Go Back   NASIOC > NASIOC Subaru Models > Outback Forum
Old 11-08-2003, 10:37 PM   #1
StuartC
Member#: 48058
02 Outback H6
Pearl White
Default ECU Modifications for H6
I am currently getting around with a 3" cold air intake and custom exhust 2.5" from the heads back - got rid of the excess cats etc. On the dyno this is giving around 20Kw extra at flywheel. Has anyone managed to find someone to hack the ECU - yes I know that the VDC is a big pain - but I feel that this engine is wanting to give more and needs a tweak.
StuartC is offline   Reply With Quote
Old 11-09-2003, 04:50 AM   #2
SubaH6
Member#: 38460
2005 Liberty 3.0R B
Obsidian Black
Don't you just hate the VDC. Thats why I'm getting the base spec new H6 as it doesn't have the VDC.
SubaH6 is offline   Reply With Quote
Old 11-09-2003, 04:52 AM   #3
SubaH6
Member#: 38460
2005 Liberty 3.0R B
Obsidian Black
Hey, StuartC, I've just noticed that you've got a pearl white H6 like me and you're in Sydney too. What a coincidence. As I just posted I'm getting the new spec H6 and I can't wait. It's a beauty.
Old 11-12-2003, 06:12 AM   #4
StuartC
Member#: 48058
02 Outback H6
Pearl White
Love the VDC and what it can do in the wet/mud etc. Getting inside the ECU is the pain. What colour is the new H6?
Old 11-19-2003, 04:36 PM   #5
black H6
Member#: 48887
2003 outback H6
black
what kind of cold air intake and exhaust do you have, and how do you like them. I want to do something like that to my H6 but its really hard to find parts and info about modifying these cars.
black H6 is offline   Reply With Quote
Old 11-20-2003, 04:59 PM   #6
SubaH6
Member#: 38460
2005 Liberty 3.0R B
Obsidian Black
StuartC,
I'm getting another metallic white H6 (Subaru call it arctic white), although the new version is white not the creamy white of the last model.
Old 11-20-2003, 05:00 PM   #7
SubaH6
Member#: 38460
2005 Liberty 3.0R B
Obsidian Black
StuartC,
Where abouts in Sydney are you?
Lance
Old 11-21-2003, 05:29 PM   #8
StuartC
Member#: 48058
02 Outback H6
Pearl White
Answer to Black H6:
The cold air intake I built myself, basically it is 3 " mandrel bend mild steel tube running from the air resivoir at the back of the engine and out thru the hole in the RHS gaurd. Inside the gaurd I have a K&N cone filter mounted up high to avoid water. You get a fair amount of intake noise but the benifits are worth it. The exhust was a trial and error thing - man these H6 engines are noisey. I have 2.5" mandrel bend stainless running from the heads back to a Y junction at the rear of the engine. To reduce noise I had to put in a balance pipe about 12" back from the heads. Behind the the Y junction I am running a single Hi-Flow 2.5" Cat then a 24" x 4" resonator. Thru to the back in 2.5" and a single 14" straight thru muffler with a 4" tip. The best part of doing this is that it has moved the whole power curve and I am getting a big benefit below 3000rpm. Will try and post some pics late on.
Old 11-21-2003, 05:30 PM   #9
StuartC
Member#: 48058
02 Outback H6
Pearl White
G'Day Lance,
I am from the wilds of inner Sydney, Surry Hills.
Stuart
Old 12-02-2003, 08:54 AM   #10
Rally Medic
Member#: 28249
1998 Outback Sport
Dirty with some mud flaps
Rally Medic is offline   Reply With Quote
JECS ECU modification fastenova Normally Aspirated Powertrain 58 06-05-2010 03:11 AM
Looking for real-world advice on modifications for an OBS kattz General Community 1 09-02-2005 01:07 PM
ECU Modifications in Street Prepared? FSelekler Motorsports 24 05-13-2004 11:24 AM
STI - Know any European tuners for ECU modification? fassts4 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-20-2002 06:05 AM
What modifications for 12 sec. 1/4 mile? TurismoLou Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 44 03-01-2002 12:20 PM
