North West Impreza Club
Go Back   NASIOC > NASIOC Chapters > North West Impreza Club Forum -- NWIC
Old 11-05-2003, 08:55 PM   #1
well_armed
Member#: 15204
Default Switched Ground? Huh? What do I need to do to get my Hella's working!!
Need help here-
How do I hook up my hella lights when our cars use a switched ground system? I want them to come on when the high beams come on, however the high beams read 0 volts when selected.
Hella says that I ground from terminal 85 to the ground on the headlamp (instead of the chassis)...but what is the ground wire on our headlamps? Is that the high beam wire since it reads 0volts when operating?
http://www.hellausa.com/maineng/NewL..._aux_lamps.pdf
Or do I just reverse the wiring, the red wire that normally goes to the battery goes to the ground terminal on the battery, and the ground goes to the positive terminal of the battery?
well_armed is offline   Reply With Quote
Old 11-05-2003, 09:00 PM   #2
Vostok 7
Member#: 30209
Do you need to
read this in Braille?
If I understand you correctly, I had the same problem with my Rallye 4000's when I hooked them up.
You want them to come on with the highbeams? You have to reverse the wiring basically. Are you using the hella harness? What you do is hook the wire that goes to the highbeams to the lowbeam wire. Confusing I know.
There's three wires on your lights, Low, High and a common ground (iirc).
I can find my old thread in the electrical and lighting thread if necessary.
Patrick
Vostok 7 is offline   Reply With Quote
Old 11-05-2003, 09:07 PM   #3
Vostok 7
Member#: 30209
Do you need to
Old 11-06-2003, 12:12 AM   #4
well_armed
Member#: 15204
Thanks Patrick!
Well, have the lights worked properly since you installed them? Are you gettting the right voltage to your relay (+12V)?
Old 11-06-2003, 12:12 AM   #5
PhreeZe
Member#: 11676
2003 350Z
Super Black
Sorry I didnt read all of what Doug said but couldnt he just do the fog light mod? You do some wire cutting and stuff under the dash...
Jason
PhreeZe is offline   Reply With Quote
Old 11-06-2003, 12:24 AM   #6
Vostok 7
Member#: 30209
Do you need to
Originally posted by well_armed
Thanks Patrick!
Yeah, I've taken them off since then, but they worked fine as long as I had them (like 4 months IIRC). They came on whenever I flipped the switch and turned on my highbeams. The relay worked just fine. The problem was the wiring for the Subaru is like the opposite of what the Hella instructions say to do... So all it took was a little creative thinking (and another vampire tap ) and everything worked just fine.
Patrick
Old 11-06-2003, 12:29 AM   #7
well_armed
Member#: 15204
Jason
I am installing some hella FF1000 driving lamps where the stock fog's used to be. Therefore I needed a +12V source for when the brights go on.
I will show you guys some pics of the install as soon as I get my camera batteries charged up. It's gonna be sweet!
dP
Old 12-04-2003, 05:53 PM   #8
well_armed
Member#: 15204
Okay, so I got the lamps working and what not...however I have another problem.
Since I have tapped the low beam to ignite the driving lamps to go on with the high beams...this means that the driving lamps turn on when I switch off my lights from the steering column.
I want all my lights to turn off! Does this mean that I need to tap another source for this to work? Do I need to incorporate a switch with the system so that activates when the lights read the 12+V source?
http://forums.nasioc.com/forums/show...72#post5143372
Old 12-04-2003, 06:09 PM   #9
gpd323
Member#: 9878
2002 WRX/GTX
WRX Wagon/Mazda GTX
If you visit www.rallylights.com they have a wiring diagram to use for the switched ground system the Sube has.
Its here.
http://www.susquehanna.com/susq/other/auxlamps.htm
Cheers and beer me!
Greg Downing
gpd323 is offline   Reply With Quote
Old 12-04-2003, 06:22 PM   #10
well_armed
Member#: 15204
V
Old 12-04-2003, 06:24 PM   #11
well_armed
Member#: 15204
"Note that in some Japanese cars, the GROUND is switched instead. In that case, you would apply battery to pin 85 of the relay and the high or low beam circuit to the other side of the on/off switch. "
Yeah, I could never figure that verbiage out...can someone translate for me?
Old 12-05-2003, 03:00 PM   #12
Vostok 7
Member#: 30209
Do you need to
So let me understand what's going on now... When you turn off the lights, the driving lights come on again? That's odd. I wired my driving lights to another switch so that I could turn them on and off when I had the high beams on, but I don't think they ever came on when the lights were off, switch on or not.
Patrick
Old 12-05-2003, 04:26 PM   #13
well_armed
Member#: 15204
I think I am getting some voltage going to the lights still with the DRL lights (even though I have unplugged the drl unit under the hood).
I am going to try and disable the DRL module under the glove-box...see if that works.
Where do I get my Subaru worked on? Subaru shops/techs in Texas Geoff Texas Impreza Club Forum -- TXIC 0 01-22-2010 12:37 AM
Who do I need to PM tp get my handle changed like Subiedrift (cough) I mean Semaj? AnorexicSTI Vancouver Impreza Club Forum -- VIC 8 01-16-2007 11:07 AM
what do i need 2 do to beat a ser w/det? denracingwrx Mid West Subaru Owners Club Forum -- MWSOC 25 05-26-2003 02:11 PM
Info on where to get my wrx worked on ram116611 Bay Area Impreza Club Forum -- BAIC 3 10-22-2002 11:40 AM
