Go Back   NASIOC > NASIOC Subaru Models > Outback Forum
Notices
Old 11-08-2003, 02:56 PM   #1
stevenmurray
Member#: 48030
2000 Legacy Outback
Unhappy Water Sloshing after rainfall. Frame rails
If car is parked nose uphill, when driving off on level ground - starting and stopping - I can hear large amounts of water sloshing forward or backward. It almost sounds like I'm at the ocean and waves are rolling in.
When I stop the car and look water is coming out of holes in the frame raiils on the drivers side of the car. This frame rail is inboard about a foot, water drips out different holes on its 6 foot lenth to the rear suspension.
Even on a dry day there will be water dripping down from the frame in the area behind the front suspension drivers A arm.
Any ideas or tech service bulletins out on this?
steve
stevenmurray is offline   Reply With Quote
Old 11-08-2003, 06:07 PM   #2
SubaH6
Member#: 38460
2005 Liberty 3.0R B
Obsidian Black
Obviously if there is water dripping from some where and you can here it sloshing about you have a problem. Where exactly is the water coming from? Your description is a little vague, but it sounds as though you've got a plugged drain hole on the chasis rail. Look under the car and see if all the drain holes are clear along the chasis rail.
It is a strange symptom as I've never heard of water being trapped in that area. I've heard of water being trapped in the rocker panel but never the chasis rail.
SubaH6 is offline   Reply With Quote
Old 11-09-2003, 06:20 PM   #3
stevenmurray
Member#: 48030
2000 Legacy Outback
THanks H6. The rail holes are pretty big. I did some work with a garden hose and made a new post - the problem is with the water coming down the windshield into the black cowl. That water fillls up something in the car body.
steve
Old 12-02-2003, 09:08 AM   #4
Rally Medic
Member#: 28249
1998 Outback Sport
Dirty with some mud flaps
Rally Medic is offline   Reply With Quote
Water Sloshing Issue? minorc Newbies & FAQs 8 10-07-2009 12:08 PM
water sloshing around in my dash??? sonicwrxpa Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 06-20-2007 10:54 AM
Water sloshing sound when revving and clutch in? affinity1 Newbies & FAQs 7 04-02-2006 11:07 PM
STI 04 water sloshing sound in cowl area WickedSTI Impreza Forum 5 04-20-2005 04:12 PM
Car Makes Weird Water Sloshing Noise ?? antidote11 General Community 18 12-30-2004 09:59 AM
