Old 11-10-2003, 04:40 PM   #1
Kuonji
Member#: 44406
2004 STi
Silver/Silver
Default Jack points for STi
Can anyone tell me the ideal front and rear jack points for the STi using a floorjack? Also, where should I put the jackstands once it's jacked up? I'm really worried about putting these things in the wrong place. Thanks!
Kuonji is offline   Reply With Quote
Old 11-10-2003, 05:02 PM   #2
Brack
Member#: 12445
13 Accent
Red
I jack the front up by putting the jack under the frame member with the 4 bolts in it,just under the oil pan,just past the plastic shield.I use a block of 2x4 between the jack and the frame member.On the rear,I put the jack under the rear diff housing and lift.
Jackstand placement is outlined in the cars manual
Brack is offline   Reply With Quote
Old 11-10-2003, 05:18 PM   #3
imminence
Member#: 39617
2005 M3
I jack the car up at the tow hooks both front and rear.
imminence is offline   Reply With Quote
Old 01-14-2004, 06:21 PM   #4
Kuonji
Member#: 44406
2004 STi
Silver/Silver
I couldn't find the front tow-hook. Where is it?
Old 01-14-2004, 06:54 PM   #5
rexxer
Member#: 27624
2014 WRX
Is that the one you have to screw in? The WRX comes with a mini-tool kit with a tire iron and a tow hook that screws in.
rexxer is offline   Reply With Quote
Is there an optimal ignition point for STi? bboy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 16 12-02-2007 05:25 PM
preffered trolley jack points for front work Kastley85891 Tire & Wheel 1 07-02-2007 06:46 PM
Nervous about jacking the car up at front jack point BlackoutWRX Newbies & FAQs 10 10-27-2006 11:14 PM
jacking points for the front and back of the STi maengelito STi Forum Archive 2 08-29-2003 02:22 PM
