Old 11-10-2003, 07:33 PM   #1
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
Default Can you use normal crush washers on Fumotovalve?
I'm pretty sure the fumotovalve came with a blue washer on it to seal up to the oil pan. I think it was just taken away with my old engine, it must have just stuck to the pan. So is it ok to just slap an OEM washer on there? Don't see why not, just want to see if anyone has a reason not to. Thanks.
garface is offline   Reply With Quote
Old 11-10-2003, 08:52 PM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
I have used a Fumoto since 1k miles and am now at 10k. I used the stock Fumoto blue washer and that's it, no leaks. Prior searches about this issue here led me to believe this is what most Fumoto users do. Some do use the OEM washer instead and have had good results. I personally don't think it matters, so you should be OK with OEM. Install and check 2-3 times over the first week to make sure it's OK. Best of luck.
Old 11-10-2003, 09:00 PM   #3
rbehny
Member#: 1908
I don't know the exact thickness of the blue washer but its purpose might be to push the valve further out. Thus in turn less threads are visable from the inside and more oil can be removed. If the blue washer's thickness is about the size of a crush washer then i haven't a clue.
:edit: the only reason i bring up the threads protruding into the oil pan is because Peaty had to file a groove into the top three threads to be flush with the inside of the oil pan.
rbehny is offline   Reply With Quote
Old 11-10-2003, 09:52 PM   #4
aj's25rs
Member#: 30160
9900 2.5rs
rbp,srp
you shoudnt need anything but a standard washer. most cars just have a standard washer. the thickness might matter due to the threads. good luck
aj's25rs is offline   Reply With Quote
Old 11-11-2003, 10:32 AM   #5
jikhead
Member#: 32535
2009 Nissan 370Z
Monterey Blue
I just put mine on Saturday. I used the blue washer and also used some high heat red silicone because the factory plug had a slight leak. Using the silicone helped seal it up real good.
jikhead is offline   Reply With Quote
Old 11-11-2003, 10:37 AM   #6
bluestone
Member#: 36583
2004 WRX sedan
Is the fumoto supposed to be installed with just one of the blue washers? Mine came with four... not sure why, should it be spaced out like rbenhy said?
bluestone is offline   Reply With Quote
Old 11-11-2003, 11:06 AM   #7
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
You could try to use a crush washer but it would be difficult to get the proper torque on it because a socket won't fit. I've also seen that the threads need to be slotted so that you get a full drain.
I used blue loctite on the threads along with the fiber washer they provided.
Tim Sanderson is offline   Reply With Quote
Old 11-11-2003, 05:03 PM   #8
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Using all four washers would be BAD! Pitch 3 and use one. Too much space is a bad thing and will probably lead to leaks. The spacing issue is really moot as the Fumoto goes into the oil pan by 3-5mm if I remember. Do a search on www.scoobymods.com for fumoto and someone there modded their Fumoto to account for this. In my opinon that is super anal retentive as the oil that the Fumoto leaves behind is approximately .00000000044223232 quarts, so why worry.
Old 11-12-2003, 09:56 AM   #9
bluestone
Member#: 36583
2004 WRX sedan
ok thanks i'll use just one. i thought the issue was particles might get left behind in those couple drops that don't come out, that's all..
Old 11-12-2003, 02:13 PM   #10
bluesubie
Member#: 767
04 FXT
I use 3 of the blue washers on an OB and a WRX. I've had them on for over 6 months and haven't had any leaks.
I asked Fumoto for extras because I didn't want the valve sticking too far into the pan like on Scoobymods. Even with three washers, I still drained out a little more oil after removing the Fumoto yesterday.
-Dennis
Old 11-12-2003, 05:27 PM   #11
bluestone
Member#: 36583
2004 WRX sedan
dennis i think i bought your extra that's why i have the stack of washers. i'll use 3 as well =)
Old 11-12-2003, 05:27 PM   #12
InfamousDX
Member#: 25413
I just ordered me one of these because I enjoy the ease of the product. I just hope it doesn't leak, that's all.
Old 11-14-2003, 02:29 PM   #13
e_a_olson
Member#: 7034
2005 Nissan Altima
2.5SL - Black
I've been using mine for 2 1/2 years without any semblance of leakage...
e_a_olson is offline   Reply With Quote
Can you use 3 inch gasket on 80mm exhausts? WRXSleeper Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 12-12-2007 09:31 AM
so does anyone in Houston know where I can get drain plug crush washers? Big_Hitter Texas Impreza Club Forum -- TXIC 10 10-05-2004 01:03 PM
what size is the crush washer on a late 03 5MT gaijin Transmission (AT/MT) & Driveline 8 07-25-2004 05:44 PM
Crush washer on tranny and if plugs? DanZ Service & Maintenance 4 04-13-2004 10:57 AM
ONLY use Subaru crush washers... mykrrrr Mid West Subaru Owners Club Forum -- MWSOC 2 05-20-2003 11:59 AM
