View Poll Results: Cobb CAI or SPT by Eibach springs?
Cobb Cold Air Intake 10 50.00%
SPT by Eibach Springs 10 50.00%
Voters: 20. You may not vote on this poll
Old 11-04-2003, 12:45 PM   #1
millenix
Member#: 43511
2010 Nissan Frontier
Gray
Default CAI or Springs
I have a tough decision to make...
or
SPT Springs by Eibach (1.4" front - 1" rear [aprox])
My only current mod is a catback exhaust with a magnaflow muffler and I am very interested in both... just can't have my cake and eat it to.
What do you guys think?
millenix is offline   Reply With Quote
Old 11-04-2003, 12:50 PM   #2
Zen
Member#: 12656
I'd go for the springs.
You still on RE92's?
Zen is offline   Reply With Quote
Old 11-04-2003, 12:53 PM   #3
millenix
Member#: 43511
Gray
Yes, as stated I've only done a cat-back exhaust system. I've been debating on whether I should replace the cruddy tires, or wait to replace wheels and tires together later on.
Old 11-04-2003, 12:57 PM   #4
Zen
Member#: 12656
Aftermarket tires make a world of difference! But it's your decision. Also, getting a thicker rear sway bar makes a world of difference as well. A WRX rear sway bar will work, they are 20mm compared to your puny 13mm one, and they are cheap.
Old 11-04-2003, 03:08 PM   #5
Defiantguy
Member#: 41268
2015 WRX
I'd say do intake unless you have money for the alignment to do after you put the springs on(not saying you have to but you should get your car realigned after you lower it).
Defiantguy is offline   Reply With Quote
Old 11-04-2003, 03:42 PM   #6
millenix
Member#: 43511
Gray
Well I work at a local Subaru dealership, so getting an alignment done isn't as expensive as most folks have to pay, but it is indeed more $$ cause those guys don't work for free
The real issue is which to get first, the other will likely be my next mod. I'm just courious which you guys would do in my position.
Old 11-04-2003, 03:57 PM   #7
C-daleRidr
Member#: 18074
2008 Speed3
springs. I've wanted to tune the suspension on my car since I got it, but keep spending the money on bicycles.
I've read a lot about the Eibach Pro springs being a hair better than the SPT version, but they're harder to find.
C-daleRidr is offline   Reply With Quote
Old 11-04-2003, 05:16 PM   #8
DanzBorin
Subaru Bounty Hunter
Member#: 7131
2015 Outback - Croc
Dundee Edition Ice Silver
don't do only the springs... wait, save up and at least buy struts too, if not strut tops while you are at it... I know you want to get something new, but for now all springs will do is slowly kill the struts... and you will be wasting your time, as you will have to do the whole thing later if you get struts... might as well do It all at once... It was tough, but I waited 5 months to do all 3... it was well worth it, as it is a PITA process...
oh, btw... I'm also overruling both... either get new tires, or a rear sway bar before you do anything else...
DanzBorin is offline   Reply With Quote
Old 11-04-2003, 11:48 PM   #9
BlackAndBlue
Member#: 40617
2002 RS's dont come w/puny 13mm ones anymore, i think theyre 17 now, im too lazy to go check (thats what i remember suby girl saying) it still makes a difference, i have the Perrin w/endlinks. I went w/the CAI and cat back first, then the perrin stuff. then again i live in downtown atlanta so i cant lower my car w/out fear of scraping something
I wouldnt get springs w/out new struts...
I'd go w/the cobb...
BlackAndBlue is offline   Reply With Quote
Old 11-04-2003, 11:50 PM   #10
blueimpreza25rs
Member#: 21821
2004 Fxt
Psm
i'd go for the CAI, if your still on stock wheels
i was just deciding between tint and cai
and i'm going w/ the cai
blueimpreza25rs is offline   Reply With Quote
Old 11-04-2003, 11:57 PM   #11
Kucheto
Member#: 3688
2002 Impreza 2.5RS
Blue Ridge Pearl
good decision I just got my used COBB CAI and absolutely love it
Kucheto is offline   Reply With Quote
Old 11-05-2003, 01:58 AM   #12
nySulli
Member#: 32617
2008 STi
i'd say get a rear sway bar and then the intake
i can tell you my 04 has a 13mm rear sway, so i doubt the 02 would have anything bigger
nySulli is offline   Reply With Quote
Old 11-05-2003, 02:36 AM   #13
joubtt
Member#: 33901
04 04 STI
No AWD, Not interested
You can probably get a used larger sway bar(adjustable) for cheap, get rid of those re92's, do struts/springs/Sti tops at once. I did all of the above and it should've at least come that way from the factory.
