Old 11-09-2003, 06:50 PM   #1
SSTINGER77
Member#: 45635
02 WRX Wagon
Question best fuel management for my setup?
Im going to be headding to ATP or vishnu to get a dyno for a 02 wrx... When i dyno i will have on the car an vishnu U/P, 3" TURBO back( no cats ), IC hoses, Zerosports intake and k&n filter, lightweight crank pulley and colder plugs...
Also i have an MBC ( running 13psi )and a Dastek Unichip ( <-- i have no idea *** is does can someone explain )
I havent had time to consult with the owner of the car about what the Dastek Piggy back ECU is,
But with that said... My plans are to get a S-AFC and have it tuned to give me the fuel needed for my setup...
I don't want to get a re-flash yet because I dont know if i'll be done modding for the future, maybe get an exhaust manifold or larger turbo.
But whats your suggestions.. iM pretty much new to the suby powerplant
SSTINGER77 is offline   Reply With Quote
Old 11-09-2003, 11:49 PM   #2
csleee
Member#: 17861
stock should be fine
csleee is offline   Reply With Quote
Old 11-10-2003, 12:23 AM   #3
dunk
Member#: 15359
The Dastek Piggy back ECU, otherwise known as a unichip is a piggyback fuel and timing computer. As well as being able to make fueling changes, like a S-AFC, it is also able to make timing changes as well.
That being said, apart from the ability to tune yourself, it seems redundant to put a S-AFC on the car when you have a unichip. It would be far more worthwhile to have Vishnu just tune the unichip, a system they have lots of experience with. This will most likely give you far greater gains than the S-AFC due to the ability to make timing changes.
cheers
Duncan
dunk is offline   Reply With Quote
Old 11-10-2003, 01:11 AM   #4
csleee
Member#: 17861
sorry, i thought you were talking about injectors and that sort of thing, but yea you should have the unichip tuned. It will yeild more hp gains.
Best route for my Setup? HELP! Propaganda Engine Management & Tuning 1 04-15-2005 12:30 AM
Best boost controller for my setup? Rizzo314 Engine Management & Tuning 3 07-12-2004 09:37 PM
FMIC or TMIC is best for my setup Xtremewrx Factory 2.0L Turbo Powertrain 19 03-17-2004 01:48 PM
Best Fuel Management Drivingchallenge Factory 2.0L Turbo Powertrain 0 10-17-2002 12:26 PM
Which is the best aftermarket fuel management for modded WRX please help ImprezaSTIVI Factory 2.0L Turbo Powertrain 47 07-24-2002 12:22 PM
Message Board Statistics All times are GMT -4. The time now is 12:59 AM.
