Welcome to the North American Subaru Impreza Owners Club Friday July 3, 2015
Old 11-08-2003, 09:44 PM   #1
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Default The pulley debacle
First question.....how many different pulley sets are there?
I know there's UR, N1, & GFB. Are there any others I'm unaware of?
Next question, which kits have underdriven pulleys, and which pulleys are underdriven?
The reason I'm asking is that I currently have an UR underdriven pulley. I have replaced my stock alternator with a HO one. It uses an auto turn based on RPM speed. What's happening is that due to the underdriven crank pulley, at low rpms, the alternator is actually not on, and not producing power. My calcs are based at 500 rpm, which is an extreme, but I would like a safety margine.
In all honesty, I would actually like a stock sized crank pulley with an underdriven alternator pulley. Whether I get a PS pulley is arbitrary IMO. The million dollar question is can I get the pulley size combo I want without buying two kits?
Any comments would be greatly appreciated.
Thanks
Josh
Legacy777 is offline   Reply With Quote
Old 11-09-2003, 12:45 AM   #2
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
hm, I thought only Perrin makes stock size
Hyper is offline   Reply With Quote
Old 11-09-2003, 03:11 PM   #3
nySulli
Member#: 32617
2008 STi
perrin and mr josh are the only 2 stock sized ones i know of
nySulli is offline   Reply With Quote
Old 11-09-2003, 09:49 PM   #4
Legacy777
Member#: 4800
forgot about the mr. josh pullies.
I do know UR does make a stock sized pulley.....but I'm not sure if the full kit they sell has stock sized crank/alt pullies.
Guess it's time to email vendors.
Old 11-10-2003, 12:26 AM   #5
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Perrin and Mr Josh are not the only ones.
The N1 stock sized pulleys were taken over by the manufacturer (ISO certified machine shop here in Colo Springs) and the distributor is now ProECM in Colo Springs - with a couple of retailers, subaruplanet.com (me) and airborne motorsports.
They come with Alt, PS and Crank pulleys that drop about 5lbs from the stock set, and a set of stock sized gates belts free. These are very good quality and come in black, silver, blue and red.
[edit - PS not PC]
ImprezaRS dot com is offline   Reply With Quote
Old 11-10-2003, 09:10 AM   #6
Legacy777
Member#: 4800
So the N1 kit has all stock sized pullies, including the alternator?
What I really want is an underdriven alternator pulley and stock sized crank pulley.
Is there any chance you could take some measurements for me? I would like to know the circumference of the pullies where the belt rides. This can pretty easily be found by taking a skinny piece of paper, tightly wrapping it around the pulley, and then marking and measuring the line. If you think you could do this for the alternator & crank pullies I'd greatly appreciate it.
Thanks
Josh
Old 11-10-2003, 03:24 PM   #7
ImprezaRS dot com
over boosted again
Member#: 1458
ProECm has the pulleys accross town - I would have to ask them to measure, but they ARE all three stock size pulleys. The weight loss is 85% of the gains, and the crank pulley drops from 5.75lbs to 1.75lbs (I don't know the weight of the lighter cross drilled model) - the whole set is under 3lbs!
I don't know of anyone who makes a smaller underdrive alt pully to over spin the alt shaft.
Old 11-10-2003, 06:09 PM   #8
Legacy777
Member#: 4800
Thanks for the info. The GFB pulley set has a smaller diameter alternator pulley to compensate for the decrease in alternator speed from the under driven crank pulley.
I want to do some more checking, but it looks like I'll probably have to buy to kits to make everything work the way I want it to....we'll see.
Old 11-10-2003, 10:47 PM   #9
ImprezaRS dot com
over boosted again
Member#: 1458
We can sell you a Crank and PS without the Alt pulley, if you can GFB to sell you the smaller alt pulley by itself. Email me.
Old 11-11-2003, 12:41 AM   #10
Brento
Member#: 24485
02 RS
just a side note the perrin isn't quite exactly stock size. it is 97% of the stock size making it slightly underdriven. but in reallity you won't see any difference. i'm running it with two amps (40+40 amps at peak) with no problems.
Brento is offline   Reply With Quote
Old 11-11-2003, 08:45 AM   #11
Legacy777
Member#: 4800
These would be the N1 pullies, correct? I'll try and see about getting just the alternator pulley, and will be in touch.
Thanks
Josh
Old 11-11-2003, 12:52 PM   #12
ImprezaRS dot com
over boosted again
Member#: 1458
Thanks
Josh
Yes, the N1 - name changing to ProECM I believe...
Crank pulley install: How many ft-lbs to torque down the pulley? roninsoldier83 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 41 07-29-2008 10:48 PM
wtb: Idler pulley the pulley under the ac compressor stiboss Private 'Wanted' Classifieds 5 04-06-2008 02:32 PM
i have a specific question about the pulley - yes the pulley last lemming alive Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 05-13-2007 06:00 PM
Was anyone else there for the LIE debacle this morning? balajc Tri-State Area Forum 2 09-29-2003 12:13 PM
Someone with a quick response!!!..questions about the belts for the pulley AustinSTi General Community 1 01-29-2002 10:01 PM
