Welcome to the North American Subaru Impreza Owners Club Friday September 19, 2014
Old 11-07-2003, 10:37 AM   #1
cjm04WRX
Member#: 37101
2008 WRX
Default V6 STI longblock in an 04 WRX: Car won't start
Ok here's the deal. I just got done installing my V6 STI RA long block on my 04 WRX and the car won't start.
I've checked everything. Delta Dash reads positive values for all sensors and Injectors. And no codes. Coils are connected and everything is plugged in. Motor has good compression.
I am tired and can't think of anything else.
Any THought?
Thanks
Spanky
cjm04WRX is offline   Reply With Quote
Old 11-07-2003, 10:47 AM   #2
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Ask me.... if all else checks out... it's a cam or crank timing sprocket issue.
v.VI is a GC8, which IIRC used a different timing sprocket then a GDA/B (on the RS's at least)
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 11-07-2003, 01:26 PM   #3
crazyhorse
Member#: 19502
2010 Impreza with no
scoop. =(
Does it act like it wants to start at least? Sort of cranks but just won't turn over.... If so.. make sure you didn't flip flop your fuel lines... I did and it took me a lil bit to figure out why the sucker wouldn't turn over. The engine itself isn't any different than the GDA's here as far as I know. Definitely check the timing though. Which ECU are you using?
Did the v6 have AVCS? If so... and if you're not using an STi ecu.. unplug it!
crazyhorse is offline   Reply With Quote
Old 11-07-2003, 04:33 PM   #4
blackie
Member#: 42979
03 wrx
blizzzack stage IV
blackie is offline   Reply With Quote
Old 11-07-2003, 05:07 PM   #5
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Did you verify that the timing was alined properly? As others have asked, what ECU are you using?
-Jon
Old 11-07-2003, 05:22 PM   #6
mizar
Member#: 20293
03 wrx
1820 makes my area tingle
im going to speak on spanky's behalf here..
he got an entire front clip from a v6.. which icluded all the wiring and ecu
mizar is offline   Reply With Quote
Old 11-07-2003, 05:26 PM   #7
crazyhorse
Member#: 19502
scoop. =(
Hrm.... Double check the fuel lines for sure... If you crossed the return it'll try to start but never kick over for obvious reasons. I could have kicked myself when I reallized that's why it wouldn't start...
One REAAAALLLLLY obvious thing... do you have a voltage reader? I had to jumpstart my new engine.... battery had sat for a while when I was working on it... If your volts are below 12... jump start the sucker then kick yourself for not thinking of it. (Yet another thing I ran into when doing my engine swap)
Old 11-07-2003, 05:40 PM   #8
mlambert
Member#: 13831
check all sensors, theres one in the front that can keep it from firing. I dont know what it is though
mlambert is offline   Reply With Quote
Old 11-07-2003, 06:39 PM   #9
Imprezd
Member#: 3357
V6 motors IIRC are pre 2001 which have different crank trigger.
Changed a timing belt with the motor in the car before? sounds like a nice time to pratice.
Imprezd~
P.S. doesn't sound like he used the v6 ecu since he running delta dash and it has to be setup for that certain ecu... at least that my understanding of their licensing program
Imprezd is offline   Reply With Quote
Old 11-07-2003, 07:22 PM   #10
samh22a
Member#: 30710
04 STI
BTW, what happened to the previous motor ? Did it survive the NOS ?
samh22a is offline   Reply With Quote
Old 11-07-2003, 08:10 PM   #11
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
V6 also don't use the same coil setup, another possible problem.
Which ECU you using?
DarthChicken is offline   Reply With Quote
Old 11-07-2003, 08:13 PM   #12
crazyhorse
Member#: 19502
scoop. =(
So.. he should have the proper coils, ecu, timing stuff, etc....
Old 11-07-2003, 11:27 PM   #13
cjm04WRX
Member#: 37101
2008 WRX
Never used NOS never will. Blew both head gaskets from detonation.
Turned out to be the crank sproket and Cam sproket. Both had to be swapped over from my stock motor.
Old 11-08-2003, 08:59 AM   #14
Imprezd
Member#: 3357
Old 11-08-2003, 10:43 AM   #15
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
So... timing then?
-Jon
Old 11-08-2003, 12:03 PM   #16
downshift1
Member#: 15607
I'm not the type
to make angry
The Ver.6 GC8 uses less definition (fewer points) on the cam and crank sensors, so I swapped both over to the 04' parts and it's all good.
-Dylan
downshift1 is offline   Reply With Quote
Old 11-08-2003, 03:44 PM   #17
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
-Dylan
WOO HOO!! There's hope for my troubleshooting skills yet
Jorge (RiftsWRX)
www.ProjectWRX.com
Old 11-08-2003, 09:59 PM   #18
cjm04WRX
Member#: 37101
2008 WRX
Jorge (RiftsWRX)
www.ProjectWRX.com
Yeah but the motor proceeded to self-destruct on itself in no time flat. Oh well. Here we go again.
Old 11-08-2003, 10:04 PM   #19
samh22a
Member#: 30710
04 STI
details ???
Old 11-08-2003, 11:04 PM   #20
cjm04WRX
Member#: 37101
2008 WRX
details ???
I'll have details after I get the car home. Hopefully tomorrow. Sounds like it spung a crank bearing.
Old 11-08-2003, 11:21 PM   #21
samh22a
Member#: 30710
04 STI
Sorry to hear that,
Good luck !
Sam
Old 11-09-2003, 10:17 PM   #22
cjm04WRX
Member#: 37101
2008 WRX
Well it looks like the oil pump failed. Here are the pics of the damage.
http://pop.ipa-iba.com/anatax/****
Oh well. **** Happens.
05+ STi Center in an 04 STi Admission_Regret Interior & Exterior Modification 1 09-12-2008 04:25 PM
car won't start....and I'm an idiot srt4eh Service & Maintenance 8 12-07-2005 03:05 AM
Putting STi seats in an 04 WRX...quick question SUBIETUNING Interior & Exterior Modification 2 05-20-2005 10:29 PM
04 STi sways in an 04 wagon slvr bullet Brakes, Steering & Suspension 5 06-12-2004 08:28 AM
04 JDM Sti headlight in an 04 2.5 RS? digi Interior & Exterior Modification 11 11-30-2003 05:18 AM
