#1 |
Member#: 30039
NESIC
Vehicle:2002 wrx wagon dirt slvr |
I have a '93 legacy that the power windows stopped working today. All the windows do not run. It does not matter which switch you use - drivers side, passengers side or rears.
I've checked the fuse box under the dash (drivers side footwell) and the one on the driver's side of the engine compartment and all seem fine. However, I've not seen a listing on any of the covers that showed a power window fuse. Is there another fuse box? Other ideas about what failed? TIA. mch.
#2 |
Member#: 831
E. Canada
Vehicle:11 Blurple WRX 03 BH MBP |
My FSM for the 90 shows a relay under the drivers seat close to the door, under the carpet.
Manual says to remove the seat and roll back the carpet. Just another place to look. |
#3 |
Member#: 25516
NWIC
Vehicle:1995 Legacy TURBO!!! EJ22T/TEC3 & 06 MCS |
also, if the master switch (driverside door) goes out then none of the windows will work.
#4 |
Member#: 30039
NESIC
Thanks for the replys, I'll check things out.
mch. |
#5 |
Member#: 25516
NWIC
if you want i can ship ya a master door switch out of a 92 turbo. should be the same.
i dont think the fuse box in the motor bay would be of concern. if one of those fuses was blown then you would have big problems. |
#6 |
Member#: 38120
South East
Vehicle:1991 Rio Red Legacy Turbo |
All the stuff in the engine bay fuse box is for a/c and engine electricals (and headlights). There should be a fuse AND a relay for the windows.
#7 |
Member#: 30039
NESIC
I'm out travelling for the next week but will check out the switches when I get back. If I need them I'll be in touch.
Thanks for the offer. I may take you up on it. mch. |
| Thread Tools | |
| Display Modes | |
| Where the fuse box on a 98 Impreza OB | Jutboy | Newbies & FAQs | 4 | 01-01-2008 06:04 PM |
| Opinions on '93 Legacy Touring Turbo AWD Wagon | abracc | Newbies & FAQs | 2 | 12-31-2007 08:50 AM |
| ABS on '93 Legacy Turbo??? | denigrad | Legacy Forum | 10 | 07-17-2006 03:09 AM |
| '02 WRX suspension on '93 Legacy wagon | mch | Legacy Forum | 5 | 04-20-2003 12:51 PM |
| Suspension on '93 Legacy... | eastbaysubaru | Legacy Forum | 5 | 05-22-2001 12:19 AM |
