Old 11-06-2003, 05:19 PM   #1
marioej18
Member#: 31115
2004 saab 9-3 aero
black
Default help! how much antifreeze?
just a quick question
how much antifreeze is needed to fill the DOHC 2.5L?
marioej18 is offline   Reply With Quote
Old 11-07-2003, 03:58 PM   #2
NicEJ25
Member#: 26155
2008 WRX 5dr
Dark Grey
the cooling system need 5.8L of coolant (6.2 quarts). be very careful to bleed it. special funnel that goes on the rad cap or vaccum system strongly recommended. do the change when the engine is cool. fill the system as much as you can, start the engine and let it run until the rad fan has started and stopped twice. this is about 15-20 min long. fill the overflow at least at the full mark. after the first few ride, check the level when cold. subarus engine, at least the 2.5, care tricky to bleed. when you first fill up the system, maybe only 2/3 of it will be actualy filled. if you leave it this way, you'll get some trouble. I worked at a deaker this summer, and they told me they've seen a couple of case of blown engine because of bad filling. ****ty garage that were filling once and let the owners go. the engine overheat, the head gasket blow because of the warping, then the coolant get away, and the engine overheat more and more, and so on...
i don't want to scare you, you just need to be cautious.
NicEJ25 is offline   Reply With Quote
Old 11-08-2003, 07:55 PM   #3
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Do a 50/50 mix of antifreeze & water. "technically" you should really use distilled water. It's cheap too.
Legacy777 is offline   Reply With Quote
how much harder to swap an 06 wrx into gc then say an 04? HELP MUCH APPRECIATED!!!!! slavik.86 Subaru Conversions 10 05-27-2010 11:17 PM
HELP how much $ will i spend taking my car to dealership ben c Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-18-2009 02:43 PM
Help how much are 02-03 wrx stock struts/shocks?? whosgotdanks Tri-State Area Forum 1 12-02-2007 08:32 PM
Help !!! How Much Power? BooSTIn_StI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 05-06-2007 11:58 AM
Help! How much are you paying for insurance? jbogli New England Impreza Club Forum -- NESIC 27 10-26-2002 04:15 AM
