Old 11-05-2003, 11:28 AM   #1
dfwblackwrx
Member#: 30713
2006 Chebbie Duramax
1972 Datsun 240Z
Thumbs up Gruppe-S headers
bought the gruppe-s headers used from a friend of mine (petrol) and finally got around to installing them. kind of a pita install cause it had been a while since i had done the uppipe install, all bolts were a BEOTCH to get off, but not bad. reused all old gaskets, absoltley no leaks... same as when intsalled the gruppe-s upipe a long time ago. anyways all went on smoothly... GREAT fit and finish. very high quality. i was extremely impressed with the appearace and all.
took the car for a drive and wasnt really expecting much but i was pleasantly surprised. there is deff a stronger top end... enough to where my gf noticed it was deffinatley pulling harder. and about the apparent lag increase, it is noticeable but the rest is deffinately worth it IMHO.
then the sound, i have the upipe that came with the headers (selling my old one with 6k if anyones interested), hks catless dp, blitz nur-spec catback. (all aftermarket finally! ) anyways its not as bassy as it was, but still very bassy, all the afterfires are more noticeable, its got a very lumpy sounding idle, and sounds mean up high in the rpm's.
all in all i would deffinately recommend the gruppe-s headers to anyone. (the 4-1 collector)
dfwblackwrx is offline   Reply With Quote
Old 11-08-2003, 06:51 PM   #2
nekoball
Member#: 12232
wrx
cute
are they equal length? any sound clips?
nekoball is offline   Reply With Quote
Old 11-10-2003, 03:31 AM   #3
Fatman_UK
Member#: 45848
They're not equal length. They're unequal, but a lot more equal than the original headers.
Sorry, I don't have a sound clip. However, plenty (20+) people over on Scoobynet have fitted these headers this summer. You might find a clip if you have a look around/ask there.
Fatman_UK is offline   Reply With Quote
Old 11-14-2003, 10:00 PM   #4
dunk
Member Sales Rating: (26)
Member#: 15359
Does the plastic splash guard fit back on the car with no modifications.
Duncan
dunk is offline   Reply With Quote
Old 11-18-2003, 03:45 PM   #5
Fatman_UK
Member#: 45848
Do you mean the undertray? When my headers were fitted the undertray was left off. When I queried it I was told that there would have been no way it would have fitted back on unmodified.
Old 11-18-2003, 09:49 PM   #6
dfwblackwrx
Member#: 30713
1972 Datsun 240Z
yes undertray went back on with absolutely no problems... ill get a pick tomorrow.
Old 11-30-2003, 03:40 AM   #7
DaFastOne
Member Sales Rating: (5)
Member#: 19396
02/6 FrankensteinWRX
black
i have to say that my gruppe-s headers are fabulous. allows the turbo to kick on earlier and give you more mid to upper range torque. excellent craftsmenship, but the only thing i dont like is the flexible pipe that they provide you with, i prefer a sold up pipe piece, even though the gruppe-s up pipe piece looks like its a excellet quality piece, i have seen too make of teh flexible pipes break.
DaFastOne is offline   Reply With Quote
Old 11-30-2003, 04:48 PM   #8
Louie
Member Sales Rating: (47)
Member#: 43393
2014 Audi a6
Daytona Gray
do the gruppe-s headers require the use of their up pipe? I have a vishnu up pipe, will I have a compatibility conflict here?
Louie is offline   Reply With Quote
Old 12-01-2003, 06:18 PM   #9
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
bump... pls answer.
Old 12-03-2003, 02:14 AM   #10
Gruppe-S
Vendor Sales Rating: (65)
Member#: 23216
2006 949-457-1234
949-457-1234
Louie - The headers will work with any uppipe that works with the stock headers
Thanks
Max
www.gruppe-s.com
Gruppe-S is offline   Reply With Quote
Old 12-03-2003, 06:32 AM   #11
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
THANK YOU MAX.
Old 12-03-2003, 12:30 PM   #12
gproach
Member#: 30739
2004 Impreza WRX
Java Black
Just had them installed with my Helix up pipe, and I am now totaly cattless. Great sound and it does feel like the top end pulls a little harder.
Other exhaust mods:
Helix down pipe
Cobb catback
George
gproach is offline   Reply With Quote
Old 12-04-2003, 04:07 PM   #13
el crichon wrx
Member#: 8493
2001 Impreza GDA
PSM-01G-IHI powered
There must be the bung for OEM first O2 sensor, but is there a 2nd bung for EGT sensor ?
