Old 11-11-2003, 03:07 AM   #1
Rubasu
Member#: 1418
MY00 2.5RS
Default p0483- cooling fan rational
I threw this code the other day when my check engine light came on. what does it mean and how do I fi it. thanks
rubasu
Rubasu is offline   Reply With Quote
Old 11-11-2003, 06:06 PM   #2
DrBoy01
Member#: 20444
2006 Outback 2.5 XT
Garnet Red Pearl 5MT
I think it means that your cooling fan can use reason to obtain knowledge and enlightenment
JK, not a clue, sorry man. That's a funny code though, never seen it before...
DrBoy01 is offline   Reply With Quote
Old 11-12-2003, 09:47 AM   #3
Puckaveli
Member#: 1518
00 2.5RS
That's a Cooling Fan Function Problem. One of the fans had a malfunction. Sometimes if you idle the car with a wall or another car in front of it it sets off the code. Make sure nothing is blocking them. And check the fan blades. Are you overheating or hearing any funny noises? Make sure both fans are coming on. If nothing seems wrong then clear the code and see if it comes back.
Puckaveli is offline   Reply With Quote
CEL P0483 Cooling fan rationality check malfunction Loki Service & Maintenance 13 10-31-2012 03:46 PM
Cooling fan rationality check? crpwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-18-2010 01:08 AM
P0483 Cooling Fan Rationality Check Malfunction RS2001 Service & Maintenance 6 09-10-2009 09:29 PM
P0483 Control Fan Rationality Check Malfunction Sudaka Service & Maintenance 7 03-25-2009 01:40 AM
cooling/radiator fan rationality check? boshot427 Normally Aspirated Powertrain 0 03-22-2007 08:22 PM
