
SSR GT7-H = 18x8_ET51__(19.4 lbs)... ([email protected])
SSR GT10 = 18x8.5_ET51__(24.3 lbs)... ([email protected])
Work Emotion CR KAI = 18x8.5_ET43... (Fizz Autosports)
Work Emotion Forged = 18x7.5_ET42... (Z1 Performance)
5Zigen FN01RC = 18x8.5_ET48... (WRXTwiztid)
Gram Lights 57F = 18x8.5_ET45__(18.5 lbs)... ([email protected])
Rial Porto = 18x8... ([email protected])
RO_JA R2-5 = 18x8... ([email protected])
RO_JA R2-7 = 18x8.5... ([email protected])
19" wheels:
Volk TE37 = 19x8.5_ET43... (CBRD)
Mille Miglia Action = 19x8... ([email protected])
Moda R10 = 19x8_ET45__(36.6 lbs)... ([email protected])
SSR GT7-H = 19x8__(21.2 lbs)... ([email protected])
SSR Comp-H = 19x8_ET48__(21.2 lbs)... ([email protected])
If you don't see a wheel/offset listed that you KNOW fits the STi please post it, and I will update the list as more wheels come available. I too am still waiting to here back from a few manufactures as to other wheels that fit, and I will update accordingly after I get responses.
Enjoy,
Rick
p.s. This list was compiled using fellow Nasioc members posts (members that actually have these wheels on STi's) as well as some of the manufactures fitment guides.
///M-power is offline
Old 04-06-2011, 10:04 PM   #1912
prochucker
Member#: 21038
05 STi CGM
08 WRX 5D SSM
Subaru Stars
Right, and your question is?
prochucker is offline
Old 04-07-2011, 11:11 PM   #1913
///M-power
Member#: 278764
Default Impreza wheels
Can I swap my SUBARU STI 2007 BBS gold wheels with 5*114 bolt pattern to the same with 5*100. Or sell them ?? Please can you help me with that.
Old 04-08-2011, 08:09 AM   #1914
dbrier
Member#: 6598
2012 Mazdaspeed3
Crystal White Pearl
Sell them, they won't fit at all.
dbrier is offline
Old 04-08-2011, 10:38 AM   #1915
prochucker
Member#: 21038
05 STi CGM
08 WRX 5D SSM
Subaru Stars
If you mean swap wheels with someone, by all means do, the 04' and earlier STi's had the 5X100 wheels. If you mean swap hubs so your car is now 5X114, you can do that too, although that is considerably more expensive.
Old 04-09-2011, 01:38 AM   #1916
///M-power
Member#: 278764
Ok thanks. I think I am going to sell them! And can you tell me pleas how much it's going to cost me the same wheels with 5*100 bolt pattern.
Old 04-09-2011, 03:01 AM   #1917
sc00by4life
Member#: 97135
The 2004 sti bbs are not the same wheel, they are half an inch narrower @ 17x7.5.
They are ~900-1000 in my area.
sc00by4life is offline
Old 04-09-2011, 01:43 PM   #1918
prochucker
Member#: 21038
05 STi CGM
08 WRX 5D SSM
Subaru Stars
These wheels are in high demand, as they are the only STi wheels that fit the WRX/Forester/Legacy. They occasionally show up on Ebay, and the For Sale threads of various Subaru Forums, $900-1000 is a fair estimate for almost anywhere. New, they would cost considerably more. ShopSubaruParts.com has them for $776.15 each, plus shipping, they typically have about the best prices on OEM parts.
Old 04-10-2011, 04:19 AM   #1919
///M-power
Member#: 278764
[img]dsc00499[/img]
Old 04-10-2011, 04:19 AM   #1920
STI_8
Member#: 209325
2004 Stage 2+ STI
1. Will 18x7.5/ET48/5x100 Prodrive GC010E clear brembo brakes on my 04' STI.
I need to know this for sure %100, no guess's. I'm about to spend $1400 for these if they fit and I can't return them.
Please Help asap! I saw one other thread that implied they may not fit...but specs are so close to stock with ET48 instead of 53... Don't want to waste time and money if they don't fit. Thanks for any help!
STI_8 is offline
Old 04-10-2011, 04:23 AM   #1921
///M-power
Member#: 278764
I wont to put the photo of my wheels, but I dont know how?
Old 04-10-2011, 04:30 AM   #1922
///M-power
Member#: 278764
It the same with good condition I am not lie. The bolt pattern is 5*114, 17 inch with rims and tiers. It doesn't fit on my Impreza because my bolt pattern is 5*100.
Old 04-10-2011, 04:31 AM   #1923
///M-power
Member#: 278764
So I am looking to same with 5*100 bolt pattern.
Old 04-10-2011, 11:06 AM   #1924
prochucker
Member#: 21038
05 STi CGM
08 WRX 5D SSM
Subaru Stars
OK, Your posts about buying, selling, or trading wheels, belongs HERE.
Old 04-10-2011, 04:50 PM   #1925
///M-power
Member#: 278764
Thanks a lot.
Closed Thread
Wheels that fit the 2.5i and the best offset. VIsubi Tire & Wheel 2 06-23-2010 09:19 PM
When the hell is prodrive going to make wheels that fit the 05 STI PARAMEDIC Tire & Wheel 2 01-09-2005 01:20 PM
Wheels that fit the 05 STI nhluhr Tire & Wheel 21 06-25-2004 01:46 PM
Need 17x7.5 wheels that fit the STi boxerT Private 'Wanted' Classifieds 5 02-17-2004 03:11 PM
Unknown wheels that fit the STi Neil Wallerstein Tire & Wheel 6 11-04-2003 12:51 PM
