Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC
Old 11-05-2003, 02:07 PM   #1
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Default FS: Lots of stuff (GC8/GM6), turbo stuff | A few WRX-capable parts
This is a quick list of the stuff I've got out and am looking to sell. I can go into more details on anything you'd like, just ask about it.
Also, these are local pricing without shipping. Shipping would be extra, though I'm sure we can work something out with everything. If you're even half-interested, just ask... I'm reasonable, so don't hesitate on speaking up.
Most if not all of the things listed come with the original boxes and documentation, with pretty much everything that came with it.
Throttle Body $40 (feel free to make offers, too)
Not much to say here... stock throttle body complete with throttle position sensor, but no idle air controller. I knife-edged the inlet side of the throttle body, but left the throttle plate alone as I didn't want to risk problems related to knifing that. I'll also include the fitting to bypass the coolant circuation in the throttle body. I used it through winters, and noticed nothing, so I think there are a lot of wives tales out there about it.
Guage Bezel $50 *
My famous 4-gauge bezel to replace the radio. Put the radio up top and put this in place of the radio for four 2-1/16" gauges. Made of 1/4" aluminum and comes with the necessary screws and spacers to fit right into the dash. It occoured to me that some people hadn't seen this yet, so here is the pics -- http://66.92.133.228/8Complex/gauge_cluster.html
Magnecore Spark Plug Wires (SOHC only) $50
The classic Magnecores. Not much to say about them, but they are definitely nice. SOHC motors only with the coil pack up top of the manifold. The Magnecores have had a history of barely clipping onto the plugs because the boots are too long, but I've never had an issue with mine, just put them onto the plugs and give them a good shove with the palm of my hand.
GReddy A/F Meter & 60mm GReddy Gauge Stand $125 * - Sold/Pending
Im going to say straight out, I had problems with this. I never did get it to read right as it's a near-WB kit and I never was able to calibrate it correctly. Also, the little adjuster on the face has been broken (snapped about 1/8" off the plastic), but you can still get at it with a pliers, or maybe make a slot in it to use a small screwdriver.
Fumoto Oil Drain Valve $15 * - Sold/Pending
If you haven't heard of them, get your head out of the sand! www.fumotovalve.com - Will even include a new crush washer.
Turbo kit (no engine management) - Sold/Pending
Guages $200 - Sold/Pending
3 gauges, Autometer Phantom series (white face, black rings, all have green condoms on the bulbs). Fuel pressure 0-100psi - I will contact Autometer about getting a new wire for the sensor as the original is coming apart, but still works fine. Also comes with T and fittings to just put it in line with your fuel system. Vacuum/boost gauge 30 in/Hg - 15psi (IIRC, will check). Comes with the original nylon line, and a fitting to adapt it to any 3/16" vaccum line. EGT gauge 0-1600F - Comes with everything you need, PLUS it comes with an exhaust manifold with the bung already installed on it by #1-3 collector (4" from head).
Whiteline Anti-Lift Kit $75 - Sold/Pending
Kit is the normal, not the comfort kit (back when I bought it, they hadn't come out with the comfort kit yet). More then anything, this sharpens steering response with the harder bushings. I haven't autocrossed the car recently, so I don't have a comparison between on and off, really. Back when I first installed them, I was on RE92's, so getting a good feel back then wasn't easy as well.
MRT Brake Bracket $20 * - Sold/Pending
It's sold already, so no need for a description just yet.
Stainless Brake Lines $50 - Sold/Pending
No details needed, sold before advertising.
* - WRX capable parts.
Old 11-05-2003, 02:12 PM   #2
mykrrrr
Member#: 733
'13 Focus ST
I may want the STi Grp. N mounts Nick. Let me check my $$$ and I'll get back to you.
-mykr.
mykrrrr is offline   Reply With Quote
Old 11-05-2003, 06:46 PM   #3
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Sorry if this is redundant, If the flywheel fits a 2000 2.5 rs I will buy it.
Tim Sanderson is offline   Reply With Quote
Old 11-05-2003, 07:26 PM   #4
Marcin
Member#: 2874
2005 CGM WRX WGN
Jorge Tunned BattleWagon
Must ignore the turbo kit...
Marcin is offline   Reply With Quote
Old 11-05-2003, 08:24 PM   #5
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Didn't you have like most of a turbo kit sitting there? Whats wrong with all that stuff?
Yup, that is exactly what I had it on. I had an ACT clutch on it... I was considering sending it back to make sure it was good as it was 2x the pressure of ACT's on other cars, but it held great. If you're interested in a clutch at the same time, I can work something out with that as well.
Old 11-05-2003, 10:27 PM   #6
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
If you're interested in a clutch at the same time, I can work something out with that as well. [/b][/quote]
I am interrested in the clutch but I doubt I can swing it now. I am also interrested in the mount set.
P.m. me what you would like to get for all three and I'll see what I can do.
