Go Back   NASIOC > NASIOC Archives > NASIOC Archives > General Forum Archive
Old 01-14-2001, 10:35 PM   #1
shukes24
Member#: 1052
you fought
the good fight?
Post rising fuel regulators....
Which type are people using? I know that Bell, Cartech, Weapon R all have rising fuel regulators, but what makes one different from the other? Which would you recommend?
Thanks in advance,
Nirmit
shukes24 is offline
Old 01-14-2001, 10:56 PM   #2
Overtime
Member#: 1346
Post
WeaponR is crap.
Tom is using Cartech because that's what he's used in the past and it's worked fine. Of course, if you like, you can get a Holley or Bell or whatever brand name makes RRFPRs...but as long as it does the job...
Overtime is offline
Old 01-15-2001, 12:22 AM   #3
AaronB
Worst Mod Ever
Member#: 369
12 Vagon
Smile
Bell and Cartech are the same thing. If you look at their addresses and phone numbers they are exactly the same
I too have heard that WeaponR is crap.
I am going with a Vortech SFMU. It seems to have more adjustability, but it does cost a bit more. I am going with it mostly due to the fact Bell wasn't going to have any more made for over 3 weeks when I called them, and I am impatient.
BTW Teague sells the Bell unit as well for $199. Might as well give the business to a Subaru vendor, if you want the Bell
Aaron
AaronB is offline
Old 01-15-2001, 01:15 AM   #4
Sam Kaufman
Member#: 3135
98 2.5 rs
red
Question
Are you guys using fuel pres. regulators on N/A cars? I was told that if your only running intake,header and exhaust, you will not see much differance.Have you ran into any engine lights? Whats your take on this and what have you done to your cars? Would you recomend new sti engine/tranny mounts or a regulator?
Sam Kaufman is offline
Old 01-15-2001, 07:35 AM   #5
stewartg2000
Member#: 1570
2009 Impreza WRX
WR Blue
Post
i was using a weapon-r fpr, i put it at 47psi initially and it squealed like it had an air leak (which it didnt), it wasnt until i put it to 50psi that the sound went away and i noticed considerably better throttle responce. but then i started having problems and started stripping out my parts (came to be a loose afc wire) and i could really feel how much of a difference it made when i took it out. i havent used any others, but i would say that i was pretty happy with the weapon-r, its just a pain to install (as would any) so its not back in yet.
as for mods, i had intake, exhaust, fpr, and afc.
hope this helps a little.
-- stewart
stewartg2000 is offline
HTML code is On
Rising Fuel Pressure Regulator Oo DaRk StAr oO Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 52 11-25-2009 12:58 PM
WTB (RI) stock WRX top feed fuel rails and fuel regulator tro8 NESIC Private Classifieds 4 11-05-2009 06:59 PM
Wideband o2 (AFR monitor), rising rate fuel regulator wanted.. wong-wing Private 'Wanted' Classifieds 1 06-20-2006 03:54 PM
Need Fuel rail or fuel regulator vortectoy Private 'Wanted' Classifieds 0 05-04-2005 01:26 AM
SX Fuel regulator and perin fuel rails IA Performance Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 12-19-2002 08:55 AM
