Old 06-16-2000, 10:03 PM   #1
burr101
Member#: 907
2002 WRX Sedan
Cool Rallispec's Intake/ Oil Catch Can
does the oil catch can that comes with the intake give any preformance gains. thanks
shaun
burr101 is offline
Old 06-17-2000, 12:14 AM   #2
8Complex
Member#: 922
04 FXT
Red
Post
Huh? You're kidding right? It's just a breather to put the non-needed hoses into.
I suppose it could help a little by not having those hoses piped into the intake itself and creating little non-smooth section of the tube inside, but hell...
8Complex is offline
Old 06-17-2000, 08:20 AM   #3
MattC
Member#: 158
2011 STi
PBP
Lightbulb
Have you ever looked in the inside of the intake tubing? Over time it gets coated with oil, as does the throttle body. The catch-can eliminates this, and keeps those nasty vapors away from your MAS. I am having one added to my Minnam Turbo Intake, along with the heat shield and vent block off spacers.
MattC
MattC is offline
Old 06-17-2000, 09:34 AM   #4
Wreckleford
Member#: 887
Post
I don't know why, but oil vapour in your intake charge increases the likelihood of detonation. As well, if oil coats the inside of your intercooler, it reduces the efficiency of it. Two very good performance reasons to run a breather or catch can.
Wreckleford is offline
Old 06-17-2000, 01:58 PM   #5
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Post
So can I get the catch can and use it on the Minnam intake on a NA motor? I have seen my friend's setup (Minnam intake) and he uses CLEAR tubing, and the one hose leading to the T joint is grimy with oil. So can I use the catchcan and eliminate the oil getting back to the intake system? My car is a MY00 btw.
Keiho is offline
Old 06-17-2000, 04:01 PM   #6
Wreckleford
Member#: 887
Post
You can use it on a n/a car, but it is not as necessary I would say. Turbo cars have much greater blowby air passing the rings and going into the crankcase which forces more air and oil through the breather hose.
It is more useful on a n/a car to put the catch can at the PCV valve (although most people don't do it) and not the breather hose though.
Old 06-18-2000, 01:01 PM   #7
Imprezer
Dynamic Uno
Member#: 1
2011 Impreza WRX STi
Post
CUSCO makes a very neat looking oil catch can also. It has dual hose entry for both heads PVC valves.
Imprezer is offline
Old 06-18-2000, 06:19 PM   #8
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Post
Hehe..Imprezer you just like Cusco so much huh? I'll ask Minnam how much the catchcan is..saw one there last time..very nice...
Keiho is offline
Old 06-18-2000, 06:19 PM   #9
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Post
Keiho is offline
Old 06-19-2000, 12:53 AM   #10
burr101
Member#: 907
2002 WRX Sedan
Cool
thanks for the info. where is the pcv valve on the subie? i thought that hose was the pcv valve. another thing, why does the can have its own filter?
shaun
burr101 is offline
HTML code is On
Oil catch can with no maf or intake? ki11switch Built Motor Discussion 11 06-16-2009 08:15 PM
WTT(HR): Greddy Oil Catch Can with Perrin Oil Catch Can scooby_wooby MAIC Private Classifieds 1 03-24-2008 09:01 PM
So cal greddy oil catch can & Apexi intake JRSTI Private 'For Sale' Classifieds 7 04-15-2005 05:31 PM
APS Cold air intake, Perrin Oil Catch Can, ARP Headstud Kit, JE Pistons Subaru300hpWRX Private 'For Sale' Classifieds 24 12-12-2004 01:17 AM
Intakes, Turbos. Oil catch cans, etc blaster88 Normally Aspirated Powertrain 3 03-10-2001 11:08 PM
Message Board Statistics All times are GMT -4. The time now is 12:02 AM.
