Old 11-05-2003, 12:45 PM   #1
I_smoke_hondas
Member#: 47755
Question Hot air intake?
So I've had my simple J-tube intake for a while now with the filter in the engine compartment where the air box first was but have no plans for a cold air extension since I'm off-road all the time and don't want to worry about mud or deep puddles. I'm curious if some type of heat sheild would be beneficial, or I was also thinking of moving one step up in the temp range for my NGKs. Anyone think one will work better than the other??? Thanks.
-Andy
I_smoke_hondas is offline   Reply With Quote
Old 11-05-2003, 01:20 PM   #2
Section 8
Member#: 821
A heat shield help get colder air, but if you are "off road all the time" its likely that by drawing air from the fender that you will get more dirt to travel to your filter. Be a stud and cut a hole in the fender and run a tube up to the top of your windshield for a snorkle!
Why do you want to change your heat range? Have you pulled the plugs and evaluated their condition? If they look "used" then you don't need to change them.
Here is a page that talks about the apperance of the spark plugs and what the causes and solutions are:
Here
Greg
Section 8 is offline   Reply With Quote
Old 11-05-2003, 01:46 PM   #3
JewPac42
Member#: 23260
Patr ick Willis
for Rookie of the year
It would be cool to see someone make a snorkel CAI like they use in Jeeps someimtes. Or even a Ram-Air intake through a hoodscoop.
JewPac42 is offline   Reply With Quote
Old 11-05-2003, 01:46 PM   #4
orndog
Member#: 34670
If she smokes she
pokes
The cold air doesn't keep your engine colder, it makes for a denser charge. A heat shield will help, go for it.
orndog is online now   Reply With Quote
Old 11-05-2003, 01:57 PM   #5
I_smoke_hondas
Member#: 47755
Rally Stuff
Yes, I know cool air provides for better combustion(denser air = more powerful explosion), not keeping the engine cool. That's a damn cool idea with the snorkel, though. I know of an offroad shop locally that hooks up the Jeep kits all the time so they will have all the plumbing I'll need. Any ideas for the hood scoop-ram intake would be appreciated since I could do that myself with a hole put where that scoop is- FINALLY! Only concern is keeping the elements out of my combustion chambers while driving....
-A.
Old 11-05-2003, 01:59 PM   #6
Section 8
Member#: 821
All your base?
Old 11-05-2003, 03:02 PM   #7
orndog
Member#: 34670
If she smokes she
pokes
Originally posted by Section 8
All your base?
All your bases are belong to us!
Hot Air Intake VS Cold Air intake.Poll & Discussion arfrce Factory 2.5L Turbo Powertrain 73 09-01-2008 10:35 PM
Intake ?s. Keeping the cold air cold and the hot air OUT (wrap/painting) kaisersouse Normally Aspirated Powertrain 10 08-26-2006 11:49 AM
Hot-Air Intake? turbokill Alaskan Impreza Club Forum -- AKIC 7 10-02-2003 01:04 AM
AEM cold air intake or Injen cold air intake? energy57 Factory 2.0L Turbo Powertrain 31 05-20-2002 12:27 AM
Hot air intake Sparky's WRX Factory 2.0L Turbo Powertrain 3 02-19-2002 07:56 PM
Message Board Statistics All times are GMT -4. The time now is 01:24 PM.
