Old 11-09-2003, 05:15 PM   #1
slowme
Member#: 12235
2006 WRX Limited
Red
Question Engine Knock
This is on an MY00 RS.
When the engine is cold I can hear a knock coming from the engine. It is faint at idle, but around 1,500-2,000k on the tach it's pretty loud. After the car warms up the sound is still there, but not as loud as when the car is cold. I took it to the dealer and they said it was the timing belt tensioner. They said they replaced the tensioner...but the bolts look like they weren't touched. The sound was still there, so I brought it back to the dealer. This time they said that piston slap was the cause, that it was normal and to not worry about it. They even gave me a copy of a service note http://www.endwrench.com/current/win...03/insider.pdf Page 4 "Engine noises when cold"
I can't believe that this is normal for a car with 50k.
Anyone have any input?
slowme is offline   Reply With Quote
Old 11-09-2003, 05:23 PM   #2
NicEJ25
Member#: 26155
2008 WRX 5dr
Dark Grey
if you have piston slap at cold. it's about normal. if it still slap when hot, then it's no more normal, nor acceptable. the dealers have been told to replace the short block under warranty when engine emit piston slap noise at normal operation temperature. if you're still under warranty, go and shout at'em loud. if not, well, wait until something fail to open the engine or change the shortblock. you could wait long. 200K miles long...
NicEJ25 is offline   Reply With Quote
Old 11-10-2003, 12:18 PM   #3
marcus12
Member#: 45613
2005 Legacy GT Ltd.
Satin White Pearl
Noisy hydraulic lifters? Common on subies and is doing it on mine...try some of that Gunk oil treatment and Rislone with next oil change, it worked for mine.
//marcus
marcus12 is offline   Reply With Quote
Old 11-10-2003, 05:33 PM   #4
slowme
Member#: 12235
2006 WRX Limited
Red
NicEJ25: It's not as loud at operating temperature...but still there.
marcus12: How long to you keep the additive in the oil and do I have to use it every oil change?
Old 11-11-2003, 01:38 AM   #5
E Newman
Member#: 47213
98 Impreza 2.5 RS
Rally Blue
Piston slap is a big issue . The meaning of this problem is slamming side to side [tipping] movement of a piston when piston-to-cylinder clearance is excesive , can produce a very audible hollow , chattering sound . If that is happening , something like rings or play somewhere in the internal parts would be something to consider looking at . I say a better mechanic or one you can trust and get to the real problem . Your symptoms dont sound like " Piston Slap "
E Newman
E Newman is offline   Reply With Quote
Old 11-11-2003, 01:55 AM   #6
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
It's Piston Slap.. both my Subaru's make the same sound.. Sounds almost like a diesel truck in the morning. It's due because of the way the Pistons are made in the H-4 The pistons are short so they wont run into the Rod.
SubaruImpreza_power is offline   Reply With Quote
Old 11-11-2003, 07:55 AM   #7
slowme
Member#: 12235
2006 WRX Limited
Red
As per the dealer: "It's normal and to live with it." That was the same answer for two separate dealers. So it has to be normal, which I still can't believe. I hate that sound and if the car did it when I first looked at it, I would have skipped over it.
Any ideas of a good mechanic in Buffalo,NY?
Old 11-11-2003, 03:04 PM   #8
E Newman
Member#: 47213
98 Impreza 2.5 RS
Rally Blue
Try a high performance mech . Dealers are nothing but BS , They tryed to charge me 200$ to change a CV boot , what a joke.
Well then good Luck
Old 11-11-2003, 03:15 PM   #9
adeliciouspizza
Member#: 7844
05 STI CGM 450whp
05 FXT CGO Stock
hey, i have the same issue. have a look at these two threads:
It's a knock knock knock knock that seems to run in harmony with engine speed....
Heavy knocking sound when motors cold
also have a look at this page, it explains the issue and made me feel a bit better.
im just wondering if there is anything that can be done to make it better? i was in georgia and north carolina last winter when it was about 20-30 degrees outside, with about 7k miles and it was completely quiet. now i am at 35k miles in florida and its making noises when its like 60 degrees outside. i guess its a given that things will loosen up and get louder with time but it just seems excessive. it sounds like there is a wood pecker in my engine bay sometimes.
edit: i tried to link up a couple other threads about this issue. hopefully someone really smart will chime in.
adeliciouspizza is offline   Reply With Quote
Old 11-11-2003, 05:03 PM   #10
Machine Age Victim
Member#: 29961
2008 Honda Element
1975 Triumph Spitfire
I have always had valve noise (most boxer engines do, listen to a Porsche) but I've been developing what sounds like a leaky exhaust gasket, same cadence as engine RPM's and louder under load. but it doesn't go away when hot (like most exaust gasket leaks, expanding metal) sound liek your problem?
-jeff
btw I run 20w-50 because I favor the gas peddle and it gets really hot in florida
Machine Age Victim is offline   Reply With Quote
Old 11-11-2003, 05:16 PM   #11
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
almost 30k on mine and it does exactly the same thing on cold startup but goes away as the engine warms up. The only thing I could recomend is to experiment with different oil viscosities. When I switched to M1 0w-40 I noticed that the noise didn't occure as often and when it did ocure, it wasn't as loud as it was with the 5W-30 I was running previously. This deffinately sounds like piston slap especially since its effected by different oil types. I wouldn't worry about it unless it doesn't go away as the engine warms up.
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 11-11-2003, 10:34 PM   #12
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
I guess I have the "normal knock".
So a piston slap is heard louder while a knock is more noticeable in the driver's cabin?
Because on my sound, it's barely noticeable outside, more noticable inside.
-paK +2
Pakin is offline   Reply With Quote
Old 11-12-2003, 01:12 AM   #13
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
mine is also more noticable inside the cabin.
-- Ed
Old 11-12-2003, 04:54 AM   #14
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
in my 1995 L impreza I can hear it more inside the car and more so if you put your head down near were the passanger puts his/her feet.
Old 11-12-2003, 05:32 AM   #15
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
yep.. that's exactly where I hear the noise comming from as well!
Old 11-12-2003, 07:50 PM   #16
marcus12
Member#: 45613
2005 Legacy GT Ltd.
Satin White Pearl
Mine's noisy lifters...and it comes and goes with warmth...never completely, but it gets quieter when my car is all warmed up. I just use a bottle of Rislone in place of a quart of oil with every oil change and a little GUNK oil treatment every 3 weeks or so. Careful with that though...it tends to gum up your oil filter over time, so be diligent with oil changes. As mentioned by everyone else, Subarus make a lot of "noise" that is pretty normal for the most part. But if it's affecting the performance of your car, you should just bring it to a trusted mechanic for a professional opinion.
FYI, lifter noise is usually caused by a cracked / mis-shaped rubber seal and is a pretty easy fix when done professionally. I'm having mine replaced this weekend
hope that all helps, sorry for the lengthy post
//marcus
G35 engine Knock vs WRX STi engine Knock... BBBsti LTD General Community 6 03-21-2007 01:40 AM
Weird Knock noise, dont think its engine knock mlotek Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-14-2006 09:12 PM
Engine knock and rough running engine Chi_San Legacy Forum 1 07-23-2004 11:57 AM
Reason for Engine Knocking! ImprezedRS Normally Aspirated Powertrain 5 05-09-2001 03:21 PM
Engine Knocking! ImprezedRS Normally Aspirated Powertrain 4 05-06-2001 09:49 PM
