Welcome to the North American Subaru Impreza Owners Club Wednesday July 30, 2014
Old 11-09-2003, 07:36 PM   #1
PeterJ
Member#: 14727
2002 impreza RS
Default Can octane requirement be calculated?
If one was "building up" a NA 2.5 motor and wanted a higher compression ratio, would there be a way of calculating the octane level of the fuel required to run the engine without damage? Or to word it another way, knowing that 11:1 is good for 87 octane, how hight of a compression ratio could one go using 93 octane as the minimum?
PeterJ is offline   Reply With Quote
Old 11-09-2003, 08:59 PM   #2
orndog
Member#: 34670
2013 No gears!
Saltine American
11:1 and 87 octane? Are you nutz?
orndog is offline   Reply With Quote
Old 11-09-2003, 10:48 PM   #3
PeterJ
Member#: 14727
2002 impreza RS
OMGHi2U
Isn't that what a 2.5RS is at? Or did I mean 10:1... oops.
Old 11-14-2003, 08:45 AM   #4
Section 8
Member#: 821
you cannot calculate octane requirements. You can calculate compression ration before hand though. Most people will not run more than 11:1 on 93 octane, others even less.
Other things come into play for detonation resistance of an engine, such as quench, timing, anything not quite right in the cylinder/combustion chamber ect. You can play with timing, but eventualy you run into a point where you can raise the comprssion, but you loose timing so you gain nothing.
cheeRS,
Greg
Section 8 is offline   Reply With Quote
What octane would be safe to run? chico_kj_23 Subaru Conversions 20 07-16-2006 11:34 PM
I know beautiful woman can be unattractive but can ugly ones be attractive? Undepelo Off-Topic 27 06-23-2005 04:47 PM
Minimum Octane Requirements For FXT N10S Factory 2.5L Turbo Powertrain 8 12-24-2004 07:48 PM
Cobb & Vishnu Octane requirements allythom Engine Management & Tuning 5 04-29-2003 12:36 AM
Unichip Octane Requirements/Octane Boosters? 2002wrx1 Factory 2.0L Turbo Powertrain 12 08-18-2001 12:42 PM
