Mid Atlantic Impreza Club
Old 11-08-2003, 01:57 PM   #1
Gonz
Member#: 18642
2005 Impreza WRX STi
Question Is there Subaru specific antifreeze ?
I need to change my coolant for my 30000 mile service. Here's what the service manual says on page RM-4
" 5. COOLANT. Use the genuine coolant to protect the engine. Recommended: SUBARU Coolant. Item Number 000016218 Alternative: NONE "
I went down to Fitzgerald Gaithersburg to pick it up this morning. The parts guy looks at the computer screen, gets his info then goes to the back. Rummages around for a few minutes, comes back and says 'there is no specific Subaru coolant '
I said, ' well the service manual says there is one " .... He says we just use " regular green coolant. "
Does anyone know if there is actually a Subaru specific coolant or can I just use off the shelf stuff like I've always done on my other cars ? Shouldn't the parts guy be able to tell me the minute I asked him " there is no Subaru coolant" without even looking at his computer screen ? People must ask about this all the time.
Is SUBARU coolant just a private labeled regular coolant invented to make money for the dealer ?
Or, if there is a genuine Subaru coolant and the dealer doesn't know about it or doesn't want to sell it to me, where can I get it ?
I've used off the shelf stuff in my Mustang (iron block and heads) and my BMW ( iron block, aluminum head) for years, but this is a 'new' car and I don't want to put in anything except the factory recommended stuff.
Thanks.
Gonzalo.
Gonz is offline   Reply With Quote
Old 11-08-2003, 02:56 PM   #2
scoobi02
Member#: 14045
99 Forester
White like virgin snow
There should actually be subaru coolant. I don't know much about it but I am sure it exists.
scoobi02 is offline   Reply With Quote
Old 11-08-2003, 03:06 PM   #3
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Yes there is.
its green, but a much deeper green color, probably the same as other green coolants.
Its available at your subaru dealer only
Jay
Old 11-08-2003, 03:49 PM   #4
WRX Jim
Member#: 22321
yea 10 dollars a gallon.. needs to mixed 50/50 water when you get it.
I saw tachih had it.
Scre wfitz in gaitehrsburg, go down to rockville, they know what it is.
WRX Jim is offline   Reply With Quote
Old 11-08-2003, 04:19 PM   #5
iceNine
Member#: 12170
2002 WRX Sedan
Platnum Silver Metallic
Don't even bother to go to Fitz in Gaithersburg for parts. I had to explain to the parts guy there that my WRX had a turbo when he didn't know how to find the little plugs for the cover over the boost control solenoid. I thought for a minute that I had walked into a Dodge dealership by mistake because they didn't seem to know much about Subarus. Going to Rockville would be a better idea.
Dale
iceNine is offline   Reply With Quote
Old 11-08-2003, 06:46 PM   #6
MrBaggio
Member#: 35375
2003 Wrx
WRC Blue
What is the harm in using off the shelf coolant.
Can there be much difference from the higher end non corrosive coolant?
Thanks
Justin
MrBaggio is offline   Reply With Quote
Old 11-08-2003, 06:55 PM   #7
SubaruPartsGirl
Member#: 37513
Subaru makes coolant...
SOA868V9210 / SOA635002
We use Subaru's coolant, brake fluid, ATF and throttle body cleaner.
SubaruPartsGirl is offline   Reply With Quote
Old 11-08-2003, 06:58 PM   #8
N/A
Member#: 133
TBA TBA
TBA
Anybody care to explain the difference between them since its not exactly like comparing the old green antifreeze to the RV antifreeze or the new orange stuff. What makes this so special?
N/A is offline   Reply With Quote
Old 11-08-2003, 10:16 PM   #9
c_hunter
Member#: 32434
05 Outback XT 5EAT
Gold/Black
If there is a recommended Subaru coolant for the WRX, that is interesting. I changed the coolant on my 02 LL Bean Outback, and the manual only called for a general type of coolant. I got the light green Prestone stuff. The old coolant was definitely a darker green (not dirty, but actually "darker" green).
Craig
c_hunter is offline   Reply With Quote
Old 11-09-2003, 03:23 PM   #10
caged1
Member#: 13932
1998 GM6-5MT+09XT
Brilliant Red
Thanks
Justin
yes, I would like to know the difference (if there is one).
caged1 is offline   Reply With Quote
Old 11-10-2003, 08:49 AM   #11
WRX11
Member#: 26638
I can't imagine what kind of differences there could be between the Subaru and the others. Color may varied because everyone wants theirs to stand out. The purpose is to cool the engine and there are only several ways to do it. The engine block, hose and radiator's material are still about the same so why would any off-of-the-shelve coolant be not recommended?
It cools, prevents rust and deposit build up. Those are the only things it should do well. It could be clear as water for all I care.
I'd be really surprised if Subaru really produce their own coolants and not just brand it. Spending the money into R&D just to sell their own coolants is not the corporate mentality these days.
