Old 11-04-2003, 10:45 PM   #1
96imp
Member#: 28237
1996 impreza L
green
Default o2 sensor question.....
the long version:
being not the smartest person in the world when i was putting in a new half shaft i had to drop the muffler and what not to reach the roll pin. i didnot disconect the o2 sensors because there was enough slack, however when i decided it needed to be moved the downstream o2 senesors wires pulled out of the plug(on the sensors side of the plug).
the short version:
Now the question is what wires went in what holes in the plug. there is a blck wire and 2 white wires with no tracers so i'm not shure how to figure out which one goes where and there is no money left in the budget to get a new one. any help would make my day. Is it possible the white ones can be in either spot?
96 1.8L
thank matt
96imp is offline   Reply With Quote
Old 11-04-2003, 10:55 PM   #2
Ahzlon
Member#: 45216
2005 Baja Turbo
matt.. look a lil closer.. as far as i remember one of the white wires accualy has a black stripe running up it... or atlest mine does... BUT ill look tommarow and run a volt meter to it.. and kinda set up a diagram for you if i can... or as on my truck.. 2 black wires 1 white.. with white stripe runnin up the wire.. just check.. i might be wrong
Ahzlon is offline   Reply With Quote
Old 11-05-2003, 08:51 AM   #3
ChosenWon
Member#: 2236
2000 Audi S4
silver/rally dirt brown
How cool am I?
ChosenWon is offline   Reply With Quote
Old 11-05-2003, 08:53 AM   #4
ChosenWon
Member#: 2236
2000 Audi S4
I am sooo coolt aht I felt so bad for you that I went out, in the cold, and took off my o2 sensor, came in and took digital pics of it for you.
Kidding. I recently changed mine out and this was in the trunk.
Old 11-05-2003, 10:10 AM   #5
avk
Member#: 17252
'06 WX8
59E
The white wires are interchangeable, so you only need to know where to put the black signal wire. On a '95 diagram, the signal wire in the harness is also black. Hopefully that doesn't change from year to year. But the signal wire is also shielded, so you can't mix up (the shield does not connect to anything on the sensor side). The white wires are power and ground for the heater. On the '95 diagram, the harness colors for them are yellow/red and white/blue.
avk is offline   Reply With Quote
Old 11-05-2003, 10:10 AM   #6
m750
Member#: 2278
8Sti | 07 allez
White | Comp
hey, chosen, any chance I could maybe buy your dead 02 sensor? I'm working on a harness for my mil eliminator, and I need the connectors...
:-D
AO
m750 is offline   Reply With Quote
Old 11-05-2003, 04:21 PM   #7
ChosenWon
Member#: 2236
2000 Audi S4
Sure how much?
Old 11-06-2003, 09:28 AM   #8
96imp
Member#: 28237
1996 impreza L
green
Thanks ChosenWon for the pic but they must be different on yours because mine looks nothing like yours.
As long as avk is right and they are interchangable i should be alright then.
Old 11-06-2003, 10:44 AM   #9
ChosenWon
Member#: 2236
2000 Audi S4
WRX o2 Sensor question... BuickturboV6 Factory 2.0L Turbo Powertrain 6 04-09-2002 06:08 PM
TurboXS stage 2 exhaust O2 sensor question fastburro Factory 2.0L Turbo Powertrain 2 02-06-2002 11:59 AM
O2 sensor question NateDogg Normally Aspirated Powertrain 0 05-21-2001 08:00 PM
O2 Sensor question Spectre23 Normally Aspirated Powertrain 3 01-04-2001 10:16 AM
O2 sensor question Eric SS Technical Forum Archive 2 08-08-2000 09:19 AM
Message Board Statistics All times are GMT -4. The time now is 11:36 PM.