Old 11-05-2003, 10:36 PM   #7
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
arn't the RS fly and wrx fly the same?!?!?!?
scobaru is offline   Reply With Quote
Old 11-06-2003, 12:34 AM   #8
mykrrrr
Member#: 733
'13 Focus ST
scobaru - Nope.
Marcin lost all those other parts.
-mykr.
Old 11-06-2003, 12:54 AM   #9
Hondaslayer
The toast of OT
Member#: 4562
1995 Legacy LSi
1998 Forester, lifted.
Nick,
Want to sell the backbox seperately??
Also if Tim backs out on the flywheel I will take it.
Ben,
Old 11-06-2003, 01:18 AM   #10
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
I won't be backing out of the flywheel. Where the heck is schaumberg?
How do you want to do this Nick?
Old 11-06-2003, 01:28 AM   #11
obyone
Member#: 16523
this anymore???
NW of Chicago.
Nick, I'll talk to you about the Haltech on Thursday. I wanna engine managment on an N/A.
obyone is offline   Reply With Quote
Old 11-06-2003, 04:20 AM   #12
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Tim - I marked you down as Sold/Pending on the flywheel, and sent you a PM regarding the combination of the flywheel/clutch/mounts.
Ben - Don't you have take-offs laying around that you can have a muffler shop modify? If someone shows interest in just the non-resonated Stromung midpipe, I may be willing to split, though.
Oby - Sounds good.
I have plenty of other things to add as well, I just have to organize everything and make sure they're off the car before I sell them. (only things left on the car are spring, struts, rear sway bar, and endlinks all around)
Also, I just added the Anti-Lift Kit. Forgot I had taken it off and not put it on my list.
Old 11-06-2003, 04:40 AM   #13
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
nick i'll take the ALK like i said already bastage lemme know if you need any stock suspension pieces
Old 11-06-2003, 05:07 AM   #14
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Jeremy - Doh, ok, I'll mark you down for it (one of these days I'll remember something again). Was there anything else I missed or hadn't yet listed? Not the WB... I'm still trying to decide whether or not I want to keep that.
Old 11-06-2003, 05:13 AM   #15
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
nick the clutch, STi Mounts....that's all i can think of for now.
you pulling the brake lines off as well??
Old 11-06-2003, 05:33 AM   #16
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
I thought you had a clutch and mounts? Well, they may be spoken for already, unfortunately, but we'll see how they turn out.
Yeah, eventually the brake lines will come off as well. BTW, if you want these Ultimates, $75 and I'll deliver them to ya... consider it buying them from them directly without the shipping costs.
Old 11-06-2003, 05:42 AM   #17
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
no no, you forgot them in the list
$75 for $38 pads.....wow you working at SOE now??
Old 11-06-2003, 09:15 AM   #18
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Nick, I'm in for the flywheel for sure. (replied to p.m). and mounts if mykrrr falls out. Unfurtunately I can't swing the clutch.
Old 11-06-2003, 09:25 AM   #19
Hondaslayer
The toast of OT
Member#: 4562
1995 Legacy LSi
yeah but I am lazy
Brake lines huh?? Can you have them ready for my visit??
Ben,
Old 11-06-2003, 02:55 PM   #20
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Jeremy - Funny guy. That is for all 4 corners of Ultimates.
Tim - Got your PM and replied, marked you down for the flywheel/mounts (sorry guys, he committed first!).
Ben - I think you're behind Jeremy for the brake lines... but I doubt they'll be off real soon unless I decide to get rid of the car fast.
Old 11-06-2003, 03:36 PM   #21
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Nick how about I buy that catback off you for what I sold it to you.
Revision is offline   Reply With Quote
Old 11-06-2003, 03:36 PM   #22
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Ben - Talked to Jeremy about the brake lines and he was just suggesting them to be posted, so if you want them, I'll give ya dibs. You're coming into town on the 22nd? I should be able to have them off by then. I think $50 is pretty fair... I think they go anywhere from $90-120 new, so it sounds about right.
Old 11-06-2003, 03:37 PM   #23
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Andrew - You want it? We can work it out if so...
Old 11-06-2003, 04:11 PM   #24
Hondaslayer
The toast of OT
Member#: 4562
1995 Legacy LSi
Done deal Nicky-poo
Old 11-06-2003, 04:38 PM   #25
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Cool, marked ya down for it, Ben.
FS: lots of WRX Parts turbo xs chip and more JER Tri-State Area Private Classifieds 5 10-13-2009 06:49 PM
FS: lots of stuff- wheels, front brakes, 04STi parts, etc. Carreragt2e MWSOC Private Classifieds 33 05-04-2007 12:43 AM
FS: Lots of GC8 Parts!! RB5, Headlights, Seats, Lip XyKo NESIC Private Classifieds 9 09-17-2006 02:49 PM
FS: Lots of GC8 Parts. RB5 Spoiler, Headlights, Seats, V6 Lip XyKo Tri-State Area Private Classifieds 3 09-14-2006 10:04 AM
FS: Lots of Stock GC8 parts! Robmat Private 'For Sale' Classifieds 2 10-13-2003 01:51 AM
