Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 11-11-2003, 07:06 PM   #1
S.G.D
Member#: 36448
Default power loss
i got my car back from subaru yesterday after having a valve cover gasket and a front o2 sensor replaced. i noticed as soon as i started the car somethign was wrong. there is an odd "Wooshing" sound under acceleration, it sounds like a vacuum, but faint and there is a significant loss of power and intake sound under accleration. i checked the intake, and i made sure it was tight.
subaru told me that they had removed the engine becuase they belived that it was the head gasket leaking when it was only the valve cover. so my question is;
is there anything that they could have left disconnected after reinstalling the engine that would lead to these symptoms?
Thanks,
~SGD
S.G.D is offline   Reply With Quote
Old 11-11-2003, 10:05 PM   #2
petergun
Member#: 46425
2004 2.5 TS '15 BRZ
Platinum Silver / WRB
Weird, that sounds like actually cooling system problem my '95 Avenger suffers from. Since they moved so much stuff around, better have them recheck.
Also, since I'm from Montreal, can I ask you which dealership ?
petergun is offline   Reply With Quote
Old 11-12-2003, 10:21 AM   #3
S.G.D
Member#: 36448
subaru des sources.
im pretty sure it's an honest mistake. but my ganzflow was not properly installed when i got home, like it was when i took it in.
i will try and go see them tomarrow.
~SGD
Power Loss? Need Advice. BrysImpreza Normally Aspirated Powertrain 18 06-02-2001 12:36 PM
Power Loss Rayman Newbies & FAQs 2 04-21-2001 10:37 PM
Power loss in 3rd gear Jazz95 Newbies & FAQs 4 04-10-2001 07:59 AM
Power loss due to ignition kill Stavros g Technical Forum Archive 2 07-05-2000 04:24 PM
low end power loss... solutions: (tec2 ?) alastair Technical Forum Archive 8 07-03-2000 11:49 AM