WRX11 is offline   Reply With Quote
Old 11-10-2003, 10:00 AM   #12
slim speedy
Member#: 2254
1992 Sentra SE-R
1999 Infiniti G20
Subaru coolant no silicates or phosphates, they found out that those additives hurt water seals over 25-30k miles. If you don't use Subaru coolant make sure you use one with NO phospates or silicates. However you will find most coolant out there has both of these, and should not be used in Subaru's. There is more info about this in service and maintence.
slim speedy is offline   Reply With Quote
Old 11-10-2003, 01:37 PM   #13
Gonz
Member#: 18642
That's real interesting. If you recall in my original post the parts department guy said " we just use regular green coolant" since they didn't have the SUBARU coolant.
Well I guess that can drum up some business fixing water pump leaks, etc down the road.
So if the stuff exists, and the DEALER doesn't have it, where do I get it...... do I have to Mail Order coolant
BTW, I already purchased prestone but I'm willing to take it back after I read the label.....
I know they have SUBARU brake fluid, but as long as I meet the spec DOT 3 (or DOT4) I'm OK and for the tranny and rear end GL-5 is the spec. Does coolant have some kind of SAE or NIST or ISO or TUV spec's or something I should look for ?
G
EDIT: Just read the service & maintenance forum. Looks like I'm not supposed to use Prestone. I'll save that for my 2002. So what brands can I use....... anybody know ?
I might end up going to a different SUBARU dealer to try and find the correct coolant, but it's not like there's one on every corner.
Old 11-10-2003, 01:59 PM   #14
slim speedy
Member#: 2254
1992 Sentra SE-R
1999 Infiniti G20
I got the subaru coolant from the dealer in leesburg, but i guess thats not to close to you. I suppose either call around to find a local dealer that carries it or mail order it. I think someone in service and maintnance said toyota coolant also has no silicates or phospates.
Old 11-10-2003, 04:21 PM   #15
Gonz
Member#: 18642
Thanks, maybe I'll go down to the Rockville dealer on the weekend.
G
Old 11-10-2003, 04:41 PM   #16
beastcivic
Member#: 17795
2002 Impreza WRX
Platinum Silver Metallic
G
Gonz, if you know you'll be at B&N this week, and if I definitely go, I can pick it up while I'm at work and bring it on Friday. Let me know if you like that idea, or just want to go down there on the weekend.
Anyone know what a gallon of it costs? (Do we need more than one gallon for our cars? I don't know how much it takes in this car.)
beastcivic is offline   Reply With Quote
Old 11-10-2003, 08:06 PM   #17
rbehny
Member#: 1908
rbehny is offline   Reply With Quote
Old 11-11-2003, 10:30 AM   #18
beastcivic
Member#: 17795
2002 Impreza WRX
Is it me, or it is their webpage??? I clicked on the item to add it, but when I go to check out my 'cart' is empty.
Old 11-11-2003, 12:30 PM   #19
Gonz
Member#: 18642
Jim, thanks for the offer.
That would be cool but I am going to stop by Fitzgerald tonight after work... ..... so hopefully I can pick it up !
I believe the coolant capacity is 8.1 quarts 1/2 coolant, 1/2 distilled water (no minerals).
Gonz.
Old 11-11-2003, 12:44 PM   #20
beastcivic
Member#: 17795
2002 Impreza WRX
Cool, no problem. I wasn't sure how late their parts department was open during the week, so I thought I'd offer.
Do you know how much it costs per gallon?
Old 11-11-2003, 12:54 PM   #21
Gonz
Member#: 18642
I spoke with Fitzgerald Rockville.......... they don't have it. The parts guys suggested i use regular non-reconstituted green coolant. That's what they use.
Tisher Subaru in Silver Spring has it. $8.60 for a gallon. Not much different than what other coolants cost and I won't regret miles down the road.
Guess I know what I'm doing at lunch time
Old 11-11-2003, 12:55 PM   #22
beastcivic
Member#: 17795
2002 Impreza WRX
Have a fun drive over.
Old 11-11-2003, 01:55 PM   #23
Gonz
Member#: 18642
actually, it was about 10 miles from here (Columbia MD)
It's actually $13.65 not $8.60 that I was quoted on the phone. Anyway I picked up oil drain plug gasket and transmission drain gasket while I was there.
So to answer my own question. THer is a SUBARU coolant, although few of the dealers seem to use it or sell it !
thanks for all the feedback.
G
Old 11-11-2003, 03:26 PM   #24
elgorey
Member#: 4374
06 Titan,99,94 SM
06 nasa spec miata champ
^what he said.
I read up on this a good deal before doing my 30k service. I decided it best to go with Subaru brand coolant.
btw, Ive got a mostly-full bottle if ya want it.
elgorey is offline   Reply With Quote
Old 11-11-2003, 08:56 PM   #25
modvp
Member#: 25215
the GM DEX-cool stuff will work fine.
modvp is offline   Reply With Quote
Is there a EDM specific plastic floor mat post? BIGSKYWRX Interior & Exterior Modification 0 05-08-2005 07:03 PM
are there any Subaru specific magazines out there? Hoplite General Community 10 08-16-2003 05:54 PM
Is there an Outback specific lowering spring? dvancleve Legacy Forum 6 09-27-2002 01:02 PM
Is there a scooby specific bone yard in New England? Camperguy New England Impreza Club Forum -- NESIC 10 07-22-2002 11:12 PM
Is this Subaru-specific book any good? PureWRX Newbies & FAQs 4 04-28-2002 12:55 AM
