Old 11-11-2003, 08:40 PM   #1
Sonic Yellow 2K3 WRX
Member#: 33236
Default I just stripped the hex off a lug
(the hex is completely rounded) what's the best way to get it off now...without damaging my rims?
Sonic Yellow 2K3 WRX is offline   Reply With Quote
Old 11-11-2003, 09:39 PM   #2
Bottom Feeder
Member#: 2808
I know Sears makes some kind of packaged set of nut removers. You basically hammer this thing on (I think) and use a ratchet to take it off. This may not work if your wheel doesn't have a lot of clearance around the lug hole.
Silly question: How did you do this?
Bottom Feeder is offline   Reply With Quote
Old 11-12-2003, 01:21 AM   #3
kenchan
Member#: 15106
is it completely rounded or do you have some rounded shoulders?
my buddy and i hammered in a socket 1mm smaller and
was able to take out the lug that way on his stripped lug.
just be careful not to break the stud.
kenchan is offline   Reply With Quote
Old 11-12-2003, 08:00 PM   #4
Corn-Picker
Member#: 8679
2010 The most hated
vehicle on the internets
You need a bolt extractor...
I would also suggest a toque wrench:
Overtightening lugnuts helps to warp your rotors. Follow the specifications in the owner's manual for the correct torque.
Corn-Picker is offline   Reply With Quote
Old 11-13-2003, 11:06 AM   #5
KoneKiller
Member#: 39191
2004 WRX STi WRB
Red 1990 Spec Miata
KoneKiller is offline   Reply With Quote
Old 11-13-2003, 06:08 PM   #6
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
Vice grips...
Worked for any bolt that wouldn't come off of Cam's car.....
IronMonkeyL255 is offline   Reply With Quote
Old 11-13-2003, 10:58 PM   #7
bbbwrx
Member#: 32734
break off the stud and replace if all the above fails. or take it to a tire shop and have them deal with it.
BEN
bbbwrx is offline   Reply With Quote
Old 11-14-2003, 04:36 PM   #8
BlackAndBlue
Member#: 40617
where is this in the owners manual?
BlackAndBlue is offline   Reply With Quote
Old 11-14-2003, 11:02 PM   #9
leecea
Member#: 37359
2003 WRX
It is not in the manual that comes with the car - at least it wasn't in mine. Most people seem to go with 70 ft/lbs. I believe it is specified in the service manuals.
leecea is offline   Reply With Quote
Old 11-14-2003, 11:33 PM   #10
Corn-Picker
Member#: 8679
2010 The most hated
It is in the manual, it's somewhere in the instructions for changing tires, in reference to the spare I believe. IIRC, 70 ft-lbs is on the high end (or over) what Subaru recommends. I think the spec is 45-65 ft-lbs, but check the manual to make sure.
Old 11-14-2003, 11:44 PM   #11
c_hunter
Member#: 32434
05 Outback XT 5EAT
Gold/Black
It's in my 2003 manual, page 9-13.
58-72 ft-lb. I set my wrench at 65 ft-lb.
Craig
c_hunter is offline   Reply With Quote
Old 11-15-2003, 12:46 PM   #12
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
Same here.
Old 11-15-2003, 02:16 PM   #13
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
You should also use antiseize on the studs.
Patrick L is offline   Reply With Quote
Old 11-15-2003, 06:43 PM   #14
Bottom Feeder
Member#: 2808
No, you shouldn't. There was a pretty long thread about this recently.
Wheel studs should be clean and free of rust, but they shouldn't be lubricated at all. Doing so will throw off the reading on your torque wrench, which will cause you to overtighten your lugs by a pretty large amount. Bad idea.
Old 11-16-2003, 12:38 AM   #15
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
Show me
I can give you some reasons why you should. Aspecially if you take your wheels off and on regularly. First off, it will not make it miss read. If anything make it read more accurate. The problem is that with regular remove and reinstall. You rubber off metal off the nut and or stub and get build up which can cause the nut to seize and also throw off the reading on the torque wrench. The problem I see is people who use their torque wrenches improperly. The stufff I use has the high copper content.
Old 11-16-2003, 02:44 AM   #16
bbbwrx
Member#: 32734
I will use anti size if mechanics have been doing it for ever then it can't be that bad or wrong.
