Old 11-04-2003, 04:36 PM   #1
koolaid
Member#: 43491
1997 Impreza Outback
Red
Default would you buy this catback?
koolaid is offline   Reply With Quote
Old 11-04-2003, 04:57 PM   #2
AustinSTi
Member#: 9386
2000 2.5rs sedan
silverthorn
3" piping for a NA car is far too large, if your whip is a 97 outback, I would go with a 2.25" exhaust at the most
AustinSTi is offline   Reply With Quote
Old 11-04-2003, 05:14 PM   #3
koolaid
Member#: 43491
Red
whats wrong w/ 3 in?
Old 11-04-2003, 05:17 PM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
not enough back pressure. You will actually lose HP with too big an exhaust...
Old 11-04-2003, 05:26 PM   #5
koolaid
Member#: 43491
Red
I could almost swear back pressure was the root of all evil
Old 11-04-2003, 05:40 PM   #6
Jejunum
Member#: 15773
2011 Impreza WRX
its actually not back pressure that is a big issue but instead lack of exhaust velocity.
when building an exhaust system one wants to eliminate as much as back pressure as possible...while keeping exhaust velocity as high as possible
heres a link
http://www.cobbtuning.com/tech/exhaustdesign/index.html
Jejunum is offline   Reply With Quote
Old 11-04-2003, 06:23 PM   #7
Matt Monson
Member#: 832
99 2.5RS, '85 911
When the heck did Josh post that up??? I am a regular on their site and their forum and hadn't seen that. Thanks...I consider one of the benchmarks of a good day one where I learned something new on these forums...Today it was a good day...
Old 11-04-2003, 06:41 PM   #8
koolaid
Member#: 43491
Red
so i should get this CB???
Old 11-04-2003, 06:53 PM   #9
Jejunum
Member#: 15773
2011 Impreza WRX
if its a 3 inch diameter pipe...no
i recommend a stromung catback. i have the stainless steel single pipe (not the XA) and it sounds great!
Old 11-04-2003, 07:20 PM   #10
koolaid
Member#: 43491
Red
I am poor, i need cheap performance
Old 11-04-2003, 07:30 PM   #11
Jejunum
Member#: 15773
2011 Impreza WRX
custom magnaflow is ur best option then; buy the pieces (muffler and catback - if u search i think u can find part numbers) you need then find a reputable exhaust shop to weld and chop everything
Old 11-04-2003, 08:07 PM   #12
Ahzlon
Member#: 45216
2005 Baja Turbo
it's all part of Borunolies <sp??> principle... High pressure low velocity... high velocity - low pressure.. sorta like a vaccume...
it pulls air up the vac pipe at a high velocity.. creating low pressure.. ie.. low back pressure... sounds odd... but it's totaly true... it's one reason u can talk and air planes fly
Ahzlon is offline   Reply With Quote
Old 11-04-2003, 10:53 PM   #13
Blindeye_03
Member#: 4418
2016 Focus ST
you all talk like you know what you are saying.
2pt5rs on the board has a 3" exhaust on his RS, and yes it DOES loose some torque, but what it looses in torque, it makes up for in HP.
His RS is just as quick as mine, with similar mods
I have 2.25" exhaust, UDP, intake, flywheel & clutch. On his car he has a 3" exhaust, intake, flywheel & clutch.
They are the same on the road.
-justin
Blindeye_03 is offline   Reply With Quote
Old 11-04-2003, 10:56 PM   #14
2pt5RS
Member#: 10853
2013 BRZ LTD
Satin White Pearl
yes, I lost some low end torque, but gained a lot of high end....my car climbs to 6275 REAL quick...it used to be 6200, but, I think I hit the rev limiter soo much it bumped it up j/k... I'm currently looking for a 2.5-2.75 scoobysport...I love the sound of it too much
Matt
2pt5RS is offline   Reply With Quote
Old 11-04-2003, 11:01 PM   #15
Jejunum
Member#: 15773
2011 Impreza WRX
-justin
well i guess u know better than cobbtuning? the only knowledge i can draw on is my engineering background...if people say to maintain torque u must maintain exhaust velocity ; well i understand that...