Case 'YES' : is there a plug provided to fill it ?
Mine's ordered...
el crichon wrx is offline   Reply With Quote
Old 12-04-2003, 04:51 PM   #14
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
MAX- I PM'd YOU.
Old 12-11-2003, 01:15 AM   #15
WRXtreme02
Member#: 12680
2010 GTi
Anyone know if these headers will work on a 2.5?
I would like to get them now while I have the 2.0 still in my car.
Thinking about getting the STi block soon...
Thanks.
WRXtreme02 is offline   Reply With Quote
Old 12-19-2003, 09:42 AM   #16
wRxbeater11
Member Sales Rating: (15)
Member#: 12682
Bump no sound clip
wRxbeater11 is offline   Reply With Quote
Old 12-26-2003, 06:49 AM   #17
el crichon wrx
Member#: 8493
2001 Impreza GDA
PSM-01G-IHI powered
Bump too !
Old 12-26-2003, 11:08 PM   #18
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Default ...
Hi
El Crichon - Sorry for the confusion, the Gruppe-S V2 Manifold does not include an EGT bung for an additional EGT probe. We chose not to do this because there has been much debate on where to locate the EGT bung for best results. However tapping and welding a bung onto the manifold usually takes 10-15 min
WRXtreme02 - Yes, they will work with teh 2.5 STI
WRXbeater11 - Sorry, we do not have sound clips because the exhaust sound is mostly determined by your uppipe, downpipe, exhaust setup, rather than by the manifold. The main difference between the Gruppe-S V2 manifolds and some of the others on the market is that you do not lose the separate exhaust pulsing "scooby sound".
Thanks,
Gary
Gruppe-S
Old 02-09-2004, 03:08 AM   #19
vovo
Member#: 33742
2002 Wrx Sportwagon
WR Blue
I saw them on e-bay for $350 sold by gruppe-s is that the going rate? I have an sti uppipe... will it work with that?
vovo is offline   Reply With Quote
Old 02-09-2004, 09:39 AM   #20
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
Gruppe-s, If I were to purchase set of your headers, could you place an EGT bung for me at the #3 outlet?
Old 02-18-2004, 03:55 AM   #21
downshiftdan
Member#: 52006
2003 WRX
Platinum Silver Metallic
1) why do you not lose the boxer sound? Do unequal length let you keep the sound?
downshiftdan is offline   Reply With Quote
Old 02-18-2004, 06:18 AM   #22
McBain_TP
Member Sales Rating: (2)
Member#: 43986
2002 WRX wagon RIP
2003 330ci black/tan
Yes, unequal length lets you keep the sound. Some people claim they make the car soundmore like a Porsche, more high-pitched. I have a Borla header, it sounds somewhat similar to the setup before the header.
McBain_TP is offline   Reply With Quote
Old 02-25-2004, 06:06 PM   #23
MikeWRX-NJ
Member Sales Rating: (6)
Member#: 33410
08 wrx
dgm
i have to say, i have the gruppe-s header and im taking it off for two reasons.
a) it has *increaed* spool time a little with my vf34.
b) it made my exhaust more "tin" sounding, much more high pitched than i like.
However, I have to say, the headers are awesome quality, they fit perfect and for 6k miles, no leaks.
editted for backwardness.
MikeWRX-NJ is offline   Reply With Quote
Old 02-26-2004, 08:07 PM   #24
15secWRX
Member#: 52088
07 limited
URBAN GRAY
a) it has reduced spool time a little with my vf34.
wouldnt that be a good thing? or are u saying more lag?
15secWRX is offline   Reply With Quote
Old 02-29-2004, 11:47 PM   #25
MikeWRX-NJ
Member#: 33410
08 wrx
dgm
more lag, i was backwards that day.
gruppe s header/helix uppipe questions wrxracer55 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-22-2003 06:13 PM
wanted parts review-gruppe-s headers batmanalan Car Part Reviews 0 10-12-2003 03:24 PM
installed new gruppe-s header v2! blackie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-13-2003 09:25 PM
FS: Cusco Replica/Gruppe-S Header! Kickz107 Bay Area Impreza Club Forum -- BAIC 24 08-15-2003 08:35 PM
has anybody ran gruppe-s headers? Enigma76 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 05-26-2003 01:44 PM