In fact, you just missed a 30% sale on SPT products .
joubtt is offline   Reply With Quote
Old 11-05-2003, 03:58 AM   #14
jasona
Member#: 11786
2014 OB 2.5i 6MT
Custom Dirt/Snow twotone
Or you could get a non name brand intake and springs both for the same price as either one of the brand name products.
edit: Jeebus, the Cobb CAI is almost $300 I didn't realize
$300 = intake, piping from your header to catback, springs, and like 100 bucks left over for, something... I dunno right now. It's 3 am.
jasona is offline   Reply With Quote
Old 11-05-2003, 09:18 AM   #15
millenix
Member#: 43511
Gray
From what I have read over and over, with the Cobb CAI you get what you pay for... its definitly the part I want on my car.
The springs also aren't a bad deal at all on price... my price on them is a bit less than anything else I've found... and the other aftermarket springs would wear stock struts considerably faster than the SPT by eibach springs would... as they are designed for stock struts.
Old 11-05-2003, 09:20 AM   #16
millenix
Member#: 43511
Gray
By the way... man this poll is neck and neck... heh 6 for springs and 5 for the Intake so far.
Old 11-05-2003, 09:20 AM   #17
DanzBorin
Member#: 7131
2015 Outback - Croc
not necessarily true... dealers also sell the AGXs and recommend them with the SPT springs...
Old 11-05-2003, 09:55 AM   #18
m750
Member#: 2278
8Sti | 07 allez
White | Comp
I wouldn't recomend agx's for anyone.
Go w/ springs, and when your tires are toast, get something good. You'll get more out of handling mods than 'power' mods.
AO
m750 is offline   Reply With Quote
Old 11-05-2003, 10:20 AM   #19
Swano
Member#: 19114
2002 2.5TS
Blue Ridge
Don`t assume things if you are too lazy to check.
It still comes with a 13mm rsb.
You will get more out of handling mods thats for sure. But the fisrt handling mod you should do is to get some good tires, you can't even imagine what difference it makes.
Phil =)
Swano is offline   Reply With Quote
Old 11-05-2003, 10:45 AM   #20
millenix
Member#: 43511
Gray
Yes I could imagine what difference it would make... but as I stated the choice currently is between these 2.
Old 11-05-2003, 10:53 AM   #21
MulletSlayer
Member#: 7044
2015 Crosstek
If your not going to replace the struts don't buy the springs. I would go with the Cobb CAI. If you want to do something suspension wise get a set of high performance tires. Falken Azenies are not that expensive and will give you better results then just springs alone.
"Anything worth doing, is worth doing right"
MulletSlayer is offline   Reply With Quote
Old 11-05-2003, 10:59 AM   #22
DanzBorin
Member#: 7131
2015 Outback - Croc
AO
what's wrong with the AGXs... best cost effective strut made... as long as you put the correct spring on them... I had them and loved them... they aren't great rally struts, but for road use, they are great... better than the V5 IMHO...
Old 11-05-2003, 11:01 AM   #23
millenix
Member#: 43511
Gray
While everyone is throwing in tires, which tire would everyone recommend on an affordable budget? No need for all seasons here, only 3 seasons in Texas... December, January, and Summer.
Old 11-05-2003, 11:05 AM   #24
DanzBorin
Member#: 7131
2015 Outback - Croc
falken azenis sport... best all around tire for cheap... actually one of the better tires around period, just happens to be cheap...
only other decent option in the price range is the Kumho MX, but it costs a bit more and isn't near the tire the falkens are...
Old 11-05-2003, 11:09 AM   #25
BlackAndBlue
Member#: 40617
Phil =)
I wasnt assuming, I was trying to remember a post by suby girl at midnight, unfortunately i forgot that it was for wrx's only therefore useless to us...
WTT/WTB aem cai or aps cai boxergq SCIC Private Classifieds 22 12-06-2011 01:29 AM
Poll : Aem CAI or Injen CAI pdpawd Alaskan Impreza Club Forum -- AKIC 21 01-12-2008 04:54 AM
FS: Gram Lites, AEM CAI, STi springs battlewagon Vancouver Impreza Club Forum -- VIC 21 10-18-2005 06:24 PM
WANTED: Cobb CAI or Axleback or cat-back! (RS) HolyCrikey Private 'Wanted' Classifieds 0 06-27-2005 10:37 PM
Injen CAI or AEM CAI? KillerRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 02-24-2002 12:18 AM