Old 11-05-2003, 01:17 AM   #16
AustinSTi
Member#: 9386
2000 2.5rs sedan
silverthorn
i believe Brucelee ran a 3" exhaust on his na rs a while back and he stated it ran like ish
Old 11-05-2003, 03:59 AM   #17
Dolphin Overton
Member#: 1925
01 A4 89 944s2
13 Speed 3R 99 Sprint
If you need cheap performace, go custom. Find a custom exhaust/muffler shop in your area and get something made. Should cost you a bit less than $300 for a catback. I had a Stromung for 2.5 years and it was great, but now that it's rattling and i'm in college(read "pooR") i can;t afford a new one. I am going with a super trap 2.25" muffler welded to my 2.25" stromung midpipe. should b great.
Dolphin Overton is offline   Reply With Quote
Old 11-05-2003, 04:14 AM   #18
jasona
Member#: 11786
2014 OB 2.5i 6MT
Custom Dirt/Snow twotone
I paid $80 for a muffler and $30 for the piping. Complete headerback, not catback Custom is the way to go
jasona is offline   Reply With Quote
Old 11-05-2003, 09:51 AM   #19
m750
Member#: 2278
8Sti | 07 allez
White | Comp
3.0 is huge, 2.5 is larger than I'd go. 2.25 is what I've heard recomended from the people who used to be here...
m750 is offline   Reply With Quote
Old 11-05-2003, 10:56 AM   #20
cfvwtuner
Member#: 16474
1972 bug, 1977 Bug
NESIC TrackHoz member #23
I wanted an exhaust that had that same look at the rear can. I bought a pep-boys special 2.5" stainless fart can. I cut off the stock RS muffler, welded on a 2-2.5" adaptor then made a hanger and installed the can. Overall outside the car sounded fine. Inside there was just way too much resination and was just too loud.
I just bought a SPT/brospeed system to replace it. Sounds much better.
Seat of the pants feel was the same with both.
I think that the 3" is going to be way too big. I passed on that e-bay auction because of the size
cfvwtuner is offline   Reply With Quote
Old 11-05-2003, 03:14 PM   #21
LA
Member#: 7119
2000 impreza rs
blue ridge pearl
3" is a bit big, just get a 2.25" catback system
LA is offline   Reply With Quote
Old 11-05-2003, 05:24 PM   #22
spiralsmurf
Member#: 16085
2005 STi
i rode in a car w/ a 3" catback and its just fine.
spiralsmurf is offline   Reply With Quote
Old 11-05-2003, 07:57 PM   #23
koolaid
Member#: 43491
Red
har, i should have made this a poll.. I want good looks too! I mean the gf *dont ask* is like make it a show car
Old 11-05-2003, 09:10 PM   #24
twizzstyle
Member#: 18941
2005 Lotus Elise
Orange
but how many people are really gonna look under your car and say:
"that doesn't look like 3 inches, does it? This car sure ain't show quality"
You don't need a huge exhaust to look nice!
twizzstyle is offline   Reply With Quote
Old 11-05-2003, 11:38 PM   #25
Derk1127
Member#: 9134
2000 Impreza RS-T
BRP w/Hydra+EJ257
Back when my car was NA my first exhaust was a blitz nurspec which had 3" piping only from the axle back and it completely sucked the torque out of the low end of my car. Top end didnt change too much but i thought the difference down low was dramatic. I then switched to a greddy evo with 2.5 inches and the car seemed to pull off the line much harder and it still had all the top end i had with the nurspec. this can be because it is a catback vs. a axle back but i think that 3" is too much for a NA car. Im boosted and im still runing with my 2.5" Greddy evo and I think its fine... although im looking at other exhausts now... like the greddy DD
one more note, if you get your exhaust done custom, make sure your tubing is mandrel bent and make sure they weld the can on so its not angled down. theres too many ricers out there with theyre ford escorts and their J-Bodies with their exhaust tips pointing to the pavement... and it looks cheap that way
Derk1127 is offline   Reply With Quote
Would you buy this car? This color? Sephro Off-Topic 37 08-16-2005 02:14 PM
Would you buy this STi? Hank3 STi Forum Archive 22 06-18-2003 11:27 AM
Would you buy this-GC8 Custom bumper wighti Interior & Exterior Modification 27 07-27-2002 01:47 AM
hey guys, would you buy this? dRu888 Southern California Impreza Club Forum -- SCIC 4 01-29-2002 06:13 PM
Would you buy this? chyisan Texas Impreza Club Forum -- TXIC 3 01-18-2002 08:28 AM
