Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 11-06-2003, 03:25 PM   #1
SlowMotion
Member#: 42455
Default ITB on RS engine possible?
Hi guys, just wondering if ITB (Individual Throttle Body) on a boxer engine possible? i know nobody makes them...but lets say..just lets say...someone decided to make one....would it work on a boxer engine?
SlowMotion is offline   Reply With Quote
Old 11-06-2003, 04:06 PM   #2
Dolphin Overton
Member#: 1925
01 A4 89 944s2
13 Speed 3R 99 Sprint
it's possible. they would sit right on top so it shouldn't be a problem. It would sound INSANE.
Dolphin Overton is offline   Reply With Quote
Old 11-06-2003, 04:17 PM   #3
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
It is a work in progress.. Josh at Cobb is working on a one off design of ITB's for his personal car. Just yesterday, he said that while they won't put it into production, it may become available as a very expensive custom set up. But don't expect it in the near future. To my understanding he won't put any more work into the ITB's until Trey does some redesign work on the stage II heads...so it will be quite some time.
Not very streetable, but a good way to get around the flow issues of the intake manifold on a going for broke NA build.
Old 11-06-2003, 04:22 PM   #4
jasona
Member#: 11786
2014 OB 2.5i 6MT
Custom Dirt/Snow twotone
One of the things I'm gonna do to mine is get another stock TB and run twin TB's / twin manifolds. That's the next step after I finish turboing.
jasona is offline   Reply With Quote
Old 11-06-2003, 04:24 PM   #5
Zen
Member#: 12656
how would twin manifolds work?
and how would they benefit your setup?
Zen is offline   Reply With Quote
Old 11-06-2003, 08:06 PM   #6
dcoty
Member#: 3149
01 V7 GC/R32 sky
Im building an aluminum intakle manifold with my brother this winter, it will be done by xmas. It is a dual plenum/ dual TB setup. One plenum over one head, the other over the head on the other side, the runners run straight down from the bottom of the plenum. We just have the velocity stacks to order and thats it. Each throttle body will have a cobb-style intake running into each fender.
Dan
dcoty is offline   Reply With Quote
Old 11-07-2003, 02:49 AM   #7
jasona
Member#: 11786
2014 OB 2.5i 6MT
^ exactly, except my TB's will go into a y-pipe to the intercooler. Err I guess that's backwards, the intercooler outlet will split with a y-pipe to the 2 TB's.
For my little turbo kit, the benefits will be having complete control over runner length and manifold volume, double the airflow without buying an expensive large diameter TB, and mainly the coolness factor.
Old 11-07-2003, 04:42 AM   #8
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Do I need to bust out that pic of the JDM N/A 2.0 280ps monster again??? It has individual throttle bodies, among other things...
Old 11-07-2003, 07:38 AM   #9
danci1973
Member#: 19018
1995 Legacy Wagon
Please, do!
D.
danci1973 is offline   Reply With Quote
Old 11-07-2003, 10:46 AM   #10
Compressed
Member#: 12271
2012 4Runner TE
KDSS!
Hell yeah man, its a must!
Compressed is offline   Reply With Quote
Old 11-07-2003, 11:24 AM   #11
Matt Monson
Member#: 832
99 2.5RS, '85 911
Absolutely!!!
Old 11-07-2003, 11:32 AM   #12
SlowMotion
Member#: 42455
PLS DO! i would luv to see it!
Old 11-08-2003, 01:19 AM   #13
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
%$#%#, trying to find the pic on my HD...
Old 11-08-2003, 01:25 AM   #14
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Ok, found it...
Old 11-08-2003, 03:02 PM   #15
SlowMotion
Member#: 42455
Kostamojen...thanks for the pics..i'm drooling already! haha!!
Old 11-08-2003, 03:42 PM   #16
SlowMotion
Member#: 42455
btw, is there a website where i can get a closer look at the engine?
Old 11-08-2003, 06:28 PM   #17
Crazy D
Member#: 35927
02 wrx
this is for nasty nate
Crazy D is offline   Reply With Quote
Old 11-08-2003, 06:37 PM   #18
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
It'd be simple to pull off, but problems lie in the tuning since ITB's don't tend to give off very steady vacuum signals, even with a vacuum plenum for the map sensor. Plus you'd have to run a seperate intake air temp sensor since the stock one that is in the MAP sensor won't work.
There is another problem with getting it to work right... the exhuast ports suck on these engines. The cylinders at the outsides of the motors (1 & 4) have extremely bent exhaust paths, creating some crappy flow in itself.
280hp would be cake... give me a motor that will rev to 10k and is cammed right, add 11.5-12:1 compression, tune it right, and call it a day. Personally, I would choose to start with a 2.2NA motor (shorter stroke, slightly larger bore), or destroking a 2.5L motor.
Old 11-08-2003, 11:03 PM   #19
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
It took me forever to even find that pic originally... The first time I saw this car it was in a JDM Impreza magazine from a couple years back, if that helps any... Had close up pics of the engine, and other things...
Old 11-09-2003, 02:32 PM   #20
SlowMotion
Member#: 42455
oh..guess i'll just have to give it a miss then..no worries. Thanks for the pic again.
Old 11-10-2003, 01:40 AM   #21
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Found the pics!!!
http://www.spomotorsports.com/PhotoG...ID=#CustomerID (more at this link)
Old 11-10-2003, 11:59 AM   #22
Compressed
Member#: 12271
2012 4Runner TE
KDSS!
oooh look at this intake design
I like!
Old 11-11-2003, 02:28 AM   #23
SlowMotion
Member#: 42455
Found the pics!!!
great!! thanks dude! yummy!
Old 11-12-2003, 08:36 PM   #24
steve_d
Member#: 315
pretty awesome stuff...
it gives me great ideas for the 1.8L motor...
I dont' hang out much anywhere else but the SE forum...
I've got a project see, actually a couple, one of which is to put a subaru 1.8L in a 1967 porsche 912. the motor would face backward in relation to how it faces now, so the headers would just exit out the front of the block and straight out the back of the car...I may even leave them as duals.
sjd
steve_d is offline   Reply With Quote
Old 11-13-2003, 02:51 AM   #25
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
I'd pick anything other than the 1.8l for that idea...
The only useful Idea I have for my 1.8l would be to throw on some WRX heads and some low compression pistons and run it with a turbo. Should work great due to the thick piston walls of the 1.8, but for everything else i'd say screw the 1.8...
Need Help Pls: Possible boost issue on stock engine Kean Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 05-14-2010 12:43 PM
Swapping an EJ257 STI engine into an RS or possibly WRX Audioexcels Subaru Conversions 0 04-27-2009 12:31 AM
Possible spun rod bearing....suggestions on shops/engine sources phillyc Mid West Subaru Owners Club Forum -- MWSOC 0 10-08-2007 09:50 AM
Advan RS 18x9ET45 possible on a 04 STi? giverSTi Tire & Wheel 5 05-03-2007 10:51 AM
Headers on RS engine? LaGuaGua Normally Aspirated Powertrain 23 11-03-2005 12:42 PM
