Old 11-11-2003, 06:20 PM   #1
aj's25rs
Member#: 30160
9900 2.5rs
rbp,srp
Default over oiled k&n on my99rs!!!!!!!!
i recently put a k&n on my intake again and it must have been over oiled because my car isnt happy. i pulled the maf out and it was covered. so i bought carb cleaner with tolene(wrong spelling) and cleaned it then drove home pulled it out and cleaned it again. this sucks tommorrow ill probably but another maf. all this for a little hp increase. well thanks for letting me vent.
anthony
aj's25rs is offline   Reply With Quote
Old 11-11-2003, 06:35 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
YUCK. Sorry you had to learn the hard way.
Old 11-11-2003, 07:04 PM   #3
Keith99RS
Member#: 9243
05 Nissan Titan
06 B9 (hers)
Do a search on cleaning the MAF. Also ScoobyMods.com may have some hints.
Keith99RS is offline   Reply With Quote
Old 11-11-2003, 08:22 PM   #4
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Default Mafs
Not only that but at least a new Air Flow Sensor is only $50.00 or so. The whole MAF sensor housing does not need replacing. I think that's on the scooby.mods site as well. That is, if you do need a new Maf sensor.
Edit: Yep, it's on that site.
ScoobyMod Maf replacement
Kevin Thomas is offline   Reply With Quote
Old 11-11-2003, 08:35 PM   #5
nunyo
Member#: 35575
'07 Subaru OBS
Silver/Gray
[homer]D'oh![/homer]
nunyo is offline   Reply With Quote
Old 11-11-2003, 09:35 PM   #6
^jynx^
Member#: 1787
Have you been getting my PMs?
^jynx^ is offline   Reply With Quote
Old 11-12-2003, 01:20 PM   #7
aj's25rs
Member#: 30160
9900 2.5rs
rbp,srp
thanks guys ya i cleaned it so the sensor i hope is fine and thank god ther not 300 anymore. well ill see what happens.
jnyx; im still getting pm's, i sent you one
Old 11-12-2003, 04:52 PM   #8
^jynx^
Member#: 1787
Last PM i got from you was on 11-08-2003 09:43 AM
I have sent you atleast 3 sence then. Maybe email me? or do you have AIM? IM me @ "Tuned By STi"
Old 11-12-2003, 08:32 PM   #9
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
use a non oiled filter, I run a pipecross filter from a rallispec intake, its like 75 bucks but worth it.
Jay
Old 11-12-2003, 10:05 PM   #10
aj's25rs
Member#: 30160
9900 2.5rs
rbp,srp
thanks mcdade i think its alright now. on friday ill pull everything off and clean the maf one last time as i think the oil is all been pulled through. actually i keep conteplating putting the stock boxes back on with just the one filter, and gasket in the torque box. i dont know though. i still feel there is power more mid to upper with the j-bend intakes and low to mid with the stock setup. thanks to all
Old 08-06-2012, 10:10 PM   #11
chrisbouchard
Member#: 318846
this post is really old but i ahve done the same thing with my 03 wrx wagon. check engine light is on and have to be at work at 7am tomorrow wit ha 2 hour drive to get there! I have taken air box out, washed, dried and replaced ocne again. car is running but check engine light is on. do i have to worry about car dying or will check engine light stay on until the part is replaced?! stressing out!!
chrisbouchard is offline   Reply With Quote
Old 08-07-2012, 09:36 AM   #12
GrundleJuice
Member#: 165749
Go buy some MAF cleaner, unplug the maf from the harness, pull the sensor out of the housing and rinse it generously with the cleaner. Blow it off with some air. Repeat that 3 times and then re-install. Should cost you about $10 and 30 mins of your time
GrundleJuice is online now   Reply With Quote
Old 08-07-2012, 10:56 AM   #13
UsernameGoesHere
Member#: 328215
K&N sucks ****. Now you know.
UsernameGoesHere is offline   Reply With Quote
Old 08-07-2012, 12:32 PM   #14
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
^This times abillionty^
Counterfit is offline   Reply With Quote
Old 08-09-2012, 03:54 PM   #15
giosoccer20
Member#: 328622
1999 Impreza 2.5 RS
I've had a rough idle myself, and hanging revs if i throw the car in neutral when it's over 1500k revs. I read about the MAF sensor cleaning and I went ahead and did that. Sadly, the problem isn't fixed, and my check engine light is still on, but I'm not even sure if that is the case. does a faulty MAF sensor throw a CEL on a 1999 2.5 RS?
giosoccer20 is offline   Reply With Quote
Old 08-09-2012, 06:35 PM   #16
GrundleJuice
Member#: 165749
a faulty MAF sensor will usually cause a CEL to be triggered on any MAF based EFI system. What DTC is your CEL for?
Freshly Oiled K&N drop in filter newrexracer Service & Maintenance 12 05-12-2008 09:04 PM
Non Oiled K&N Air Filters - Anyone tried them? cjfike Normally Aspirated Powertrain 7 11-10-2005 02:07 PM
S/C vs. Turbo on MY99RS [email protected] Normally Aspirated with bolt-on Forced Induction Powertrain 12 04-12-2005 03:21 PM
Help: How to re-oil K&N Air Filter?? poison Service & Maintenance 4 06-25-2004 04:39 PM
RE-oiling K&N? Oquipah Normally Aspirated Powertrain 5 08-23-2003 12:55 PM
