Old 01-12-2001, 08:17 AM   #1
CP
Member#: 3522
1997 A4 1.8TQMS
Pearl White
Post Swaybars and cracked subframes
I've got a question for you guys. On my A4, there were issues when Neuspeed came out with a 22mm rear bar. Replacing the stock 12mm bar(or 16mm w/ the sport pkg) resulted in a few cracked rear subframes. Neuspeed then came out with some very beefy braces that protected the subframe mounting points, and there have been no problems since.
Have there been any issues for the Imprezza with regards to breaking things when a thick swaybar is used?
Thanks,
-Cy
CP is offline
Old 01-12-2001, 08:27 AM   #2
rao
Member#: 52
2005 Legacy GT
98 BMW 540i LS2/T56
Post
Not an issue at all - the way the swaybars are mounted are completely different.
Those Neuspeed brackets are slick, but don't even think about installing them unless you have a set of offset box wrenches handy .
rao is offline
Old 01-12-2001, 08:38 AM   #3
scoobiejosh
Member#: 3139
2001 Dodge Pikumup
& 08 Triumph Speed Triple
Post
I havent herd of any but there are several heavy duty end links and mounts for the bar that are a good idea to get anyway as they are suposed to make for a more predictible car. The stock endlinks are plastic and can lead to twitchy behavior at the limit. BTW this is what i have herd and not from experience.
Josh
scoobiejosh is offline
Old 01-12-2001, 09:06 AM   #4
Spectre23
Member#: 311
2013 STi
CBS
Exclamation
MRT told me you have to get the heavy duty sway bar mounts if you go with the 24mm dia. sway bar. With the 22mm they said you are OK with stock mounts.
Spectre23 is offline
HTML code is On
FS:COBB swaybars and WL 27/29mm front swaybar Bluemanchu Suspension/Brakes/Handling 17 04-24-2010 12:51 PM
FS NJ: Hotchkis Competition Rear Swaybar and Helix Front Swaybar KIDREX Suspension/Brakes/Handling 0 06-25-2008 02:47 PM
Tein Flex Coilovers__Cusco/Kartboy Swaybar and Endlink Package__Perrin 25mm Swaybars! Spun Autosports Suspension/Brakes/Handling 57 01-28-2008 07:48 PM
SoCal: Gt Spec subframe, ALK, swaybars and more BlueFish Suspension/Brakes/Handling 23 02-25-2007 12:19 AM
Mating undertray and front subframe brace Conecrusher Brakes, Steering & Suspension 19 11-27-2004 09:00 PM