BEN
Old 11-16-2003, 12:56 PM   #17
Bottom Feeder
Member#: 2808
Show me
Well, I looked, and for the life of me, I can't find the damn thread no matter what search terms I used. Go figure.
In a nutshell, someone chimed in on a thread about someone rotating their tires, saying the user should remember to lube the wheel studs. A few guys jumped all over that bit of advice (myself included), and Luke came up with the technical reasons why doing so is a really bad idea. Basically, torque values on wheel lugs and studs are determined when they're dry, not lubricated. Using those dry values an a lubed stud will cause you to overtighten the lugs, possibly stretching the stud beyond it's specs or damaging the wheel.
I really wish I could find that damned thread. Oh, well.
Old 11-17-2003, 10:44 AM   #18
Infymus
Member#: 20588
I'm Harrassed By
NASIOC Mods
I made it a policy with the Subaru Dealer that I use here in SLC - they are absolutely forbidden to touch my tires.
I do NOT know what it is with dealers but they torque the lugs down so hard I actually BROKE the tire-iron that comes with my WRX. I had to use a farkin hammer on the tire iron to get the lugs off they were on so tight. I'd say they used probably over 150lb to 200lb torque to stick them on. The manual says 65 to 72 ft lb of torque, but I'm sure the dealer has never read the manual.
I have no idea why, but now I forbid them from touching my tires. Personally I use a tire-iron to slightly tighten up then I use a torque wrench to apply the proper tightening.
Dang dealers and their air guns, they make the baby jehbus cry.
Infymus is offline   Reply With Quote
Old 11-17-2003, 12:39 PM   #19
imprezzed
Member#: 1624
2002 OBS 5 Spd
Green
ehhhhhh no, it's not the air gun, it's the operator. I have a set of torque sticks that attatch to to the end of my gun and will basically tell the air gun to stop tightening at a predetermined value. I use an air gun all day at work and have never had any complaints. (I'm a subaru mechanic BTW) It's the people that don't know what they are doing with the air gun and turn the adjustment on the gun to "stun" and go to town on your nuts. Wait a minute that didn't come out right...
And no, you should not use anti sieze on lug nuts. I was told this directly from the regional Snap-On manager, who deals with many manufacturers and also sells a lot of torque wrenches.
You should however apply anti sieze to the mounting area on your brake rotors. (The flat area in between the studs when the wheel is off) This will prevent the wheel from rusting on, and make it easier to take off the next time.
Anywho...hope this helps
Jason
imprezzed is offline   Reply With Quote
Old 11-17-2003, 05:06 PM   #20
DISCOPOPE
Member#: 43339
2oo4 STi
URgt35r w/t3hM3finj3cki0n
nuts
torque
studs
lube....
wtheck is going on here...
DISCOPOPE is offline   Reply With Quote
Old 11-17-2003, 05:20 PM   #21
alfaguy
Member#: 14238
2002 WRX Wagon - PSM
Alfas: 89 Milano | 72 GTV
When a manufacturer lists a torque specification, it is assumed to be on "dry" fasteners. If a lubricant or sealant is needed, it will be noted, i.e.:
54 lb/ft, oiled
or sometimes even the lubricant is specified:
54 lb/ft, MolyKote 752 Synthetic Grease
25 lb/ft, Wurth Threadlocker
If a fastener is torqued to it's "dry" torque spec with a lubricant, the actual stretching force applied to the fastener is far greater than intended.
alfaguy is offline   Reply With Quote
Darn it... Just stripped the threads on the bolt that holds the knock sensor in. Surestick Normally Aspirated Powertrain 3 04-21-2010 05:28 PM
Stripped the hex fitting on top of strut ??? Joynt93 Vancouver Impreza Club Forum -- VIC 10 03-10-2009 12:35 PM
Stripped 10mm Hex Cam Gear Bolt!! HELP!! onemoreday21 Built Motor Discussion 41 11-17-2008 02:27 PM
I just took the cap off a bottle of beer.... eurojax Off-Topic 26 08-28-2006 12:03 PM
Getting Off Strip Behind Rear Door. Indy-Lug Nuts WRX03 Mid West Subaru Owners Club Forum -- MWSOC 6 05-07-2003 08:54 AM
Message Board Statistics All times are GMT -4. The time now is 04:03 AM.
