Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 11-08-2003, 06:36 PM   #1
starbuckjunkee
Member#: 48046
85 suburu
baby blue
Default Fix my heater.....please it's getting cold
I have a 1985 suburu that I'm sure is dyslexic! In the summer the air blows out hot and in the winter the air blows cold. What's my problem? I can't go through another winter with my kids freezing. The thermostat is new, the radiator is filled and the water pump is new. I've ran out of ideas to fix! When I turn on the defrost the fan blows but it blows cold air. Thank you for any help, my kids and I are very grateful.
Elise
starbuckjunkee is offline   Reply With Quote
Old 11-08-2003, 07:34 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
If you're sure the thermostat is working properly and you still don't have heat, it's possible the heater core is clogged. Has the antifreeze been changed regularly and is the system clean inside? It's possible a flush would help, or the core might have to be removed to be checked and blown out. It might also just need to be replaced if it can't be fully cleaned.
It's also possible there is a problem with the HVAC controls for temperature and air blending. Check the cables and make sure they are operating properly.
Old 11-08-2003, 09:42 PM   #3
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
In older cars, it's pretty common for the cabling to snap/come loose for the HVAC system - there is usually a cable actuated valve which diverts coolant to the heater core - check to see that it's operating properly.
Old 11-08-2003, 10:07 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
That's true, I haven't had to work on one in so long I forgot, but if there is a heater control valve it may well be the problem. The valve could be frozen or as mentioned the control cable or mechanism might be broken. I'm not familiar enough with older Subies to know for sure if your car has such a valve.
Newer cars generally have full-time coolant flow through the heater core and no longer use these valves.
Old 11-09-2003, 04:46 PM   #5
starbuckjunkee
Member#: 48046
85 suburu
baby blue
Thanks! You guys are super!
I'll let ya know what happens after I try these.
Elise
Heater gets cold when at a stop MikalsWRX Newbies & FAQs 2 03-25-2008 07:20 PM
It's so cold my nipples tore a hole in my shirt MGXsport Off-Topic 15 09-16-2006 08:15 PM
FS: Stuff so I can fix my car! please look! 96Imprezadent Private 'For Sale' Classifieds 0 11-30-2004 09:56 PM
it's getting cold. Akirasoft Off-Topic 22 11-20-2004 03:42 AM
It's getting cold in here, So put on some more clothes Fish Off-Topic 36 12-10-2002 11:42 PM
